Whats the best HTPC/WMC7 controller app for Android? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 11-04-2012, 12:05 AM - Thread Starter
jeff lam's Avatar
I'm looking into getting more high tech with my HTPC and I know a lot of developements have come recently with tablet and phone wifi controllers to interface with HTPC and WMC7. I saw that Ceton came out with a new app and it looks great as you can schedule recordings and do almost everything you can control wise at your PC but it costs $5. I have an HD Homerun Prime but it is said to work with all tuners as well so that is nice...
Ceton Companion App
I also have seen several others that dont look quite as nice and as functional but I would also prefer a free app if there is one available.
I have an HTC Evo 4G LTE and also an Asus Transformer 101 both running Android ICS.
I have Plex on both for streaming but I want to get into scheduling recordings and full control while I'm not at home as well as start playing and control TV and WMC while I am there.
jeff lam is offline
post #2 of 18 Old 11-04-2012, 05:34 AM
lockdown571's Avatar
Quoted: 66 Post(s)
Liked: 93
Ceton Companion does exactly what you want to. I don't know of any free programs that do this. It's just $5...
lockdown571 is offline
post #3 of 18 Old 11-04-2012, 04:05 PM - Thread Starter
jeff lam's Avatar
I think you are right, after doing more searching i didn't see much that was free that does what this one does. Although the remote part of the app looks sketchy. I wonder how functional it really is to control media center.
jeff lam is offline
post #4 of 18 Old 11-05-2012, 06:42 AM
Quoted: 66 Post(s)
Liked: 93
What do you mean "sketchy"? It works fine for me.
post #5 of 18 Old 11-05-2012, 07:17 AM
snappjay's Avatar
I'm using the Ceton app right now, but I'm crossing my fingers Microsoft will make the Smartglass app work with WMC (guide, remote, etc).
*deep sigh*
snappjay is offline
post #6 of 18 Old 11-05-2012, 08:45 AM
stuiekathome's Avatar
Try Remote Potato. I was going to purchase the Ceton app but decide to first give this a try. It works great for controlling WMC 7. And if your'e not happy with it, no harm no foul. PS: I have no skin in the game...
stuiekathome is offline
post #7 of 18 Old 11-05-2012, 10:07 PM
pmrowley's Avatar
Love the Ceton Companion app. I don't even bother with the MC interface most of the time. I just grab the coffee table tablet and queue up what I want to see. And never mind managing scheduled recordings and series recordings in the "standard" way. Ceton Companion makes it so simple, it's a wonder I ever put up with Tivo.
pmrowley is offline
post #8 of 18 Old 11-07-2012, 12:52 AM - Thread Starter
jeff lam's Avatar
Thanks for the input... Seems like Ceton did a great job with this app. I guess I'll be downloading it today...
jeff lam is offline
post #9 of 18 Old 11-07-2012, 09:14 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
Anyone tried Irule ?
irule can use both wifi and IR
Wifi seems most reliable especially not line of sight or with IR 3d glasses
Mfusick is offline
post #10 of 18 Old 11-07-2012, 09:31 AM
Quoted: 66 Post(s)
Liked: 93
I have. It works well, although there's a bit of learning curve. iRule can communicate directly to devices that receive IP commands, or it can trigger an iTach IR blaster to send IR commands.
post #11 of 18 Old 11-07-2012, 09:42 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
Which do you use?
Mfusick is offline
post #12 of 18 Old 11-07-2012, 02:26 PM
Quoted: 66 Post(s)
Liked: 93
Which do you use?
Both. If the device supports IP commands, I generally use those. Obviously many devices don't accept IP commands, so then I have to use the IR blaster.
post #13 of 18 Old 11-07-2012, 03:49 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
You think irule is better than other options ?
What's total cost you invested ?
Would you do it again or take another path if given choice start fresh ?
Mfusick is offline
post #14 of 18 Old 11-09-2012, 08:24 AM
Quoted: 66 Post(s)
Liked: 93
I'm not sure what other options there are for Android. I know that there's Roomie for iOS that uses the same iTach emitters that looks pretty nice. The cost was just iRule ($50 I think) and the iTach IP2IR ($90-$100). Honestly, it's definitely more of a luxury, and I use my Logitech Harmony much much more. Again, I would not recommend it as your primary remote. Real buttons are better smile.gif
post #15 of 18 Old 11-09-2012, 12:22 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
Which harmony you have ?
My issue is working through walls.
Mfusick is offline
post #16 of 18 Old 11-09-2012, 02:19 PM
Quoted: 66 Post(s)
Liked: 93
I have a 650 which is IR. You have a few options for walls.
1. Run an IR repeater through your wall
2. Get an RF remote like a Logitech 900
3. Try one of these, which turns any IR remote into an RF remote. Never tried it, but it has very good reviews on Amazon.
post #17 of 18 Old 11-10-2012, 06:56 PM - Thread Starter
jeff lam's Avatar
I set up the companion app. The remote is as expected... limited. I could not figure out how to get any kind of a number pad on the screen. If on the guide i don't want to page through 700 channels to find 746 which i watch a lot. Or when watching a show i often use the number multiplier to skip commercials such as 6-skip, which skips 3 minutes.
jeff lam is offline
post #18 of 18 Old 11-11-2012, 06:30 AM
Quoted: 66 Post(s)
Liked: 93
Did you try the "enter text" field at the bottom of the remote screen?
Reply Home Theater Computers
