Can't bitstream dts hd ma with HD 6850 - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 35 Old 11-05-2012, 06:37 PM
Shark007's Avatar
Quoted: 81 Post(s)
Liked: 73
Originally Posted by vladd View Post
Originally Posted by Shark007 View Post
it is only irrelevant to you and your chosen player.
Use WMP or Media Center instead on MPC and bitstreaming will work only when set to stereo.
To the OP: Test playback in a Windows player.
Not true. Out of the box, WMP/WMC will use the Microsoft DTV-DVD Audio Decoder which will not bitstream HD audio regardless of speaker configuration. If you change the decoder configuration using something like DSFilterTweaker, or associate a certain filetype (.bdmv) with LAV Splitter where WMP/WMC is forced to use LAV Audio decoder, you can bitstream HD audio and you do NOT need to set the speaker configuration to 2 channel. As I type this, I have Captain America BD playing in the background in WMP with full HD audio bitstreaming. My speaker configuration is set to 7.1 on my AMD HDMI Output.
OK, I stand corrected. I just did some quick testing and also had bitstreaming work without setting stereo. I'm sure this was nessasary in the past but improved drivers probably improved this also!
Use Shark007 Codecs and retain your sanity.
Shark007 is offline
post #32 of 35 Old 11-05-2012, 06:38 PM
Shark007's Avatar
Quoted: 81 Post(s)
Liked: 73
Originally Posted by sy2088 View Post
FIXED!
It turned out to be an EDID issue. I used a EDID override that tulli creasted and it worked. Thank you all for your help.
glad to hear it!
Shark007 is offline
post #33 of 35 Old 11-05-2012, 06:58 PM
vladd's Avatar
Liked: 39
I'm pretty sure I've always had mine set to 7.1, but not enough to say you're wrong on that.
FIXED!
Great! Probably a missing 8 channel LPCM descriptor. It was my first thought but your original post said you tried an EDID already.
vladd is offline
post #34 of 35 Old 11-05-2012, 07:51 PM
Andy_Steb's Avatar
Quoted: 31 Post(s)
Liked: 158
I can also can bitstream HD In Media Center or MPC with windows set to 5.1
Edit: sorry Shark, looks like you already went and tested again
Andy_Steb is offline
post #35 of 35 Old 11-06-2012, 11:41 AM
steelman1991's Avatar
Quoted: 211 Post(s)
Liked: 116
Nope never been a neccesity in my experience.
steelman1991 is offline
Reply Home Theater Computers
