HTPC and Directv - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-05-2012, 10:45 AM - Thread Starter
Dr_Mark's Avatar
Quoted: 129 Post(s)
Liked: 180
I used the assassins guide built my HTPC and it works great. Is there a solution for recording HD directv from an HD24 that anyone is using? I have seen so much conflicting info it would be nice is someone actually has one that works.
HD video with matching 5.1 signal.
Life is enjoyable with good quality
Dr_Mark is offline
post #2 of 5 Old 11-06-2012, 10:34 AM
lsilvest's Avatar
All you need is the Hauppage HD-PVR or Colossus and an IR blaster and you should be able to record from it with no problem.
lsilvest is offline
post #3 of 5 Old 11-06-2012, 10:40 AM
Beefcake's Avatar
Half right, the best choice is the HDPVR or Colossus (component/HDMI). The IR blaster is not needed as you can get network tuning going easily. This is my setup.....2 Colossus cards, 2 directv receivers, and network tuning.
Beefcake is offline
post #4 of 5 Old 11-06-2012, 11:02 AM
yanksno1's Avatar
Quoted: 21 Post(s)
What network tuning do you use?
yanksno1 is offline
post #5 of 5 Old 11-07-2012, 10:22 AM - Thread Starter
Dr_Mark's Avatar
Quoted: 129 Post(s)
Liked: 180
Is there any advantage between the 2 that would make one better than the other? Also is the software with it good enough to edit the commercials out?
Also there seem to be a couple of models
1212
1445
The HD-PVR2 is at BestBuy, that one any good?
The HD PVR doesnt use an HDMI cable, does it matter? Would prefer to use the HDMI for a single cable solution. Then I can make use of the 5.1 signal.
Dr_Mark is offline
Reply Home Theater Computers
