Mfusick's How to build an affordable 30TB Flexraid media server: Information Requested.! - Page 100 - AVS Forum | Home Theater Discussions And Reviews
 144Likes
post #2971 of 4731 Old 02-21-2014, 04:11 PM
techmattr's Avatar
Quoted: 71 Post(s)
Liked: 184
You can also copy the config file (which I believe defaults to the C: drive) and just paste it into the C: drive of your new install.
Stop your storage pool.
Copy config file offline somewhere.
Shutdown PC.
Install new Windows.
Install FlexRAID.
Stop FlexRAID.
Copy config file back into C:
Start FlexRAID.
Start pool.
techmattr is offline
post #2972 of 4731 Old 02-21-2014, 04:28 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Doing some cool real world tests I thought I would share:
Copy from my RAID0 scratch disk to a Seagate 7200.14 an ISO BR movie.
Little bastard actually finished faster than it started. I was impressed. Drive has a few movies on it, but otherwise pretty empty. It's about a year old. Was like a 3 minute process.
Next up, to my RAID 0 Scratch disk.
Mfusick is offline
post #2973 of 4731 Old 02-21-2014, 04:32 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Copied another ISO to a WD GREEN 3TB: (drive is 60% full)
I did not bother grabbing every percent of the copy cause I am getting lazy already tongue.gif but the process took roughly twice as long as the Seagate.
Mfusick is offline
post #2974 of 4731 Old 02-21-2014, 04:40 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
RAID 0:
I am pretty happy with it so far. It's working really good, and unlike the Seagate it does not get bogged down. The Seagate is fast most of the time but when you beat on it , it slows way down. It hates multiple reads and writes at the same time, whereas the RAID 0 does not seem to slow down that much with a few reads and writes going at the same time. Makes a much better scratch disk real world.
jbcain likes this.
Mfusick is offline
post #2975 of 4731 Old 02-22-2014, 06:54 AM
politby's Avatar
Quoted: 76 Post(s)
Liked: 77
Last eBay raid - not too bad:
  • Supermicro X7DWN+ motherboard $38
  • 2x Xeon E5440 $26
  • 16GB of 667MHz FB-DIMM RAM $40 (brand new)
  • IPMI card $15
So $119 for mostlly unused server grade stuff. Granted it is old skool :) but it's all VT-d supported so should be a nice ESXi machine.
And the brand new Supermicro SC826 with SAS expander backplane case cost me $246.
Can't wait to get this built. Unfortunately I am missing 4 motherboard standoffs required for the processor heatsinks so I am stuck until I can find some. Grrr.
Mfusick likes this.
politby is offline
post #2976 of 4731 Old 02-23-2014, 06:54 AM
politby's Avatar
Quoted: 76 Post(s)
Liked: 77
Like I said in the previous post, I plan to use this system for an ESXi environment.
The plan is to use a Dell Perc H310 flashed to IT mode to connect to the 12 hotswap bays via the SAS expander built into the backplane. I will also have 2 SSDs connected to motherboard ports, one reserved as datastore for the main media server VM (WSE2012R2) and the other as datastore for other VMs.
The WSE2012 VM will be running Flexraid.
What I haven't been able to figure out is how to deal with the Dell HBA. If I pass the card through to ESXi, do I then have to assign all 12 drives to one single VM or will I be able to assign, say, 8 drives to the WSE2012 VM for Flexraid and the remaining 4 to other VMs?
Because the backplane is a 2-port SAS expander, the hotswap bays all have to go via the Dell card so the whole idea with ESXi kinda falls if all 12 drives have to go to a single VM.
politby is offline
post #2977 of 4731 Old 02-23-2014, 07:35 AM
jbcain's Avatar
Liked: 64
Originally Posted by Mfusick View Post
RAID 0:
what bearing does copying from the same drive(s) to the same drive(s) prove?
jbcain is offline
post #2978 of 4731 Old 02-23-2014, 08:10 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
That's was actually from my SSD^. I used the SSD as the source.
But from and to the same drive would be important in something like winrar (which I do often) where the bottleneck seems to be my storage and not my 4.2ghz 4770k.
Or for ripping and ISO to mkv. I do that a lot too.
Mfusick is offline
post #2979 of 4731 Old 02-23-2014, 08:27 AM
jbcain's Avatar
Liked: 64
then why wasn't a drive letter present on the destination? while it's been a while, i thought a different destination drive always constituted a drive letter (+ sub folder) being displayed.
jbcain is offline
post #2980 of 4731 Old 02-23-2014, 08:56 PM
Andy_Steb's Avatar
Quoted: 31 Post(s)
Liked: 158
The card and all connected drives will go the WSE2012 VM
What kind of VM are you planning were it needs it own data drive? The virtual machines will all be connected by a 10 Gb/s virtual network, so you can use network shares. Or you can leave a drive out of the pool and connect to it using iSCSI
Mfusick likes this.
Andy_Steb is offline
post #2981 of 4731 Old 02-24-2014, 08:04 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Good question. I have no clue actually. I'll test it again tonight when I get home and try to do it on top of "my computer" screen see if I can make it make sense. I never paid attention. I am pretty sure I just copied from my 256GB SSD to my RAID0 scratch disk (the same I did for all the others) and vice versa. My thinking was the SSD should allow the HDD's to show what they can do, but actually in the situation of from the RAID0 to the SSD the SSD write speed seems to be the limiting factor. Either way a HDD scratch disk besting a 256GB SSD seems plenty fast enough. Winrar is so much faster! So is MakMKV on ISO's.
I started keeping a collection of ISO's since they allow easily for the menu and special features and also since they are the best option I have found for 3D. The trouble is that it creates duplicates of the same movie, since I have an MKV movie only and then a FULL ISO in a another library. My front end shows both, but it's hard to tell which is which sometimes. Anyone have a good solution or suggestion for that ? Anyone run into the same problem ?
The best I can come up with is to create a profile for ISO and 3D and only include those libraries. Then create another profile excluding them, so if I want or don't want them I just log on with the applicable profile. It's not at all ideal, but I guess it's better than nothing. 90% of the time I don't bother with 3D or ISO, but when I want to do it- I want to do it easily.
Mfusick is offline
post #2982 of 4731 Old 02-24-2014, 08:18 AM
politby's Avatar
Quoted: 76 Post(s)
Liked: 77
Thanks. Come to think of it any other VMs I run can most likely make do with network shares. They will just be for tinkering anyway.
Mfusick likes this.
politby is offline
post #2983 of 4731 Old 02-24-2014, 08:25 AM
mark_anderson_u's Avatar
Quoted: 43 Post(s)
Liked: 42
Most media libraries show the file type or icon for the file type
I have separate lib for ISO and MKV though
mark_anderson_u is offline
post #2984 of 4731 Old 02-25-2014, 11:42 AM
leebo's Avatar
Quoted: 525 Post(s)
Liked: 293
Originally Posted by amarshonarbangla View Post
Bookmarked the post. Excellent guide. It'll come in handy when I get my M1015. One question however. For the last step after the flashing is done, is it necessary to boot into the USB? I can just boot into Windows right?
When you have some "spare" time (I'm certain you have tons 🚼), if you can edit your opening post, maybe you can add some links to relevant posts in this thread? Like your guide on flashing that IBM card (post 736).
I'm reading through this thread, but it's difficult keeping track of the relevant stuff, especially when a "discussion" starts and goes on for pages. Things like disagreements on hard drive speeds that, a year later, may not even be relevant anymore!
I don't know how many people have the time (like I do) or patience to read every page, wading through all the other stuff. The title of this thread claims this to be a guide. It would be great if someone could come here and easily find the relevant info.
There is actually a sticky with a title, something to the effect of, "How to build a media server", that I had started to read, but the first several pages are nothing more than a bunch of guys discussing what a great idea that was for a guide! I mean, I think I got to page four or five, and still no info on building a server!
Your guide to flagging that IBM are was great. I'm not sure I will ever need it, but I had to copy that post to my Evernote be sure I know I will never find it again. These threads sometimes become a haystack!
736
Sent from my generic not my computer device.
leebo is offline
post #2985 of 4731 Old 02-25-2014, 12:31 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
736
Mfusick is offline
post #2986 of 4731 Old 02-27-2014, 11:35 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
My project today is to finish a full performance build for a friend today:
I have been working hard the last couple weeks decided to stay home today and take the day off work biggrin.gif
Quickett likes this.
Mfusick is offline
post #2987 of 4731 Old 02-27-2014, 12:10 PM
wiley165's Avatar
Location: State of Rhode Island and Providence Plantations
Quoted: 61 Post(s)
Liked: 98
wiley165 is offline
post #2988 of 4731 Old 02-27-2014, 01:53 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Anyone know how to fix the pictures on W7 x64 so they show thumnails again ?
I had Picasa installed and it seems to have broken this upon uninstall. mad.gif
Mfusick is offline
post #2989 of 4731 Old 02-27-2014, 02:22 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Some pics:
Build Pile: Grandia project:
Grandia front:
Grandia Front
[IMG ALT=""]http://www.avsforum.com/content/type/61/id/383571/width/1000/height/1000 Grandia Empty:
Silversone GD Build pile:
Intel CPU fan:
back of the Grandia
Drive tray:
Drives Installed:
Drives to be installed:
CPU:
Mobo
PSU
GPU installed:
Had to use OCZ plate on Samsung because the 840 PRO did not come with it.
MILO case:
Back of MILO build:
Milo front
Milo Emtpty
Milo top
Boneyard behind treadmill about to get some more boxes:
The Grandia project is a full performance build for a friend. The MILO project is also a build for a friend, but I used some left over stuff I had to make it ultra cheap. I sold it to a buddy for $230, which I must say is a pretty good deal for a full build HTPC set up and configured, with SSD and Silverstone case.
It's older stuff, G630 pentium from my original Flexraid server, with the H61 mobo and a single 4GB stick of DDR1600. I used a total crap 400 watt PSU I took out of a case that came with PSU and only cost $29 for the case and the PSU!!! I am sure it's total **** but I doubt he cares. Surprisingly it's not loud at all. Who knows.. the little bastard might out last my $200 PSU in my desktop... tongue.gif
Mfusick is offline
post #2990 of 4731 Old 02-27-2014, 05:34 PM
Quoted: 43 Post(s)
Liked: 42
Go into folder / view options and uncheck "Never Show thumbnails"
post #2991 of 4731 Old 02-27-2014, 05:38 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
You are talking about this:
Mfusick is offline
post #2992 of 4731 Old 02-27-2014, 05:55 PM
sebberry's Avatar
Quoted: 26 Post(s)
Liked: 30
Ok, I'm looking at maybe buying Flexraid, but I'm not sure where to turn from here.
I want the ability to add a drive and have it automatically added to the storage pool
I'd like some sort of redundancy - if a drive dies I'd like to be able to easily rebuild the data on it
I'd like to get away from mirroring drives for redundancy. It's a waste of drives.
Performance isn't a big concern. I have one computer I use to fiddle with my media on and copy it to the server. Only one PC playing back content at any one time.
I'm thinking Unlimited T RAID ($99) but it looks like Combo (Data Protection + Storage Pooling) for $59 might work well for what I need.
Any thoughts?
PS, I'd like to be able to set up the storage pool without deleting any data from the drives.
sebberry is offline
post #2993 of 4731 Old 02-27-2014, 06:05 PM
chrapladm's Avatar
Quoted: 827 Post(s)
Liked: 287
Mfusick what type of price was the Grandia setup?
I hate not having enough money to have 2 computer builds. I would like to have a small server build with maybe 10TB of room and a performance machine I can play games on. Which would also be used as a movie browser utilizing the server. Love seeing these builds though. Just takes me a while to try and find similar parts. I was going to do the Ebay server setups but shipping was too dear to Australia. SO it is what it is for now.
chrapladm is online now
post #2994 of 4731 Old 02-27-2014, 06:24 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Roughly from top of my head I'd guess:
Grandia GD08 $120
4670k $179
Asrock Mobo $109
Seagate 4TB $155 each
Samsung PRO SSD $120
RAM $80
PSU $70
BR READER $60
GPU Card $150
or something to that effect on sale.. YMMV. I'm just guessing. Add in the windows licenses and other software registrations too. It's definitely over $1000. Even with good prices and sales.
Mfusick is offline
post #2995 of 4731 Old 02-27-2014, 06:25 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Any thoughts?
FLEXRAID will do what you want.
Do you want T raid or RAID F ? I am using RAID F or what you would traditionally call "flexraid" It's older than T raid. T raid is transparent, F raid is snapshot. Different animals, but both are good.
Mfusick is offline
post #2996 of 4731 Old 02-27-2014, 06:32 PM
Andy_Steb's Avatar
Quoted: 31 Post(s)
Liked: 158
Try using the Windows Disk Cleanup tool to clear the thumbnail cache
post #2997 of 4731 Old 02-27-2014, 06:42 PM
sebberry's Avatar
Quoted: 26 Post(s)
Liked: 30
So the $59 combo sounds like the one then if I want RAID-F
Am I correct that snapshot is basically just delaying the parity calculations until a scheduled time vs on the fly as soon as data changes?
sebberry is offline
post #2998 of 4731 Old 02-27-2014, 06:53 PM
A9X-308's Avatar
Quoted: 1285 Post(s)
Liked: 954
Get on to www.staticice.com.au or www.msy.com.au for good prices in Australia. Rackmount server cases are quite expensive here depending on the number of drives you want, so went s different route. Having a rack cabinet in the garage with lots of space, I picked up an Antec 900 secondhand for $30 and added 3 5 space Norco frames for a total of 16 drives (SSD velcro'd inside). I also have 2 self contained 5 drive chassis' I'll place inside the rack beside the Antec for 26 drives. Not as neat, but total case cost was under $A150.
If you only want 10TB, then you only need 3 x 4TB drives so lots of cases will handle that. Getting above 12 drives becomes expensive but if that's enough, lots of cases will work as server cases with a couple of 5.25 to 3.5 adapters.
A9X-308 is offline
post #2999 of 4731 Old 02-27-2014, 08:12 PM
dfkimbro's Avatar
Quoted: 127 Post(s)
Liked: 84
Two options...if you have an icon at the top right, click it and it scrolls through file view options. Alternatively type "ALT", then "v" to get the view menu and select "large icons" or "tiles".
Is that what you were looking for?
Well, Duncan, he's just this guy, you know?
dfkimbro is offline
post #3000 of 4731 Old 02-28-2014, 10:49 AM
GCS
GCS's Avatar
Quoted: 49 Post(s)
Liked: 32
Mfusick. Here ya go http://www.frys.com/product/7057131?
4TB Hitachi 7200RPM drive $149
Mfusick likes this.
XBL Gamertag - blowfish7494
"Pull up your big boy pants and deal with it" - The Wife!
"Put on your man suit and fake it" - The Wife
GCS is offline
Reply Home Theater Computers
Flexraid , Intel Core I5 4670k 3 4ghz Lga 1150 Quad Core Desktop Processor , Intel Core I3 4130 3 4 3 Fclga 1150 Processor Bx80646i34130 , Asrock , Asrock Z87m Extreme4 Lga1150 Intel Z87 Chipset Ddr3 Quad Crossfirex Quad Sli Sata3 Usb3 0 Microatx M , Asus , Asus Us , Asus Computer , Asus Components , Norco , Asus Computer International Direct , Flexraid Raid F , Seagate , Seagate Hard Drives , Seagate Freeagent Theater 1080p Hd Media Player Stcea201 Rk , Hitachi , Dell , Windows 7 Vista Xp Media Center Mce Pc Remote Control And Infrared Receiver , Hp Oem Window Media Center Mce Pc Remote Control And Infrared Receiver For Windows7 Vista Xp Home Pr , Intel , Intel Core I5 3570 3 4 Ghz Processor , Intel Pentium G2020 2 9ghz Lga 1155 Dual Core Desktop Processor , Intel Pentium G3220 3 0ghz Lga 1150 Dual Core Desktop Processor , Amd , Amd A10 6700 Richland 4 2ghz Socket Fm2 65w Quad Core Desktop Processor Amd Radeon Hd Ad6700okhlbox , Amd A6 5400k 3 6ghz Socket Fm2 Dual Core Desktop Processor , Amd A8 5600k 3 6ghz Socket Fm2 Quad Core Desk
