Mfusick's How to build an affordable 30TB Flexraid media server: Information Requested.! - Page 125 - AVS Forum | Home Theater Discussions And Reviews
 144Likes
post #3721 of 4731 Old 07-19-2014, 10:53 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Originally Posted by rc05 View Post
Of course it'll be populated
But if you wanted to turn a case into a JBOD case, you can get something like this: http://www.servethehome.com/supermic...sis-made-easy/
They have breakout cables to connect non-Supermicro power buttons and LEDs too.
this is the route I think I will take. I'm just trying to find a cheaper dummie case that has backplanes. I don't want to run sata wires.
Mfusick is offline
post #3722 of 4731 Old 07-19-2014, 11:06 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
http://www.newegg.com/Product/Produc...82E16811147164
This would be perfect except I question if using sata plugs and power cables with splitters is worth the cost savings?
Is there something like a NORCO 4020 or 4224 that's value oriented? I like the idea of SAS8087 and backplanes to make things easy.
EDIT:
I guess it's this: http://www.newegg.com/Product/Produc...82E16811219024
Mfusick is offline
post #3723 of 4731 Old 07-19-2014, 01:06 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
On second thought I'm thinking I should just wait for a 15% off coupon at newegg and free shipping and bit the bullet and get a second 4220.
Mfusick is offline
post #3724 of 4731 Old 07-22-2014, 02:59 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
http://www.anandtech.com/show/8273/w...d-pro-versions
Well done WD! WD pro @ 7200rpm and 5 and 6TB sizes launching. I like it.
Mfusick is offline
post #3725 of 4731 Old 07-22-2014, 03:07 PM
rc05's Avatar
Quoted: 152 Post(s)
Liked: 87
Did you look at those prices though? I think they're too high for you
rc05 is offline
post #3726 of 4731 Old 07-22-2014, 03:15 PM
techmattr's Avatar
Quoted: 71 Post(s)
Liked: 184
I don't get the drive limitations by WD for NAS systems.... 1- 8 bay and 8 - 16 bay.... doesn't make any sense to me.
Mfusick likes this.
techmattr is offline
post #3727 of 4731 Old 07-22-2014, 04:19 PM
Ken.F's Avatar
Quoted: 1724 Post(s)
Liked: 1558
They claim it's a vibration issue. The more drives you have in the cage the more things shake around. After saying it, I think I'll go set my 9 desktop HDDs to spin down when not in use.
Ken.F is online now
post #3728 of 4731 Old 07-22-2014, 04:45 PM
Ken.F's Avatar
Liked: 1558
Over the weekend I dumped WHS 2011 and installed Win7 Pro on my server. I didn't do squat to back up FlexRAID since I planned on re-installing everything from scratch. Before the OS swap I stopped the pool, told FlexRAID to not start the pool at startup, then assigned the original drive letters back to my PPU and DRU drives. I did not format the OS drive, I just booted from the Win7 installation CD and went on with the install. After getting Win7 installed I changed all the drive letters back to what they were supposed to be since they got mixed up during the Win7 installation. Having a hard copy of my disc inventory sure came in handy. I downloaded FlexRAID again and ran the install. I had to load the driver from the command prompt again, but to my surprise my config file was still on the FlexRAID desktop. I opened up the drive manager and it showed my old FlexRAID pool with all the drives marked as missing, and all my drives with drive letters in the section below that. All I had to do was swap each drive out without doing a restore! My FlexRAID pool was up and running again exactly as it was before. It even had my shares and e-mail alerts set up. The only thing I could think of was the WHS 2011 files are still on the OS drive in a Windows.old directory. It must have checked that folder for a previous installation and copied all the settings.
I did screw up one thing. I forgot to disable the recycle bin on the drives before swapping them back into the pool. Is this going to hurt anything? Should I assign the drive letters again and disable the recycle bin on each one, then add them all back?
Mfusick likes this.
Ken.F is online now
post #3729 of 4731 Old 07-22-2014, 06:28 PM
Gronnie's Avatar
Quoted: 32 Post(s)
Liked: 30
Your FlexRAID config info is stored on your primary PPU I believe.
Mfusick likes this.
Gronnie is offline
post #3730 of 4731 Old 07-23-2014, 02:21 AM
Ken.F's Avatar
Liked: 1558
Interesting.
Ken.F is online now
post #3731 of 4731 Old 07-23-2014, 05:42 AM
pm240sx's Avatar
I also never disabled the recycle bin. I've never had an issue but if someone else knows better i'd like to know also.
HTPC are awesome get one today!
pm240sx is offline
post #3732 of 4731 Old 07-23-2014, 07:10 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
The FlexRAID recycle bin option is specific to Snapshot RAID and does not have an undelete feature as you would expect.
Do not delete anything you have not backed up unless you are sure you want it gone.
It might be safer to delete the configuration, regain control of your drives, and handle the duplicated data as appropriate; the FlexRAID recycle bin is not related to your OS recycle bin, which FlexRAID disables.
Essentially, once you delete something from the pool, it is gone forever.
The disable of the windows recycle bin is two fold I believe:
First, disable because flexraid does it differently with the pool.
Second, Delete anything so it's not there forever and can't be deleted later or gets duplicated. If using the FlexRAID storage pooling feature with the recycle bin feature turned on, your ONLY other risk are edits (changing the file’s content) as renames, moves, and deletes won’t be an issue.
Mfusick is offline
post #3733 of 4731 Old 07-23-2014, 07:11 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
I've done it both ways. But I think the problem is when your recycle bin is full and not empty.
Mfusick is offline
post #3734 of 4731 Old 07-23-2014, 07:24 AM
techmattr's Avatar
Quoted: 71 Post(s)
Liked: 184
That's stupid. What enclosure doesn't have anti-vibration mounts? If that small of a vibration had any impact then 1 drive would have issues with any server grade fan.....
The default FlexRAID config:
C:\FlexRAID-Config.db
You can make a backup through the UI and it will also be stored on root c: by default.
Mfusick likes this.
post #3735 of 4731 Old 07-23-2014, 10:09 AM
Ken.F's Avatar
Liked: 1558
"The updated firmware (NASware 3.0) puts in some features related to vibration compensation, which allows the Red drives to now be used in 1 - 8 bay desktop NAS systems (earlier versions were officially sanctioned only for 1 - 5 bay units)."
Maybe that doesn't mean what I think it means. I have 3 cages mounted side-by-side in my server. Each cage holds 5 drives. Does that count as a 15 bay unit or three separate 5 bay units?
Ken.F is online now
post #3736 of 4731 Old 07-23-2014, 10:12 AM
Ken.F's Avatar
Liked: 1558
Thanks. The FlexRAID installer must have found the original configuration in the Windows.old C:\ directory then.
Edit: The original config file and some other copies of the log that I had saved were left in the root C:\.
Ken.F is online now
post #3737 of 4731 Old 07-23-2014, 01:20 PM
Gronnie's Avatar
Quoted: 32 Post(s)
Liked: 30
Right, but you can restore an array without the DB file from the C drive I am pretty sure.
Gronnie is offline
post #3738 of 4731 Old 07-23-2014, 02:08 PM
techmattr's Avatar
Quoted: 71 Post(s)
Liked: 184
I'm reading that the same way you are.... I just don't get it. It's BS marketing no doubt. We have SANs with hundreds of HDDs packed into half racks. The damn rack feels like a .... "rabbit" it vibrates so much. Not from the hard drives but from the cooling that's in the same isle. Those HDDs don't have any shorter lifespan than any other we have. Whatever. The Reds are still my personal favorites. I wonder if I need to RMA one if they'll ask me how many drives I had in the enclosure. lol It's the only one I swear!
Yeah I'm pretty sure I've read some threads on how to restore without the config DB.... it makes life easier to have it though. I copy mine to a backup location weekly and actually create a backup a couple months through the UI.
post #3739 of 4731 Old 07-23-2014, 02:16 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
The artificial marketing limit is for the pussified fools that like to follow the rules and actually will without questioning them very much; that way WD can make people buy the more expensive full blown enterprise drives for full rack servers, and if you only have 8 then you can just pay a little extra with the "PRO". Lol.
Mfusick is offline
post #3740 of 4731 Old 07-23-2014, 05:39 PM
htpcforever's Avatar
Quoted: 493 Post(s)
Liked: 191
Don't hold back, tell us how you really feel.
junglism likes this.
htpcforever is offline
post #3741 of 4731 Old 07-24-2014, 01:56 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
lol
PRO is good for 8 drives. Non PRO RED is only 4 or less. But the expensive enterprise drives of coarse are for more
I like how Techmattr explained it: "I swear it was only the one drive!"
FFS ... WD. Don't insult us with this nonsense. Other than this nonsense I am please to see the WD RED PRO lineup. Looks good. 7200rpm and 4TB is something I want. Hopefully street prices are competitive somewhat with Hitachi and Seagate. 5 Year warranty is kick ass, I'd pay a little more for that.
Mfusick is offline
post #3742 of 4731 Old 07-25-2014, 05:32 AM
Quoted: 493 Post(s)
Liked: 191
I am happy larger HDDs are coming out, but since I am using a dual parity, SnapRAID solution, if I replace one 4TB drive with a larger drive, I need to replace THREE of them! So I am waiting for the eight TB HDDs.
post #3743 of 4731 Old 07-25-2014, 10:47 AM
EricN's Avatar
Quoted: 154 Post(s)
Liked: 240
Vibration and disk performance: it's not fan and motor hum that is the issue, it's the higher frequencies that aren't damped by the rubber mounts.
http://dtrace.org/blogs/brendan/2008...-disk-latency/
tl;dr: A Sun Microsystem storage engineer demonstrates how to kill a hard drive's throughput simply by yelling at it. It's relevant to HTPCers with storage in proximity to their theaters/tvs/speakers/etc or to anyone with high-density storage.
If they are typical semi-open bays, then it will "count as a 15 bay unit ". There's not enough isolation to matter.
Mfusick and |Tch0rT| like this.
EricN is offline
post #3744 of 4731 Old 07-25-2014, 11:08 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
That's actually a really interesting video ^ Thanks for sharing it.
Mfusick is offline
post #3745 of 4731 Old 07-25-2014, 11:22 AM
Ken.F's Avatar
Liked: 1558
I only yell at it like that after something goes wrong, not before.
Mfusick, |Tch0rT| and Dark_Slayer like this.
Ken.F is online now
post #3746 of 4731 Old 07-25-2014, 05:36 PM
|Tch0rT|'s Avatar
Quoted: 186 Post(s)
Liked: 130
I guess I should probably move my server out of the stereo rack and into the basement then. Been thinking about it for a while now.
My Home Theater/Video Gaming/HTPC/2 Channel rig (Mitsubishi, MartinLogan, Marantz, DIYMA, and others)
|Tch0rT| is offline
post #3747 of 4731 Old 07-25-2014, 06:21 PM
Ken.F's Avatar
Liked: 1558
I decided to go back and disable the Windows recycle bin for all of my drives. It was pretty easy. I just stopped the pool and assigned the original drive letters back to each HDD in Windows Disk Management. I then turned off the Windows recycle bin for each drive and deleted the recycle bin folder on each drive. I went back into FlexRAID and opened drive manager and swapped out the missing drives (do not restore just swap out the drives) to put them back in the pool, then started the pool. The whole procedure only took about half an hour.
Ken.F is online now
post #3748 of 4731 Old 07-28-2014, 11:18 AM
leebo's Avatar
Quoted: 541 Post(s)
Liked: 308
Here's a link I came across after watching the above video.
I call it, "Mfusick's Heaven". Of course, that's assuming he's a good boy.
leebo is offline
post #3749 of 4731 Old 07-28-2014, 03:02 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
HAHA I love it. I love overkill! Even if it's 5 year old technology.
The cool think about excess is even 5 years later you are still cool rocking your socket 775 machine with video cards that don't do modern directX or have HDMI. Even if people question you ... you can still point just below your belt buckle and exclaim "suck it" haha...
There is no point going through life scared...
Mfusick is offline
post #3750 of 4731 Old 07-30-2014, 12:43 AM
leebo's Avatar
Quoted: 541 Post(s)
Liked: 308
Another HD deal, but only for new customers:
http://www.rakuten.com/prod/seagate-...fk5C0o3CPc2pZg
Rakuten (formerly Buy.com) has the Seagate Expansion 4TB USB 3.0 External Desktop Drive (STBV4000100) for a low $99.95 Free Shipping after Coupon Code: "NEWBIE" (Exp Soon).
leebo is offline
Reply Home Theater Computers
Flexraid , Intel Core I5 4670k 3 4ghz Lga 1150 Quad Core Desktop Processor , Intel Core I3 4130 3 4 3 Fclga 1150 Processor Bx80646i34130 , Asrock , Asrock Z87m Extreme4 Lga1150 Intel Z87 Chipset Ddr3 Quad Crossfirex Quad Sli Sata3 Usb3 0 Microatx M , Asus , Asus Us , Asus Computer , Asus Components , Norco , Asus Computer International Direct , Flexraid Raid F , Seagate , Seagate Hard Drives , Seagate Freeagent Theater 1080p Hd Media Player Stcea201 Rk , Hitachi , Dell , Windows 7 Vista Xp Media Center Mce Pc Remote Control And Infrared Receiver , Hp Oem Window Media Center Mce Pc Remote Control And Infrared Receiver For Windows7 Vista Xp Home Pr , Intel , Intel Core I5 3570 3 4 Ghz Processor , Intel Pentium G2020 2 9ghz Lga 1155 Dual Core Desktop Processor , Intel Pentium G3220 3 0ghz Lga 1150 Dual Core Desktop Processor , Amd , Amd A10 6700 Richland 4 2ghz Socket Fm2 65w Quad Core Desktop Processor Amd Radeon Hd Ad6700okhlbox , Amd A6 5400k 3 6ghz Socket Fm2 Dual Core Desktop Processor , Amd A8 5600k 3 6ghz Socket Fm2 Quad Core Desk
