Mfusick's How to build an affordable 30TB Flexraid media server: Information Requested.! - Page 129 - AVS Forum
post #3841 of 3842 Old Yesterday, 10:44 PM
zacjones's Avatar
I'm just getting started setting up F-Raid in my HTPC / Server. I'm trying to install an M1015 I bought pre-flashed to 9211-8i IT mode, and am having difficulty bypassing it so that I can load my OS from a mobo SATA connector. The 9211-8i wants to boot from a disk connected to it, and I can't seem to get around it by adjusting any settings in the LSI bios.
I had planned on using the 9211-8i just for the array, and run my OS off the motherboard SATA connector. Should I be making an effort to keep all my data and parity drives on the 9211-8i and use the mobo SATA for my OS? Or should I just go with the flow and hook up my OS drive to the 9211-8i and not be too concerned about where the rest of the drives are getting plugged in?
I also have another 9211-8i flashed to IT mode (I bought a pair of them for further expansion) that I could use but it would eliminate my last PCI-E slot which I'm currently using for USB 3.0.
The 9211-8i's are flashed to P19, the latest version. Is there a simple way that I could remove the boot rom from one of the cards? Or is it basically going through the whole "flash to 9211-8i IT" process again? Or even better, what's the trick to the settings in the LSI bios to get it to not want to load an OS from the card?
zacjones is offline
post #3842 of 3842 Old Today, 09:12 AM
Andy_Steb's Avatar
Quoted: 20 Post(s)
Liked: 152
Most people that flash M1015s will flash it without a boot rom.
You need to goto your motherboard Bios to make the changes. Some motherboards will have an option to ignore/bypass option roms. You will definitely have an option of which hard drive to boot from.
Andy_Steb is offline
Reply Home Theater Computers
Flexraid , Intel Core I5 4670k 3 4ghz Lga 1150 Quad Core Desktop Processor , Intel Core I3 4130 3 4 3 Fclga 1150 Processor Bx80646i34130 , Asrock , Asrock Z87m Extreme4 Lga1150 Intel Z87 Chipset Ddr3 Quad Crossfirex Quad Sli Sata3 Usb3 0 Microatx M , Asus , Asus Us , Asus Computer , Asus Components , Norco , Asus Computer International Direct , Flexraid Raid F , Seagate , Seagate Hard Drives , Seagate Freeagent Theater 1080p Hd Media Player Stcea201 Rk , Hitachi , Dell , Windows 7 Vista Xp Media Center Mce Pc Remote Control And Infrared Receiver , Hp Oem Window Media Center Mce Pc Remote Control And Infrared Receiver For Windows7 Vista Xp Home Pr , Intel , Intel Core I5 3570 3 4 Ghz Processor , Intel Pentium G2020 2 9ghz Lga 1155 Dual Core Desktop Processor , Intel Pentium G3220 3 0ghz Lga 1150 Dual Core Desktop Processor , Amd , Amd A10 6700 Richland 4 2ghz Socket Fm2 65w Quad Core Desktop Processor Amd Radeon Hd Ad6700okhlbox , Amd A6 5400k 3 6ghz Socket Fm2 Dual Core Desktop Processor , Amd A8 5600k 3 6ghz Socket Fm2 Quad Core Desk
Gear in this thread - 1080p by PriceGrabber.com
