Mfusick's How to build an affordable 30TB Flexraid media server: Information Requested.! - Page 137 - AVS Forum
post #4081 of 4081 Old Today, 01:11 AM
ajhieb's Avatar
Quoted: 470 Post(s)
Liked: 448
Originally Posted by DotJun View Post
I see. What is the cheapest sas expander that doesn't need to be modified to use? The only ones I've seen are 500 and up. That's why I thought most people used SATA port multipliers instead.
It depends on what you're looking for. If you're looking for a new expander in a shiny retail box, it's going to be pretty expensive. Most people here are going for used equipment because there is a lot of value to be had. It also depends on if you want to just get an expander, or if you're looking for an entire solution including chassis.
If you tell us what you're trying to accomplish I can probably steer you in the right direction.
RAID protection is only for failed drives. That's it. It's no replacement for a proper backup.
ajhieb is online now
Reply Home Theater Computers
Flexraid , Intel Core I5 4670k 3 4ghz Lga 1150 Quad Core Desktop Processor , Intel Core I3 4130 3 4 3 Fclga 1150 Processor Bx80646i34130 , Asrock , Asrock Z87m Extreme4 Lga1150 Intel Z87 Chipset Ddr3 Quad Crossfirex Quad Sli Sata3 Usb3 0 Microatx M , Asus , Asus Us , Asus Computer , Asus Components , Norco , Asus Computer International Direct , Flexraid Raid F , Seagate , Seagate Hard Drives , Seagate Freeagent Theater 1080p Hd Media Player Stcea201 Rk , Hitachi , Dell , Windows 7 Vista Xp Media Center Mce Pc Remote Control And Infrared Receiver , Hp Oem Window Media Center Mce Pc Remote Control And Infrared Receiver For Windows7 Vista Xp Home Pr , Intel , Intel Core I5 3570 3 4 Ghz Processor , Intel Pentium G2020 2 9ghz Lga 1155 Dual Core Desktop Processor , Intel Pentium G3220 3 0ghz Lga 1150 Dual Core Desktop Processor , Amd , Amd A10 6700 Richland 4 2ghz Socket Fm2 65w Quad Core Desktop Processor Amd Radeon Hd Ad6700okhlbox , Amd A6 5400k 3 6ghz Socket Fm2 Dual Core Desktop Processor , Amd A8 5600k 3 6ghz Socket Fm2 Quad Core Desk
Gear in this thread - 1080p by PriceGrabber.com
