Mfusick's How to build an affordable 30TB Flexraid media server: Information Requested.! - Page 145 - AVS | Home Theater Discussions And Reviews
post #4321 of 4334 Old Yesterday, 12:36 AM
DotJun's Avatar
Quoted: 240 Post(s)
Liked: 68
Originally Posted by Ken.F View Post
Verify is a bit for bit verification of every file in the pool. I have 10 data drives with 30 TB on them so I guess 14 hours isn't too bad. I only do those once a month so it's not that inconvenient. An update will check for changes in the pool and will calculate parity just for the files that changed since the last update. That doesn't take very long unless you move a lot of data between updates. I have updates scheduled every night so it's usually pretty fast.
Ahhh ok. I'm trying out snapraid right now and it's pretty dang fast as far as the parity calcs go but the sync command that I run might be the same as the update command that you run. I'm not sure if snapraid has a verify/validate command so I guess we can't really compare them.
DotJun is offline
post #4322 of 4334 Old Yesterday, 12:56 AM
Quaraxkad's Avatar
Quoted: 23 Post(s)
Liked: 40
Snapraid sync is the same as FlexRAID update. Snapraid scrub -p 100 is the same as FlexRAID verify (both products can also do partial array verifies). Snapraid diff is the same as FlexRAID quick-validate. Snapraid has no analog to FlexRAID validate. Also note that the speed reports are not comparable, you may get a reading of 20MBps in FlexRAID and 500MBps in snapraid, when in reality they are both processing exactly the same data and will finish at the same time. FlexRAID essentially reports the weakest link, while Snapraid sums up the totals across all drives being read/written. The FlexRAID method is a little more "sane" as far as a relevant number goes because it's equally valid no matter how many drives are in the array. The snapraid number is artificially inflated by simply adding new drives, even when the resulting process ends up taking longer than it did with fewer drives.
ajhieb likes this.
Quaraxkad is online now
post #4323 of 4334 Old Yesterday, 08:48 AM
Ken.F's Avatar
Quoted: 345 Post(s)
Liked: 351
Big fat fail on today's validate. With the settings of Processes 8, I/O Buffer 50MB and Threads 8 it ran really smooth during verify yesterday, but during validate today all processor cores were pegged at 100%. Memory use was good during both verify and validate. I noticed the validate beginning to slow down at 54%. About an hour later it was only up to 56%. I hit pause it and let it sit for about a half hour but the processor use remained at 100% and the little spinning icon in the FlexRAID configuration never stopped. I hit abort and waited another half hour and still no change, processor still at 100%. Resource Monitor showed no disk activity whatsoever on any of the pool volumes.
Until I figure this out I'm going to cancel my validate schedule and run verify weekly. Time to go reboot the server.
Ken.F is offline
post #4324 of 4334 Old Yesterday, 09:08 AM
Quaraxkad's Avatar
Quoted: 23 Post(s)
Liked: 40
This sounds like what FlexRAID does when it encounters an unreadable file caused by bad sector. It's not graceful at all when this happens and can result in BSODs, freezing, or just never being able to end the process. Check Event Viewer for drive or controller related errors. Are you running StableBit, HDSentinel, or anything like that?
post #4325 of 4334 Old Yesterday, 10:07 AM
Ken.F's Avatar
Quoted: 345 Post(s)
Liked: 351
No, not running StableBit or anything like it. I find it odd that yesterday's verify passed with "all bits match" and today a validate decided to hang.
Checked the Event Viewer and didn't see any drive or controller errors. I did find it spit out a low memory warning at 5:27AM. I was still asleep at that time so I never saw the warning. When I checked Resource Monitor this morning the memory use was below 6GB and the validate appeared to be running OK other than all of the processor cores were at 100%.
5:27:01 - "Windows successfully diagnosed a low virtual memory condition. The following programs consumed the most virtual memory: svchost.exe (736) consumed 3473154048 bytes, ehrecvr.exe (2712) consumed 259993600 bytes, and ehshell.exe (10004) consumed 229203968 bytes."
That svchost.exe PID 736 is the same process that has been giving me memory trouble all along.
5:27:07 - "Application popup: Windows - Out of Virtual Memory : Your system is low on virtual memory. To ensure that Windows runs properly, increase the size of your virtual memory paging file. For more information, see Help."
My page file is manually set for 24072 MB (1.5x 16GB RAM) on a HDD not included in the pool. Should I let the system manage it? I'm afraid if I do that it will just keep expanding the page file until the disk fills up.
Between 10:42 and 10:52 last night I got 5 of these errors:
"The server was unable to allocate from the system nonpaged pool because the server reached the configured limit for nonpaged pool allocations."
FlexRAID wasn't even doing anything at that time.
Ken.F is offline
post #4326 of 4334 Old Yesterday, 01:42 PM
Quaraxkad's Avatar
Quoted: 23 Post(s)
Liked: 40
I would temporarily Disable all non-essential services that are running under that svchost process. Shown in your screenshot here: http://www.avsforum.com/forum/attach...5&d=1425084056. Most of those are optional and you'll never need them so they can't be permanently disabled anyway. You also have a *ton* of processes running that could likely be disabled on startup, I highly doubt you need half of what's running.
post #4327 of 4334 Old Yesterday, 03:12 PM - Thread Starter
Mfusick's Avatar
Quoted: 297 Post(s)
Liked: 1297
I feel for you Ken. This is about the point where I format the drive clean and start over. Thinking it will fix, then wait to see what I install that brings it back.
"Too much is almost enough. Anything in life worth doing is worth overdoing. Moderation is for cowards."
Mfusick is online now
post #4328 of 4334 Old Yesterday, 05:25 PM
Ken.F's Avatar
Quoted: 345 Post(s)
Liked: 351
Thank you for taking the time to look over all of the information and I appreciate the advice. The system is 100% rock-solid stable with plenty of resources to spare until FlexRAID starts running an operation. Do you really think FlexRAID running through 40GB of memory is caused by some extra services running in the background? Maybe it could make a difference but I just don't suspect that being the root of the problem.
BTW, the svchost.exe 736 doesn't even show up in Process Explorer when FlexRAID is idle.
No, I'm not going to format it and start over. But If I did, I know exactly which program to install that will bring the problem back. FlexRAID.
Thanks again to everyone for your help. I'm getting frustrated so I'm going to put this on the back burner for a while. I have update and verify running without any drama so I don't even need to run validate.
One last screenshot.
Name:	a much needed break.jpg
Ken.F is offline
post #4329 of 4334 Old Yesterday, 05:53 PM
Defcon's Avatar
Quoted: 59 Post(s)
Liked: 44
Out of the 2 setups below, which is advisable -
1. Flexraid with snapshot Raid-F
2. DrivePool, Scanner, snapraid + elucidiate gui
From what I read both are roughly equivalent, Flexraid is an all in one solution and does everything, with #2 you have to manage things yourself, but each of the them is very well regarded on its own. I don't like reading the various issues with Flexraid here esp since it will be running on older hardware (5 year old AMD).
Defcon is offline
post #4330 of 4334 Old Yesterday, 06:20 PM
Ken.F's Avatar
Quoted: 345 Post(s)
Liked: 351
Don't let my issues scare you away from trying FlexRAID. The problem that I'm having isn't typical.
You can try FlexRAID for 21 days for free. It won't do anything that changes a single bit of your data unless you tell it to.
http://www.flexraid.com/download-try-buy-raid-f/
Ken.F is offline
post #4331 of 4334 Old Yesterday, 07:30 PM
pclausen's Avatar
Quoted: 12 Post(s)
Liked: 24
Good luck Ken!
I had a verify fail just recently due to bad blocks on one of the DRUs. I forced failed the DRU in question and did a rebuild, using the "restore in place" option. Took 20 hours, but completed without any additional errors.
I will say it has been a mixed experience moving from hardware RAID6 on Areca controllers to software raid on LSI SAS controllers using tRAID, but overall I will say I sleep better at night than I did with my hardware Raid, especially when I was down one drive, let alone two! I have had RAID6 restores drop a 3rd disk doing rebuilds and only by some miracle was I able to bring back one of the first 2 failed disk members each time, to get a array back on line.
Some issues I have with tRAID that never occurred using hardware Raid:
  • Sometimes I have to click on a mapped drive several times before it becomes accessible (this would be from from a client machine trying to access the shared drive over the network)
  • Saving torrents directly onto a tRAID pool drive is not consistently reliable
  • Write speed is very poor compared to RAID6. The use of a landing disk has mostly remedied this issue, but if I copy more than the 128GB size of my SSD landing disk, things slow to a crawl
  • Boot time have increased a lot and Windows Disk Manager is barely able to deal with 50 physical drives, let alone another 48 virtual drives and the 2 pool drives I got. Hardware RAID isolated the OS from having to deal with all these individual drives
Those issues aside, I still prefer tRAID over hardware raid since I can mix and match DRU drive sizes and I can drop the array and still mount each DRU and access the data directly from the OS. Also, I never have issues with Media Browser clients being able to access my media and I got about a dozen scattered around the house.
pclausen is offline
post #4332 of 4334 Old Yesterday, 07:59 PM
DotJun's Avatar
Quoted: 240 Post(s)
Liked: 68
I let all the bad posts about flexraids validate/verify problems scare me into option 2. The cli really isn't bad. I started out doing elucidate but by the end of the week I prefered to just write my own bat files.
Originally Posted by pclausen View Post
Good luck Ken!
The only reason I left hardware for my media is because software allowed me to have more than two parity drives, otherwise I'd stick to the simplicity of hardware any day. Hardware raid always just worked for me. Never had any controller issues.
Are you running flexraid-f realtime mode or are you running transparent raid? I tried both last week and I prefer the latter as I couldn't figure out how to have more than one parity drive with the former.
DotJun is offline
post #4333 of 4334 Old Today, 02:25 AM
pclausen's Avatar
Quoted: 12 Post(s)
Liked: 24
Agreed. I had 2 RAID6 arrays, each consisting of 24 drives. One array all 1TB drives and the 2nd all 2TB drives. I ran this way for 6 years, but as mentioned in my previous post, I got real close to loosing the data on a couple of occasions, which is what drove me to software raid.
I'm running transparent raid. Both have a total of 24 members as before, each with 2 4TB PPUs and a mix of 1, 2 and 4TB DRUs.
pclausen is offline
post #4334 of 4334 Old Today, 08:31 AM
Quaraxkad's Avatar
Quoted: 23 Post(s)
Liked: 40
The PID changes every time a process launches. What you're looking for are the services that that instance is handling. The stability and available resources of the machine doesn't concern me, that's not your issue, but it's obvious that something is causing an issue and it's not the flexraid process itself. It's very possibly one of those services. And even if you've got tons of available resources, disabling all of those useless services and unnecessary startup processes is never a bad thing. You have over 100 processes running, that's kind of insane!
In Process Explorer, press Ctrl+T. It will re-organize the list into a tree and make it much more readable.
Scanner is advisable in either setup, FlexRAID does nothing to check drive health. Each of them have their own pros and cons. As suggested, try out both of them. But I wouldn't recommend Elucidate, it's old and I don't think it was ever fully completed.
Reply Home Theater Computers
Flexraid , Intel Core I5 4670k 3 4ghz Lga 1150 Quad Core Desktop Processor , Intel Core I3 4130 3 4 3 Fclga 1150 Processor Bx80646i34130 , Asrock , Asrock Z87m Extreme4 Lga1150 Intel Z87 Chipset Ddr3 Quad Crossfirex Quad Sli Sata3 Usb3 0 Microatx M , Asus , Asus Us , Asus Computer , Asus Components , Norco , Asus Computer International Direct , Flexraid Raid F , Seagate , Seagate Hard Drives , Seagate Freeagent Theater 1080p Hd Media Player Stcea201 Rk , Hitachi , Dell , Windows 7 Vista Xp Media Center Mce Pc Remote Control And Infrared Receiver , Hp Oem Window Media Center Mce Pc Remote Control And Infrared Receiver For Windows7 Vista Xp Home Pr , Intel , Intel Core I5 3570 3 4 Ghz Processor , Intel Pentium G2020 2 9ghz Lga 1155 Dual Core Desktop Processor , Intel Pentium G3220 3 0ghz Lga 1150 Dual Core Desktop Processor , Amd , Amd A10 6700 Richland 4 2ghz Socket Fm2 65w Quad Core Desktop Processor Amd Radeon Hd Ad6700okhlbox , Amd A6 5400k 3 6ghz Socket Fm2 Dual Core Desktop Processor , Amd A8 5600k 3 6ghz Socket Fm2 Quad Core Desk
Gear in this thread - 1080p by PriceGrabber.com
