Mfusick's How to build an affordable 30TB Flexraid media server: Information Requested.! - Page 148 - AVS Forum | Home Theater Discussions And Reviews
 144Likes
post #4411 of 4731 Old 03-26-2015, 09:12 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Originally Posted by smitbret View Post
I would actually echo a lot of what you just said (although with a milder tone). However, I won't go near a 3TB Seagate. There is too much evidence that they are just not suitable for server use (nearly 50% annual failure rate according to BackBlaze). The WD Blacks are greatly overpriced and the Greens offer nothing significant over a Seagate that is 40% faster. WD Reds have no better failure rate than consumer drives in Home Server use. I would suspect the Seagate NAS drives are the same.
Right now I am adding 3TB Toshiba drives in my server. Once the 4-6TB drives have been used long enough to get a reputation I will re-investigate then.
I do get a little nuts with the HDD reliability thing. To me it's a commodity, something you need, use, and throw out. I've never seen any evidence that supports anything other than crap luck matters the most with reliability, and generally speaking even crappy hard drives are reliable. So the real small differences between one and another on a big scale, don't even realistically transfer down to the end user. But saving $20+ a unit when you need to buy many- Heck yeah. That is noticed and felt and appreciated. The cool thing- when I do replace a drive it's usually with a cheaper one, or bigger one anyways because the tech advances pretty quick. So that cash I saved the first round, goes even farther in the second round.
That's just how I roll. I would change my ways if I got burned really bad, but so far it seems to work. I buy and own just about every brand of HDD too. Price mostly dictates what I buy.
Mfusick is offline
post #4412 of 4731 Old 03-26-2015, 12:38 PM
jhughy2010's Avatar
Quoted: 840 Post(s)
Liked: 275
Originally Posted by DotJun View Post
That's exactly what I do. Pool the data drives only and leave the parity drives alone. I also do drive mapping of all the drives on my os drive which itself is in a raid 1 configuration for speed + pretty much zero downtime in the event of failure.
Can you elaborate? Do you use FlexRAID? I'm still deciding on my final product for my server and so far software configuration is pretty confusing.
Correct me if I'm wrong but "pooling" doesn't remove the individual drives from "This PC" under "devices and drives" it just creates another drive under "devices and drives" where all the pooled drives are in one virtual drive?
This is so much different than hardware RAID and thus confusing. I would like a product that replicates hardware RAID but isn't hardware RAID... I know that is a lot to ask for. I just don't want to waist all my time managing the media would just prefer to swap out a dead drive every now and then.
jhughy2010 is offline
post #4413 of 4731 Old 03-26-2015, 12:53 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Pooling in FLEXRAID F does indeed remove the drives. They disappear and only the pool shows up after you install and configure flexriad-f.
You can access the individual drives via the control panel, or navigate or inspect what is on specific drives. You can also remove a drive from the pool and make it independent again. But the drives are otherwise removed from "windows" if that is what you are thinking.
jhughy2010 likes this.
Mfusick is offline
post #4414 of 4731 Old 03-26-2015, 02:59 PM
habe's Avatar
Quoted: 35 Post(s)
Finally got my IBM M1015 flashed and installed last night using Mfusick's instructions on page 140. Only thing I did different was to get the latest LSI 2118it.bin (P20) from LSI and replaced the one that came prepackaged which is a couple years old. I was unable to flash it with my AsRock Z87 Extreme4 so had to go to a friends house and use one of his older, non-uefi PC's to flash the card. Works great and I really like how the mini-SAS breakout cables cleaned up my bay!
Once I get a little more time I'll play around with fRaids Validate and Verify feature to see if I can get my problems sorted out. If not, SnapRaid here I come!
If I migrate to SnapRaid, is there any difference in overhead or function between FlexRaid or Drivepool? I already own fRaid so I can use that just for drive pooling. If there would be an advantage to DrivePool, I don't mind purchasing it.
Thanks, habe
habe is offline
post #4415 of 4731 Old 03-27-2015, 07:52 AM
wiley165's Avatar
Location: State of Rhode Island and Providence Plantations
Quoted: 61 Post(s)
Liked: 98
I posted on page 72 on how to go through he flash process on a newer mobo with UEFI.
This thread has taken on some serious life of it's own.
wiley165 is offline
post #4416 of 4731 Old 03-27-2015, 12:13 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Ok my BR#2 drive is indeed DOA. Won't show in my desktop hot swap either. So I do indeed have a busted Seapuppy. On the good news all my drives showed back up too. Looks like I am back on track- odd though how it was behaving.
Mfusick is offline
post #4417 of 4731 Old 03-27-2015, 01:38 PM
habe's Avatar
Quoted: 35 Post(s)
It would be nice if both sets of instructions could be stickied in this forum area since the use of these boards is so common or, if Mfusick could edit the first page and link to both sets of instructions???? Page 70 is pretty far back from 148 and although I've followed this thread daily, I didn't remember that post. Bummer!
habe
habe is offline
post #4418 of 4731 Old 03-27-2015, 01:41 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Sure I can edit the first post- just link me up or quote what you want me to add to it-
Mfusick is offline
post #4419 of 4731 Old 03-27-2015, 03:00 PM
wiley165's Avatar
Quoted: 61 Post(s)
Liked: 98
The only bad thing, is that my path was through trial and error, and I didn't make it through cleanly. On top of that, it's been over a year since I did the flash. I'm not sure what the 'clean' steps would be right now.
Maybe perhaps add a link to my post on Page 72 with something to reference UEFI boards.
wiley165 is offline
post #4420 of 4731 Old 03-27-2015, 03:45 PM
habe's Avatar
Quoted: 35 Post(s)
Cool!
Your non-UEFI instructions are on page 140 and Wileys on page 72.
If you want to add it, here is the link to LSI's website where you can get the latest P20 firmware. http://www.lsi.com/products/host-bus...s-9211-8i.aspx. The current package is - "9211_8i_Package_P20_IR_IT_Firmware_BIOS_for_MSDOS _Windows". Also, all of the UEFI stuff is on there too.
I used your instructions from page 140 except replaced the 2118it.bin that came with the SAS2008 package (the firmware included in the SAS2008 link is P16, from 2012) with the latest 2118it.bin firmware (P20) from LSi's website (worked fine).
Should save people time from having to search how-to-flash instructions in the future.
habe
habe is offline
post #4421 of 4731 Old 03-28-2015, 01:41 PM
Quaraxkad's Avatar
Quoted: 63 Post(s)
Liked: 52
Originally Posted by jhughy2010 View Post
Flexraid doesn't work like this though right? It pools the drives and does parity too?
No, this is exactly how FlexRAID works also. The difference is that SnapRAID does only parity (and fake read-only pools but that's another topic altogether), vs. FlexRAID that does both in one software package and has one configuration option that does both behind the scenes. But it's just an illusion, it's still vitally important that all users understand that pooling and parity are vastly different and wholly unrelated to each-other, regardless of whether you use FlexRAID, SnapRAID, disParity, DrivePool, whatever...
This is true only if you use Cruise Control mode. I always argue that Expert mode is the "correct" mode, and in that instance the configuration is far more similar to SnapRAID. It does not take over control of your drives, it does not change any hardware configurations, etc.
I highly recommend using only P19 or older. P20 has been known to cause multiple issues and is difficult to downgrade from. Maybe it'll be fixed if they do a P21.
I own both DrivePool and FlexRAID. I currently use FlexRAID for pooling but I have not yet even tested DrivePool. Both have free trial periods, so you can give them both a shot. I will say that FlexRAID pools have some issues with software that doesn't follow proper "etiquette" for opening and writing to files. FlexRAID is very strict in not allowing "proper" usage. I don't know if DrivePool is the same. For the time being, I'm sticking with FlexRAID pooling specifically for the virtual Recycle Bin. DrivePool is a much more "powerful" pooling solution aside from the lack of a virtual Recycle Bin, but I don't know that it's any faster.
Quaraxkad is offline
post #4422 of 4731 Old 03-28-2015, 05:04 PM
habe's Avatar
Quoted: 35 Post(s)
Read your reply and I googled up issues with the P20 firmware and sure enough......Great!! Just my luck that I didn't know about this before I flashed mine with P20. I saw where others said they were able to downgrade back to P19 so I'll give it a go when I have time.
Thanks for the info.
habe
habe is offline
post #4423 of 4731 Old 03-29-2015, 05:24 PM
habe's Avatar
Quoted: 35 Post(s)
habe
Quaraxkad, Thanks for the P20 firmware info. I was able to successfully re-flash (full flash process; no issues moving backwards from P20 to P19) my card using P19 firmware. I also figured out how to get it to work on my Asrock UEFI mobo so I eliminated the step of pulling the card out and traveling to my friends house for flashing.
Everything appears working and normal.
habe
habe is offline
post #4424 of 4731 Old 03-30-2015, 04:07 AM
DotJun's Avatar
Quoted: 574 Post(s)
Liked: 154
So you have three choices when you create a volume on your drive. You can select a drive letter, which is the most common thing to do. You can mount it to a folder or you can leave it unmounted.
I would prefer to just leave it unmounted but drivepool doesn't like that so I am forced to mount it to a folder. Flexraid has no problems with unmounted drives and in fact prefers you to use an unmounted raw drive for parity iirc.
DotJun is offline
post #4425 of 4731 Old 03-30-2015, 04:09 AM
DotJun's Avatar
Quoted: 574 Post(s)
Liked: 154
habe
I thought p20 was only a problem outside of windows? I have no problems with it in windows. So far at least. What is the supposed issue?
DotJun is offline
post #4426 of 4731 Old 03-30-2015, 08:16 AM
Quaraxkad's Avatar
Quoted: 63 Post(s)
Liked: 52
To clarify, RAID-F can not use unmounted volumes at all, but tRAID can. What was the issue with unmounted drives in Drivepool? That's supposed to work.
That's what I thought too, and it sounded like it only caused problems with SSDs on Linux, so I flashed to P20. Then I started getting tons of ATA CRC errors (SMART 199) on every drive. Since flashing back to P19, not a single one.
post #4427 of 4731 Old 03-30-2015, 11:23 AM
jhughy2010's Avatar
Quoted: 840 Post(s)
Liked: 275
Thanks for your response. Since I'm only going to be using between 3-5 HDD for now I should go ahead and assign drive letters then?
post #4428 of 4731 Old 03-30-2015, 01:46 PM
Quaraxkad's Avatar
Quoted: 63 Post(s)
Liked: 52
I would still use folder mount points. If nothing else it cleans out the drives listing from showing drives you shouldn't even be directly accessing in the first place.
post #4429 of 4731 Old 03-30-2015, 02:36 PM
jhughy2010's Avatar
Quoted: 840 Post(s)
Liked: 275
Ok I see where I can mount to an NTFS file. Where do I mount the drive to?
post #4430 of 4731 Old 03-30-2015, 02:52 PM
Quaraxkad's Avatar
Quoted: 63 Post(s)
Liked: 52
Any empty folder.
post #4431 of 4731 Old 03-30-2015, 03:04 PM
jhughy2010's Avatar
Quoted: 840 Post(s)
Liked: 275
Any empty folder.
Forgive my newbness... an empty folder on an existing drive that will be added to the pool? Or an empty folder on C drive?
Should I mount all the drives to the same empty folder?
post #4432 of 4731 Old 03-30-2015, 03:21 PM
Quaraxkad's Avatar
Quoted: 63 Post(s)
Liked: 52
Create an empty folder anywhere on the C drive. One folder is one mount point. One folder/mount point per drive. I use folders under C:\!MountPoints\, each called A0 to D5 to indicate their location in my case. Once you create the mount point in Disk Management, you will see the contents of that drive just as if the files were actually in that folder.
Then when you create the snapshot array or pool, instead of using D:, E:, F:, etc, you will use C:\!MountPoints\A0, C:\!MountPoints\A1, C:\!MountPoints\A2, etc. Use descriptive names for each mount point folder so you know what physical drive it correlates to.
EDIT: If you end up using RAID-F Cruise Control, then these mount points will disappear after you create the RAID-F configuration. But they will still be labeled in the UI based on the folders they were mounted as, so you will still want descriptive names. This is one of MANY areas that confuses people when they use CC mode, they end up with multiple drives labeled E:\ in FlexRAID even though there is no drive mapped to E:\, and they have no idea what drive to replace when one of them fails.
ajhieb and jhughy2010 like this.
post #4433 of 4731 Old 03-30-2015, 04:18 PM
jhughy2010's Avatar
Quoted: 840 Post(s)
Liked: 275
post #4434 of 4731 Old 03-30-2015, 11:38 PM
DotJun's Avatar
Quoted: 574 Post(s)
Liked: 154
Mfusick's How to build an affordable 30TB Flexraid media server: Information ...
Correct, I should have noted that I meant traid. I thought it was drivepool that did not like RAW drives. I guess I was mistaken and it was snapraid instead. I knew it was one or the other and it only takes one of them to make it not work out.
I'll keep an eye out. The only errors I see for LSI are code 11. Do these errors happen only on multiple small file copies? I've not done that yet so maybe that's why I'm not seeing them.
Just to make sure, the file I flashed is 2118t.bin and I doubt it matters but I installed via uefi.
DotJun is offline
post #4435 of 4731 Old 04-03-2015, 03:10 PM
mlah384's Avatar
Quoted: 410 Post(s)
Liked: 177
I'm RMA'n my ASrock mobo, i7 cpu, and 16gb of ram... i want to get server grade hardware since I'm tired of unstable consumer stuff... I need something that will be zero problems or at least very low chance of problems...
I'm torn on dropping $1k+ on server mobo, xeon, ecc ram, SAS cards, and 24bay chassis ... or either getting a $600 refurbished one such as: http://www.newegg.com/Product/Produc...9SIA4GH27M2356
The down side is the two damn xeon's that are 100w each and two 900w PSU's, but can't one PSU be taken out? or are you forced to run both? the chassis is $1200 new, and that adaptec card is pricey separately as well, but that card may be dated and I would need to replace it anyway? I should be able to replace loud fans, etc fairly easy and inexpensive?
Help me rationalize which way to go, or a better road I haven't thought of?
mlah384 is offline
post #4436 of 4731 Old 04-03-2015, 03:21 PM
Dark_Slayer's Avatar
Quoted: 658 Post(s)
Liked: 434
@mlah384
Honestly I think you just got a bad mobo. It happens every once in a while. Of all of use here, we use a ton of asrock mobos and I've never had one DOA or flake out like the issue you were having. It sounds like your issue was definitely with the mobo, possibly a loose heatsink on the intel chipset (which routes video) or even a flaky hdmi chain after that
I hope you understand that with the history of this forum, that was definitely the exception and not the rule. Branding was something I thought used to matter a great deal, but I've helped a couple different folks here troubleshoot their stuff for a few days and they ended up having a bad mobo (one was Asus and the other was Intel, both rock-solid stable brands in my opinion which meant I ruled them out of even being a problem at first). Me and a large majority of others use asrock+intel on every build just about, and don't have issues
As to not getting the Intel Nic going inside your WS2012 install due to using a consumer nic I can't help at all on that. I can say that in my experience using WHS was a chore compared to windows, and I can't imagine WS being any less of a chore. I'd recommend just going with W8.1, but there are many more knowledgable folks that could hopefully help you out like andy_steb, ken f, ajhieb, techmattr or a few others who I can't recall that I think run ws2012 or have experience with it
Dark_Slayer is offline
post #4437 of 4731 Old 04-03-2015, 03:35 PM
Quaraxkad's Avatar
Quoted: 63 Post(s)
Liked: 52
You can take out one PSU. The second one is there for redundancy, not because it needs that much power. Though one thing you might not be considering is noise. Without any modifications, this system will be *extremely* loud. I don't mean just like "a loud PC with some fan noise". It's LOUD loud. Fans are replaceable, but the PSU is where a large portion of the noise will be coming from. You may be able to fit a full-size ATX PSU in there to quiet it down. But if you are going to start making case modifications like that, you're probably better off buying one of the much cheaper SuperMicro or AIC 24-bay cases on ebay from Tamsolutions. There's a whole thread here about those systems and how to modify them to be no louder than a typical PC. Are You Looking For A Less Expensive Norco 4220 / 4224 Alternative?
In it, I posted this video to demonstrate how loud a typical 4U server is with no modifications:
Dark_Slayer likes this.
post #4438 of 4731 Old 04-03-2015, 04:06 PM
Ken.F's Avatar
Quoted: 1472 Post(s)
Liked: 1256
I'd try loading Win7 on it as a test just to see if the hardware is defective or if it's WHS compatibility problem.
Ken.F is offline
post #4439 of 4731 Old 04-03-2015, 04:37 PM
mlah384's Avatar
Quoted: 410 Post(s)
Liked: 177
I loaded 8.1 and it worked fine and suddenly is corrupt and wont boot. Win CD wouldnt repair, ISO on USB wouldnt repair... i switched the Bios B and it booted fine, ran for an hour or so, the BSOD... now wont boot.
mlah384 is offline
post #4440 of 4731 Old 04-03-2015, 05:35 PM
Ken.F's Avatar
Liked: 1256
Does that mobo have an onboard debug display?
Ken.F is offline
Reply Home Theater Computers
Flexraid , Intel Core I5 4670k 3 4ghz Lga 1150 Quad Core Desktop Processor , Intel Core I3 4130 3 4 3 Fclga 1150 Processor Bx80646i34130 , Asrock , Asrock Z87m Extreme4 Lga1150 Intel Z87 Chipset Ddr3 Quad Crossfirex Quad Sli Sata3 Usb3 0 Microatx M , Asus , Asus Us , Asus Computer , Asus Components , Norco , Asus Computer International Direct , Flexraid Raid F , Seagate , Seagate Hard Drives , Seagate Freeagent Theater 1080p Hd Media Player Stcea201 Rk , Hitachi , Dell , Windows 7 Vista Xp Media Center Mce Pc Remote Control And Infrared Receiver , Hp Oem Window Media Center Mce Pc Remote Control And Infrared Receiver For Windows7 Vista Xp Home Pr , Intel , Intel Core I5 3570 3 4 Ghz Processor , Intel Pentium G2020 2 9ghz Lga 1155 Dual Core Desktop Processor , Intel Pentium G3220 3 0ghz Lga 1150 Dual Core Desktop Processor , Amd , Amd A10 6700 Richland 4 2ghz Socket Fm2 65w Quad Core Desktop Processor Amd Radeon Hd Ad6700okhlbox , Amd A6 5400k 3 6ghz Socket Fm2 Dual Core Desktop Processor , Amd A8 5600k 3 6ghz Socket Fm2 Quad Core Desk
