Mfusick's How to build an affordable 30TB Flexraid media server: Information Requested.! - Page 153 - AVS Forum | Home Theater Discussions And Reviews
 122Likes
Old 01-06-2016, 10:09 AM
bryansj's Avatar
Quoted: 787 Post(s)
Liked: 438
Originally Posted by amarshonarbangla View Post
Do I need to install any drivers in Windows 10 for the 9211-8i in IT mode?
http://www.ebay.com/itm/291641245650
I've never needed any, but I've never tried anything newer than Server 2012r2. It wouldn't hurt to go into device manager and right click on the card and hit update to see if there is anything it picks up.
bryansj is online now
Old 01-06-2016, 10:18 AM
Quaraxkad's Avatar
Quoted: 63 Post(s)
Liked: 52
Quick question,
I need to make some hard drive backups of a few office style PC's and their various hardrives. Most are SSD but some are normal HDD.
What is the best way to do this? Ideally I would like to do it at the hardware level, outside of windows or an OS being installed or required.
Is there a dock or something that works well? I need simple and fast. Or- is it better to use a USB stick boot from BIOS and just copy to a new disc ? Suggestions?
You never want to just copy the contents of a system drive as a backup. That's not restorable. Try something like EaseUs ToDo Free. It can make a full image of the system drive while the OS running, and it's very easy to use but still powerful. And free, if the name didn't give that away.
Quaraxkad is offline
Old 01-06-2016, 05:26 PM
amarshonarbangla's Avatar
Quoted: 26 Post(s)
Liked: 40
So it's just plug n play? The drivers are installed automatically?
If there are no drivers to install and I wanted to make the hard drives spin down where would I input the following code?
[Shutdown_addreg]
HKR,"StorPort","EnableIdlePowerManagement",0x00010 001,0x01
HKR,"ScsiPort","NeedsSystemShutdownNotification",0 x00010001, 1
amarshonarbangla is offline
Old 01-06-2016, 05:38 PM
Mrkazador's Avatar
Quoted: 209 Post(s)
Liked: 354
You need to edit one of the inf files in the driver folder that you downloaded from LSI. Then install the driver using the modified inf.
It's been awhile since I've done it but I think if you search this thread you can get more info.
Mrkazador is offline
Old 01-06-2016, 07:06 PM
Quoted: 26 Post(s)
Liked: 40
Could you kindly link me to the driver for Windows 7 x64?
Old 01-06-2016, 07:41 PM
Mrkazador's Avatar
Quoted: 209 Post(s)
Liked: 354
http://www.avagotech.com/products/se...1-8i#downloads
Driver for Windows7 and Windows Server 2008 R2
I think I'm using p19 because there were problems with p20. I can't remember.
DotJun likes this.
Old 01-06-2016, 09:30 PM
Quoted: 26 Post(s)
Liked: 40
Thanks much!!!!
Old 01-08-2016, 10:46 AM - Thread Starter
Mfusick's Avatar
Quoted: 576 Post(s)
Liked: 2407
Not much care about bootable or the OS, just the data on it.
"Too much is almost enough. Anything in life worth doing is worth overdoing. Moderation is for cowards."
Mfusick is offline
Old 01-09-2016, 01:22 PM
Quoted: 26 Post(s)
Liked: 40
Has anyone tried using the LSI 9211-8I with Windows 10? Any issues? Are there drivers for Windows 10 for this card?
Old 01-10-2016, 06:21 AM
beankid's Avatar
Quoted: 16 Post(s)
Drivers? I wouldn't see why you would need a driver for the card itself if you use the card as an HBA, it's hardware level and not software. If you don't flash the drive to a different firmware and use it out of the box then you might have to locate some. I use the 9220 in my nas box and I've never needed drivers with it, just flashed the LSI firmware on it to skip the raid functions and it works great. Allows direct access to all the drives.
beankid is offline
Old 01-10-2016, 09:40 AM
Quaraxkad's Avatar
Quoted: 63 Post(s)
Liked: 52
http://www.avagotech.com/support/download-search
Old 01-10-2016, 01:07 PM
ajhieb's Avatar
Quoted: 863 Post(s)
Liked: 646
HBA's require drivers too. Even yours.
RAID protection is only for failed drives. That's it. It's no replacement for a proper backup.
ajhieb is offline
Old 01-10-2016, 02:52 PM
Quoted: 26 Post(s)
Liked: 40
He's probably using the driver downloaded automatically by Windows. Will there be any performance difference the default driver and the driver provided by LSI? I will be using it as a HBA.
Old 01-10-2016, 05:04 PM
robnix's Avatar
Quoted: 509 Post(s)
Liked: 443
Not really. The only thing I would recommend is to install the Megaraid Storage Manager so you can setup email alerts just in case you have disk issues.
Looky here!
robnix is offline
Old 01-11-2016, 05:42 PM
GCS
GCS's Avatar
Quoted: 48 Post(s)
Liked: 32
Been a long time since I have checked into this thread nice to see still up and going.
Its about time to add some new storage space to my server so I wanted to ask what is everyone using/recommending for 5-6TB drives these days?
XBL Gamertag - blowfish7494
"Pull up your big boy pants and deal with it" - The Wife!
"Put on your man suit and fake it" - The Wife
GCS is online now
Old 01-12-2016, 12:06 PM
Quoted: 26 Post(s)
Liked: 40
Received the LSI 9211-8i today, but facing some issues booting into Windows. The card and the drives installed in it are all detected, but it seems to get stuck on the following screen and doesn't move forward to boot into Windows. What do I do?
Also, I tried disabling the boot support in the card's BIOS, but that disables the whole card and still gets stuck in a similar screen. Help please...
My system specs are as follows:
i7 920
Gigabyte EX-58-UD4P
12GB RAM
GTX 760
850 Pro OS drive running in AHCI mode
Old 01-12-2016, 06:18 PM
robnix's Avatar
Quoted: 509 Post(s)
Liked: 443
i7 920
Gigabyte EX-58-UD4P
12GB RAM
GTX 760
Try a different PCI-E slot. Some motherboards will do this if you put an HBA into a slot that's intended for a graphics card.
Looky here!
robnix is offline
Old 01-12-2016, 07:01 PM
ajhieb's Avatar
Quoted: 863 Post(s)
Liked: 646
Also might want to double check the boot order in your motherboard BIOS and make sure it isn't trying to boot from a data drive.
ajhieb is offline
Old 01-13-2016, 10:33 PM
Defcon's Avatar
Quoted: 728 Post(s)
Liked: 321
Its amazing how fast hw prices fall. I saw a Seagate 8TB drive for $200 today (from provantage). You could buy 4/5 of those, put them in any regular old pc (even one purchased from Dell/HP) for ~$200, and you'd have a 32TB server which would use less power as well !! Granted it won't be enterprise class but no one really needs that for a home server anyway IMO.
Defcon is offline
Old 01-13-2016, 11:03 PM
ajhieb's Avatar
Quoted: 863 Post(s)
Liked: 646
That 8TB Seagate is almost certainly one of their SMR "Archive" drives, which may work for some purposes but are not well suited for general purpose duty.
Caveat emptor.
ajhieb is offline
Old 01-14-2016, 05:04 AM
bryansj's Avatar
Quoted: 787 Post(s)
Liked: 438
Caveat emptor.
Also, it is a Seagate. No more Seagates for me.
Old 01-14-2016, 10:10 PM
Defcon's Avatar
Quoted: 728 Post(s)
Liked: 321
What is recommended between these 2 setups -
- FlexRaid
- StableBit DrivePool + Scanner
There are other options like snapRaid etc too but these 2 seem to me the easiest and most full featured to use. FlexRaid does more but is also more complex. I like parity as a solution much more than duplication, but have read plenty of issues with FlexRaid both here and on their forums.
For the OS, I have an option to use WSE 2012 R2, WSE 2016, or just plain old Windows 10. Is there any advantage in using the server OS? Are addons like LightsOut still working well?
Have not been following home server setups for a while so have a lot of questions.
Defcon is offline
Old 01-17-2016, 07:50 AM - Thread Starter
Mfusick's Avatar
Quoted: 576 Post(s)
Liked: 2407
Ok so I had the same issues on a RAID pool with new SSD drives I did with the old spinners, turns out the problem is a bad SATA cable !
So of coarse I admitted defeat and removed the old RAID 0 array drives, I think I even brought one online as a normal drive just for testing purposes (initialized at GPT I think)
But I did not read or write or change anything on the drives. Possible to rebuild the array or recover data from them ?
Mfusick is offline
Mfusick's Avatar
Quoted: 576 Post(s)
Liked: 2407
Mfusick is offline
Old 02-21-2016, 10:08 AM
politby's Avatar
Quoted: 63 Post(s)
Liked: 76
Anyone who has a flashed-to-IT-mode Dell or IBM card for sale? Someone just gave me an HP DL180 G6 server which I am going to turn in to virtualization lab and I need to replace the HP storage controller. 😄
politby is offline
Old 02-21-2016, 12:04 PM
rc05's Avatar
Quoted: 121 Post(s)
Liked: 81
I've read that HP servers generally don't like non-HP parts, so if you add an M1015 or other non-HP branded card, it can't read the temperature data and the fans ramp up to full speed "just to be safe".
See: https://forums.servethehome.com/inde...dl180-g6.3632/
politby likes this.
rc05 is offline
Old 02-21-2016, 12:11 PM
politby's Avatar
Quoted: 63 Post(s)
Liked: 76
Thanks, yes I am aware of this. Fortunately this machine will be located far away from human ears so the noise is not a problem. Only thing I have to worry about is the power consumption of all those fans at 100%. 😱
I also understand that there are possible mods for the fans.
This is also the 24 bay version so I was wondering if maybe one of the cheaper older generation LSI cards, which are only 3 GB/s and do not support larger than 2 terabyte drives, might work.
politby is offline
Old 03-02-2016, 06:12 AM
Quoted: 295 Post(s)
Liked: 47
Hi All
Like many here, I am running the IBM M1015 and FlexRaid.
Currently, I'm on Windows 8.1 and want to upgrade to Windows 10
Anyone done this? Any issues I need to be aware of?
Mark
Home Theater and Home Automation Enthusiast
MalevolentHamster is offline
Old 03-30-2016, 04:09 PM - Thread Starter
Mfusick's Avatar
Quoted: 576 Post(s)
Liked: 2407
Thinking about upgrading my desktop. Worth it? Or wait ?
Mfusick is offline
Old 04-01-2016, 06:23 AM
DotJun's Avatar
Quoted: 479 Post(s)
Liked: 138
Originally Posted by MalevolentHamster View Post
Hi All
Mark
No issues on win10 for snapraid.
DotJun is offline
Flexraid , Intel Core I5 4670k 3 4ghz Lga 1150 Quad Core Desktop Processor , Intel Core I3 4130 3 4 3 Fclga 1150 Processor Bx80646i34130 , Asrock , Asrock Z87m Extreme4 Lga1150 Intel Z87 Chipset Ddr3 Quad Crossfirex Quad Sli Sata3 Usb3 0 Microatx M , Asus , Asus Us , Asus Computer , Asus Components , Norco , Asus Computer International Direct , Flexraid Raid F , Seagate , Seagate Hard Drives , Seagate Freeagent Theater 1080p Hd Media Player Stcea201 Rk , Hitachi , Dell , Windows 7 Vista Xp Media Center Mce Pc Remote Control And Infrared Receiver , Hp Oem Window Media Center Mce Pc Remote Control And Infrared Receiver For Windows7 Vista Xp Home Pr , Intel , Intel Core I5 3570 3 4 Ghz Processor , Intel Pentium G2020 2 9ghz Lga 1155 Dual Core Desktop Processor , Intel Pentium G3220 3 0ghz Lga 1150 Dual Core Desktop Processor , Amd , Amd A10 6700 Richland 4 2ghz Socket Fm2 65w Quad Core Desktop Processor Amd Radeon Hd Ad6700okhlbox , Amd A6 5400k 3 6ghz Socket Fm2 Dual Core Desktop Processor , Amd A8 5600k 3 6ghz Socket Fm2 Quad Core Desk
taboola here
