Mfusick's How to build an affordable 30TB Flexraid media server: Information Requested.! - Page 33 - AVS Forum | Home Theater Discussions And Reviews
 144Likes
post #961 of 4731 Old 06-05-2013, 09:22 PM
dubboxster's Avatar
Originally Posted by Mfusick View Post
I am also on W7 x64. I don't care for W8 yet.
You should try use W8 Pro...you wont regret it..
dubboxster is offline
post #962 of 4731 Old 06-05-2013, 09:24 PM
amarshonarbangla's Avatar
Quoted: 30 Post(s)
Liked: 43
http://www.tweaktown.com/reviews/5487/superspeed-ramdisk-plus-11-software-review/index6.html
Anyone ever try it ? Or use a RAM disk ?
I have used AMD Radeon RAM disk software. Pretty fun with all that speed and all but pretty useless for most people or unless you have 64GB RAM.
amarshonarbangla is offline
post #963 of 4731 Old 06-06-2013, 01:52 AM
Quoted: 30 Post(s)
Liked: 43
What graphics card are you running btw? Do you game? I would have upgraded the GPU instead of the CPU/mobo.
post #964 of 4731 Old 06-06-2013, 03:14 AM
facke02's Avatar
Originally Posted by shepP View Post
Mfusick, are you using NFS with flexraid? My original WHS v1 died so I installed Server 2012 but it doesn't seem to play well in a home environment was I was thinking I should switch to whs2011 if Flexraid and NFS work together.
Curious why Windows Server 2012 isn't playing nice in your environment? I have WHS V1 and I have a test install of WSE 2012 that I'm playing with. I'll be upgrading to it very soon.
Ken
facke02 is offline
post #965 of 4731 Old 06-06-2013, 03:38 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
+1. I have the same feeling when changed from Win7 to Win8 as when HDD to SSD, "Wow, what miracles are happening in this OS?". Win8 is a truly modern, faster OS, Win7 is older, outdated. Just my crude, non-quantitative impression. smile.gif BTW I have never touched "Modern" UI, I immediately install StartIsBack, $3 for 2 PCs license, although I sometimes (but very rarely) have to see it, e.g. to do something with "PC settings".
renethx is offline
post #966 of 4731 Old 06-06-2013, 05:07 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
I haven't been gaming seriously. I only have a 6870 X2 XFX card. It's staying with the 2600k.
At some point I'll prob get a 8000 series Radeon. For now I'll live ok on integrated graphics. I find I'm gaming less and less.
I didn't want or need to upgrade except I needed a PC. My historical pattern is to upgrade my personal workstation and use the old one for work. My 2600k is a bit much for office PC but I'll grow into it.
Mfusick is offline
post #967 of 4731 Old 06-06-2013, 02:21 PM
dubboxster's Avatar
Classic shell is free and looks pretty cool also.
post #968 of 4731 Old 06-06-2013, 02:33 PM
Quoted: 30 Post(s)
Liked: 43
Classic shell (and the other start button alternatives) run as a service in the background if I am not mistaken. Start is back runs almost natively.
post #969 of 4731 Old 06-06-2013, 03:08 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
I perhaps should try W8. Perhaps with my 4770k machine I might give it a shot.
I love my w7. I'm just comfortable with it. W8 seemed strange. Your saying I can make W8 look and feel more like W7 ?
Mfusick is offline
post #970 of 4731 Old 06-06-2013, 03:10 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Does Microcenter even make any $$?
I picked up a Coolermaster EVO 212 cooler because it was bulked out at the checkout and tagged wrong @ $19.99 (which is the sale on the Non EVO model). I asked is that really $19.99? They said yes so I bough it much like you'd add a pack of gum at the grocery store checkout.
Mfusick is offline
post #971 of 4731 Old 06-06-2013, 03:43 PM
Quoted: 30 Post(s)
Liked: 43
The speed improvements in Windows 8 really are amazing. It feels smoother and just snappier overall. And this is on my WD Black drive. It's definitely worth a try. My favorite W8 feature is the new file copy/transfer thingie. Anyways, yes you can bring the start button back with various little utilities. Start Is Back is my favorite. $3 for 2 PCs, $5 for 5 PCs.
Doubt you will get 4.5Ghz with an Evo however.
post #972 of 4731 Old 06-06-2013, 04:11 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
I was actually going to use the stock cooler for now. I only grabbed the EVO because it was $20 and seemed like a fair deal. I am not going to overclock this hard at first. I might not even do it at all.
I usually like to wait 6 months and get all the feedback from others so I know where to go and what to do. I'm not into smoking my CPU being a test monkey. I actually have been shopping for a radiator and water cooler for my Coolermaster COSMOS II.
With a Passmark score over 10,000 it's already higher than my 2600K with a mild overclock. I really did not want or need to upgrade. My i7 Sandy Bridge as perfectly acceptable but my office PC blew up so I figured why not ? I needed to get a PC anyway and if I went low end I'd probably be upgrading or regretting it.
Mfusick is offline
post #973 of 4731 Old 06-06-2013, 04:38 PM
dubboxster's Avatar
ummmm with your new gig using Windows 8 Pro...You'd be amazed....beat me up if I lie...I'm jealous :-)
post #974 of 4731 Old 06-06-2013, 10:15 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
The look and feel of 8 with StartIsBack (or Start8) is almost the same as 7.
The only thing I don't like is that the title bar/border color of inactive windows is all identical, flat gray. When multiple windows are open, it may be hard to distinguish them. There may be a workaround?
renethx is offline
post #975 of 4731 Old 06-07-2013, 05:26 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
I'm intrigued about windows 8.
ReneThx - you run on your HTPC personally ?
What front end and player ?
This is actually for my work station so I'm ok to try anything I'm just being lazy about a learning curve.
Mfusick is offline
post #976 of 4731 Old 06-11-2013, 10:05 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Originally Posted by bryansj View Post
lol.
I am actually going to do a full "HOW TO BUILD A HIGH VALUE MEDIA SERVER" thread from this build. I am almost done with it.
Working on it as we speak:
What is the thoughts on editing this thread with links on the first page to the pages with specific guides inside ? versus.. Starting a new thread?
Mfusick is offline
post #977 of 4731 Old 06-11-2013, 03:33 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
without much playing or tuning - first results are impressive of my new 4770k
Mfusick is offline
post #978 of 4731 Old 06-12-2013, 09:13 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Time for some pictures I guess:
Mfusick is offline
post #979 of 4731 Old 06-12-2013, 09:20 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
This is my HTPC (3570k/Asrock Z77)
Ignore the crappy case (Antec 300) my HTPC goes on the floor in a dedicated AV closet that holds my receiver, Projector, cablebox, Xbox, etc... It's not seen.
During the project I removed a cheap tuner card I was using for no encrypted channels I bought on ebay for $10 (Good deal biggrin.gif )
The reason I took the HTPC out was to steal the Memory from it:
I used the 2400mhz DDR3 on the new 4770k. It was previously in my HTPC (3570k)
I then split up my 2600K RAM between two machines: (16GB DDR3 1600mhz = 8GB each machine now)
Mfusick is offline
post #980 of 4731 Old 06-12-2013, 09:24 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
A 4670k or 4770k is going to stress a stock intel fan - which is not really up for the duties demanded.
Two things happen: (Both bad)
First- The stock Intel Fan must run hard, increasing noise due to higher RPM speed.
Second, The CPU runs hotter than ideal because the stock Intel fan is limited in cooling capability.
When you upgrade the fan a couple things happens: One it can get quieter (not that Intel stock fans are super loud. They are usually quiet unless your going hard). Two, Temps can drop down.
I picked up a Coolermaster EVO2 212 air cooler at Microcenter last week for $19.99. I believe it was marked wrong, but I confirmed the price with the checkout girl. They had a pile of them at the front of the store bulked out with a sign. I believe the non EVO was supposed to be $19.99 and the EVO was $29.99 (still good value) but since it was marked wrong I bought it. I bought it as a last minute after thought much like you would add a candy bar or pack of gum at a grocery checkout. Looking back I am glad I did, because for $20 it saved me the trouble of having to remove my other after market cooler I was originally going to re-use from my 2600k machine.
My long term plan is for a water cooler, which is why I did not want to get too serious with an air cooler or spend big $$. But for $20 the EVO is a great air cooler if you can fit it.
I added a second 120mm fan so there is a fan on both sides of the large radiator.
The results are it is super quiet because most of the time it is going at very low RPM. Lower the RPM the quieter the sound. That is why a high end cooler can often be quieter and cool better than a stock cooler. It cools much better because it's like 5 times the size of the stock intel cooler with more radiator, more surface area, and two 120mm fans moving more air than a small single fan.
Disclaimer: I run a 3570k in my HTPC with stock intel cooler and it's in my bedroom and I hear nothing. No hate on Intel stock coolers. For non overclocked situations they work fine on any mid range or under CPU.
Mfusick is offline
post #981 of 4731 Old 06-12-2013, 09:26 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
One of the reasons I went Z87 Asrock Extreme 4:
Mfusick is offline
post #982 of 4731 Old 06-12-2013, 09:26 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
One thing the Extreme 4 seems to have is (2) HDMI (One is an input)
WTF is up with that ???
Mfusick is offline
post #983 of 4731 Old 06-12-2013, 09:30 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
One of the millions of things I absolutely love about my coolermaster Cosmos II case is that the sides remove for easy building- and they are on levers and open easily with full swing.
You can remove the door once it is open by just lifting up. It goes on and off and open and closes very easily. It's a true enthusiast case. Nothing I've ever uses is as good.
Mfusick is offline
post #984 of 4731 Old 06-12-2013, 09:32 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Some pictures from the removal of my old system I was upgrading (2600k / Z68 Asus deluxe )
Mfusick is offline
post #985 of 4731 Old 06-12-2013, 09:34 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
One thing I like about Asus higher end board is the back plate is thicker and insulated and gives a better fit around the motherboard input connections panel.
Comparison of two:
Mfusick is offline
post #986 of 4731 Old 06-12-2013, 09:36 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Another win for Asus:
The header pins go onto a plug - which then goes on motherboard making it much easier.
Mfusick is offline
post #987 of 4731 Old 06-12-2013, 09:39 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Top of the case has (3) 120mm fans on it. (I am upgrading to a water radiator )
Back of case has a few large fans. Front of case has a monsterous fan and a couple 120mm as well.
I think my case has 10 fans total- all run off the built in fan controller with soft touch buttons on the case.
Mfusick is offline
post #988 of 4731 Old 06-12-2013, 09:42 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Since I needed an SSD for another machine I was building I decided to buy a cheap 128GB Vector (it was $109) as an upgrade and re-use my old SSD (MAX IOPS Toggle NAND) in my HTPC, and the normal Vertex3 in another machine.
At some point soon I plan to really upgrade my SSD to a Samsung 512 or 256GB PRO. This is just a stop gap.
Mfusick is offline
post #989 of 4731 Old 06-12-2013, 09:44 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
I am not sure why I labeled my SATA cables but I figured it would be handy in future. I open my case up enough and mess around. I also have 2 built in Hot Swap bays on my Desktop case.
Mfusick is offline
post #990 of 4731 Old 06-12-2013, 09:46 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
The RAM I split up between machines:
I left 8GB in the 2600K
Mfusick is offline
Reply Home Theater Computers
Flexraid , Intel Core I5 4670k 3 4ghz Lga 1150 Quad Core Desktop Processor , Intel Core I3 4130 3 4 3 Fclga 1150 Processor Bx80646i34130 , Asrock , Asrock Z87m Extreme4 Lga1150 Intel Z87 Chipset Ddr3 Quad Crossfirex Quad Sli Sata3 Usb3 0 Microatx M , Asus , Asus Us , Asus Computer , Asus Components , Norco , Asus Computer International Direct , Flexraid Raid F , Seagate , Seagate Hard Drives , Seagate Freeagent Theater 1080p Hd Media Player Stcea201 Rk , Hitachi , Dell , Windows 7 Vista Xp Media Center Mce Pc Remote Control And Infrared Receiver , Hp Oem Window Media Center Mce Pc Remote Control And Infrared Receiver For Windows7 Vista Xp Home Pr , Intel , Intel Core I5 3570 3 4 Ghz Processor , Intel Pentium G2020 2 9ghz Lga 1155 Dual Core Desktop Processor , Intel Pentium G3220 3 0ghz Lga 1150 Dual Core Desktop Processor , Amd , Amd A10 6700 Richland 4 2ghz Socket Fm2 65w Quad Core Desktop Processor Amd Radeon Hd Ad6700okhlbox , Amd A6 5400k 3 6ghz Socket Fm2 Dual Core Desktop Processor , Amd A8 5600k 3 6ghz Socket Fm2 Quad Core Desk
