Mfusick's How to build an affordable 30TB Flexraid media server: Information Requested.! - Page 46 - AVS Forum | Home Theater Discussions And Reviews
 144Likes
post #1351 of 4731 Old 08-27-2013, 11:54 PM
politby's Avatar
Quoted: 76 Post(s)
Liked: 77
Originally Posted by dakkar View Post
Thx for the reply.
Still about 100€ difference compared to the Norco at Newegg...
EDIT: Sorry, I did calculate wrong. The difference would be 150€. (373 € vs 222 €, both shipping not included).
Agree that is a significant difference. I'd say the box is about the same size as a large suitcase or maybe a little larger. Not sure about Italian customs but here in SE they would definitely stop someone with an obviously new box like that and demand a VAT payment. If the Customs desk is manned, that is.
politby is offline
post #1352 of 4731 Old 08-28-2013, 03:10 AM
DotJun's Avatar
Quoted: 574 Post(s)
Liked: 154
I chose the 2120t for its very very low idle consumption because 99% of the time that is what our servers at home is doing.
I choose raid 6 over 5 because when you are using huge capacity drives across huge capacity arrays the chance of failure increases more than I'd care to risk.
I choose hardware over software due to speed and bbu.
I choose noctua fans over others because I have personally tested db vs cfm output of over a dozen 120mm fans and the noctua came out on top. They are pricey though.
I chose hardware over software also for other reasons not having to do with media storage, but as far as media storage goes... I compress my media. It's faster for me to have a better chance at recovering from a crash with hardware/backup implementation than it would be for me to have to re-encode whatever media I lost in a crash.
DotJun is offline
post #1353 of 4731 Old 08-28-2013, 03:27 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
FYI, the idle power consumption of a "T" chip is the same as a non-T chip. smile.gif A T chip consumes less power only at full load because of lower clock/voltage.
renethx is offline
post #1354 of 4731 Old 08-28-2013, 04:26 AM
DotJun's Avatar
Quoted: 574 Post(s)
Liked: 154
My bad, I meant that is the reason I went with that chip over an atom or celeron. Well, ok I also need the CPU power to decode my movies.
DotJun is offline
post #1355 of 4731 Old 08-28-2013, 03:07 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
The T version only uses less because it's lower clock. It doesn't actually use less than normal version.
It's like limiting you cars engine to 5000rpm and then saying it gets better gas mileage under hard acceleration. It does, but not because the engine is more efficient
Mfusick is offline
post #1356 of 4731 Old 08-28-2013, 10:22 PM
DotJun's Avatar
Quoted: 574 Post(s)
Liked: 154
Less clock than the normal version or less than celeron/atom? I realize it is less than 2120 but it was enough CPU for my needs where the atom and celeron were not for the same amount of energy consumption.
DotJun is offline
post #1357 of 4731 Old 08-29-2013, 12:42 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Performance-wise,
Core i3 2120 (SNB, 3.3GHz, 2C/4T, 3MB cache) > Core i3 2120T (SNB, 2.6GHz, 2C/4T, 3MB cache) > Celeron G540 (SNB, 2.5GHz, 2C/2T, 2MB cache) >> Atom.
- Core i3 2120T is just Core i3 2120 with max CPU multiplier = 26.
- Celeron G540 is Core i3 2120 with max CPU multipler = 25, HyperThreading disabled, and decreased size of cache (eventually it's the same Sandy Bridge microrachitecture).
renethx is offline
post #1358 of 4731 Old 08-29-2013, 02:47 AM
dakkar's Avatar
Thank you everybody for the answers to my questions.
There is one still unaswered (unless I have skipped it somehow...):
Hello,
another question: is SATA 6Gb/s really needed over SATA 3Gb/s?
I am asking since I found cheap motherboards with 4 SATA 6Gb/s + 4 SATA 3Gb/s which are 50-60$ cheaper than modern boards with 8 SATA 6Gb/s.
Thx,
Dakkar
What would you suggest?
Thx,
Dakkar
dakkar is offline
post #1359 of 4731 Old 08-29-2013, 02:54 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
SATA 3Gb/s has a bandwidth of 300 MB/s, that's enough for HDD.
DotJun likes this.
renethx is offline
post #1360 of 4731 Old 08-29-2013, 03:09 AM
AVTechMan's Avatar
Quoted: 31 Post(s)
Liked: 37
I want to go ahead and make the purchase for FlexRaid to test with my server once I get a few drives (get the license in advance) but seems like the site is only taking PayPal for payments, which I have such a deep loathing for and refuse to use. It would be nice if FlexRaid's site had where just cards could be used like normal sites. I'm convinced that RAID-F will work for my storage and redundant needs, and I have a spare system to work with and test.
AVTechMan is offline
post #1361 of 4731 Old 08-29-2013, 03:27 AM
Nevcairiel's Avatar
Quoted: 43 Post(s)
Liked: 135
You can pay over PayPal without even registering for it (with a credit card). If you don't even want to do that, you're probably out of luck. They have to use some payment processor, and building your own credit card billing system is quite overkill. smile.gif
Nevcairiel is offline
post #1362 of 4731 Old 08-29-2013, 03:32 AM
dakkar's Avatar
Great!
So this: http://www.newegg.com/Product/Product.aspx?Item=N82E16813157356
plus a IvyBridge Pentium/Celeron/I3 would be a good choice, right?
Dakkar
dakkar is offline
post #1363 of 4731 Old 08-29-2013, 03:35 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Yup. I am using ASRock B75M in one of my servers.
renethx is offline
post #1364 of 4731 Old 08-29-2013, 03:49 AM
dakkar's Avatar
Great.
Would it fit 2 Supermicro AOC-SAS2LP-MV8 8-port SAS/SATA 6.0Gb/s PCI Express 2.0 x8 card?
It says it has:
1 PCI Express 3.0 x16
1 @x4 PCI Express 2.0 x16
What does @x4 means?
Dakkar
dakkar is offline
post #1365 of 4731 Old 08-29-2013, 04:48 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
x4 is half the bandwidth of x8. If you want to install two of SAS2LP-MV8 (or a similar PCI Express 2.0 x8 such as IBM M1015), you should choose a mb with dual PCI Express 2.0 x8 slot. But it will cost a lot more ($130 or more). For example
IVB
ASRock Z77 Extreme4
ASUS P8Z77-V LK
GIGABYTE GA-Z77X-D3H
Haswell
ASRock Z87 Extreme3/4
ASUS Z87-A
GIGABYTE GA-Z87X-D3H
GIGABYTE GA-Z87MX-D3H
AMD Trinity / Richland
ASUS F2A85-V PRO (one of 8 SATA is used for eSATA)
ASRock FM2A85X Extreme6 (one of 8 SATA is used for eSATA)
GIGABYTE GA-F2A85X-UP4 (one of 8 SATA is used for eSATA)
MSI FM2-A85XA-G65 (8 internal SATA; cheapest)
Has anybody used SAS2LP-MV8 or M1015 with PCI Express 2.0 x4 slot without performance penalty? FlexRAID/SnapRAID/disParity reads/writes one disk at a time, so 2.0 x4 (2.0 GB/s) should not be a bottleneck, I guess.
dakkar likes this.
renethx is offline
post #1366 of 4731 Old 08-29-2013, 04:50 AM
DotJun's Avatar
Quoted: 574 Post(s)
Liked: 154
Performance-wise,
I needed hyper threading. I do CPU decoding for my vids. How old is that celeron? I don't remember that one when I first picked up the sandy new.
DotJun is offline
post #1367 of 4731 Old 08-29-2013, 04:56 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Celeron G540 is based on Sandy Bridge, released in September 2011. Cerelon G1610 (2.6GHz, Ivy Bridge, released in January 2013) is even better and cheap ($45). The effect of HyperTheading is not that big, at most 20% performance increase. Well, if you want performance, non-T is for you. smile.gif
renethx is offline
post #1368 of 4731 Old 08-29-2013, 05:49 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
IVB
ASRock Z77 Extreme4
ASUS P8Z77-V LK
Haswell
ASUS Z87-A
Flexraid reads all HDDs at same time so x4 might bottle neck on parity updates if you have 8 HDDs running through that x4 speed slot.
Also,
This is not very scientific but I often see all the lights in the front of my Norco chassis light up indicating hard drive activity when I first enter my flexraid drive after a period of inactivity, or I go browsing through folders.
It's reading all the drives from the pool at the same time it appears- even if its only to populate your display or update contents.
Mfusick is offline
post #1369 of 4731 Old 08-29-2013, 08:05 AM
Nevcairiel's Avatar
Quoted: 43 Post(s)
Liked: 135
8 discs at 150MB/s or even 200MB/s still won't manage to saturate PCIe 2.0 4x, which runs at 20 gigatransfers per second, or 2GB/s.
post #1370 of 4731 Old 08-29-2013, 08:06 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Reading all HDD is at parity calculation, that's common to all solutions. But even then 8 x 150MB/s = 1200MB/s, a lot lower than 2000GB/s per direction speed of PCI Express 2.0 x4. This is just a theory. Need an actual test.
renethx is offline
post #1371 of 4731 Old 08-29-2013, 08:11 AM
Nevcairiel's Avatar
Quoted: 43 Post(s)
Liked: 135
I can only tell you that controllers in PCIe 3.0 x4 slots run just fine and dandy with 8 discs (if your controller is 3.0, like mine), but of course 3.0 increases the bandwidth again. smile.gif
post #1372 of 4731 Old 08-29-2013, 08:45 AM
DotJun's Avatar
Quoted: 574 Post(s)
Liked: 154
I wanted the highest performance for the amount of power drawn. Price wasn't a consideration. 20% increase in performance is significant when you talk about power consumption vs CPU.
I know the atom is not capable of decoding my movies. I'm not sure if the celeron available at the time was able to. I do know that I tried a celeron 340 at one time and it failed to decode my movies. Do those celerons have a gpu?
DotJun is offline
post #1373 of 4731 Old 08-29-2013, 09:01 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
All Sandy Bridge / Ivy Bridge / Haswell processors integrate GPU, except for some Xeon (server processor) SKUs.
renethx is offline
post #1374 of 4731 Old 08-29-2013, 09:29 AM
dakkar's Avatar
IVB
ASRock Z77 Extreme4
ASUS P8Z77-V LK
Haswell
ASUS Z87-A
Thank you as usual.
I will take it in consideration.
Dakkar
EDIT: Anyway, you can confirm that it is technically possible (with reduced performance) to install a SAS2LP-MV8 card in a x4 slot, right?
dakkar is offline
post #1375 of 4731 Old 08-29-2013, 09:48 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Yup, but the card is sitting in my real server. So not right now.
renethx is offline
post #1376 of 4731 Old 08-29-2013, 01:48 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
"real server" as opposed to "fake server " ???
Mfusick is offline
post #1377 of 4731 Old 08-29-2013, 02:03 PM
DavidT99's Avatar
Quoted: 13 Post(s)
You could try SnapRAID...........no issues with Paypal there.
David
DavidT99 is offline
post #1378 of 4731 Old 08-29-2013, 02:35 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
renethx is offline
post #1379 of 4731 Old 08-29-2013, 03:19 PM
itznfb's Avatar
Liked: 58
I just tried a M1015 and Perc H200 in a 2.0 x4 slot on a few different motherboards. The card isn't even detected.
dakkar likes this.
Running Windows Home Server 2011 Evil Abandoned Edition
itznfb is offline
post #1380 of 4731 Old 08-29-2013, 03:21 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
renethx is offline
Reply Home Theater Computers
Flexraid , Intel Core I5 4670k 3 4ghz Lga 1150 Quad Core Desktop Processor , Intel Core I3 4130 3 4 3 Fclga 1150 Processor Bx80646i34130 , Asrock , Asrock Z87m Extreme4 Lga1150 Intel Z87 Chipset Ddr3 Quad Crossfirex Quad Sli Sata3 Usb3 0 Microatx M , Asus , Asus Us , Asus Computer , Asus Components , Norco , Asus Computer International Direct , Flexraid Raid F , Seagate , Seagate Hard Drives , Seagate Freeagent Theater 1080p Hd Media Player Stcea201 Rk , Hitachi , Dell , Windows 7 Vista Xp Media Center Mce Pc Remote Control And Infrared Receiver , Hp Oem Window Media Center Mce Pc Remote Control And Infrared Receiver For Windows7 Vista Xp Home Pr , Intel , Intel Core I5 3570 3 4 Ghz Processor , Intel Pentium G2020 2 9ghz Lga 1155 Dual Core Desktop Processor , Intel Pentium G3220 3 0ghz Lga 1150 Dual Core Desktop Processor , Amd , Amd A10 6700 Richland 4 2ghz Socket Fm2 65w Quad Core Desktop Processor Amd Radeon Hd Ad6700okhlbox , Amd A6 5400k 3 6ghz Socket Fm2 Dual Core Desktop Processor , Amd A8 5600k 3 6ghz Socket Fm2 Quad Core Desk
