Mfusick's How to build an affordable 30TB Flexraid media server: Information Requested.! - Page 71 - AVS Forum | Home Theater Discussions And Reviews
 144Likes
post #2101 of 4731 Old 11-21-2013, 10:13 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
Originally Posted by mark_anderson_u View Post
what did you choose instead of FlexRAID? I'm looking for something Windows based with RAID and pooling
I believe he went all in with a ZFS Solaris based server using the Oracle/Solaris/Sun Microsystems software.
http://www.oracle.com/technetwork/server-storage/solaris11/downloads/index.html?ssSourceSiteId=ocomen
http://docs.oracle.com/cd/E19253-01/819-5461/
http://www.oracle.com/technetwork/server-storage/solaris11/technologies/zfs-338092.html
http://en.wikipedia.org/wiki/ZFS
Have at it.
It's not a direct competitor to Flexraid though... There is nothing I have found that competes with Flexraid directly for the things I want it to do. The only real choice I struggle with is F vs T options... But I think snapshot makes sense for me.
That's not quite as simple as installing a piece of software into your Windows based OS.
Speaking of which... Where is Puwaha these days ?
Mfusick is offline
post #2102 of 4731 Old 11-21-2013, 12:23 PM
mark_anderson_u's Avatar
Quoted: 43 Post(s)
Liked: 42
Originally Posted by Mfusick View Post
Have at it.
Think I'll stick with flexRAID. Built a rackmount HTPC/Server (streams DVR content and movies to one other place in house and serves up music for Sonos), so no need for a dedicated server; hence, Windows solution is required.
mark_anderson_u is offline
post #2103 of 4731 Old 11-21-2013, 06:19 PM
mrfattbill's Avatar
Quoted: 91 Post(s)
Liked: 89
I killed my FlexRaid config tonight in order to move stuff off of the 2TB and 3TB WD green drives I still have left to my 4TB Hitachi's. Cards should be here tomorrow along with my cables, HOPEFULLY I will be up and running in full force by tomorrow night. biggrin.gif
Bill
mrfattbill is offline
post #2104 of 4731 Old 11-21-2013, 07:04 PM
nickbuol's Avatar
Quoted: 554 Post(s)
Liked: 615
Good luck Bill. Keep us posted! We're rooting for you!
nickbuol is offline
post #2105 of 4731 Old 11-21-2013, 07:25 PM
mrfattbill's Avatar
Quoted: 91 Post(s)
Liked: 89
Thanks, seeing the "Are you sure you want to delete Movies" gave me pause for a second, lol. Almost done moving 2TB worth of data.
Bill
post #2106 of 4731 Old 11-22-2013, 06:30 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
Bill
This is the story of my life. Seems like I'm copying TB's constantly. Glad it's digital , and the quality remains biggrin.gif
Mfusick is offline
post #2107 of 4731 Old 11-22-2013, 07:35 AM
Quoted: 43 Post(s)
Liked: 42
Do you have something to verify all these moves/copies? I use Teracopy, as it does a CRC check after move copy (I got burned a while back with some files that were supposedly moved, but were corrupt, now I use it all the time). There's a free copy, which I think does pretty much eveything
post #2108 of 4731 Old 11-22-2013, 07:39 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
+ 1 on terracopy. Always use it. Much better than windows standard copy paste. I love how it can "queue" up additional copies so they add to the end of the current copy instead of trying to do them all simultaneously. That's awesome when you are coping a bunch of movies. Who wants to wait for the 1st copy to end before you can paste the next one ????? The Verify feature is cool but I skip it most of the time. I have been doing this a long time and at high volume and the likely hood of an error copying is very low so I don't see the point in running that since it takes twice the time.
Mfusick is offline
post #2109 of 4731 Old 11-22-2013, 07:39 AM
techmattr's Avatar
Quoted: 71 Post(s)
Liked: 184
I'm pretty sure anyone who has ever tried to copy/move more than 3 files in Windows in their lifetime uses TeraCopy. biggrin.gif
techmattr is offline
post #2110 of 4731 Old 11-22-2013, 07:45 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
techmattr do you have that link to your blog about flashing cards ?
Mfusick is offline
post #2111 of 4731 Old 11-22-2013, 08:03 AM
Quoted: 43 Post(s)
Liked: 42
LOL, I think it was popular when Windows explorer copy was slow, but since Win 7, I see little performance difference with TC. I use it for the CRC Check more than anything
post #2112 of 4731 Old 11-22-2013, 08:07 AM
mrfattbill's Avatar
Quoted: 91 Post(s)
Liked: 89
I use either Ultracopier or KillCopy, I really like KillCopy.
Bill
post #2113 of 4731 Old 11-22-2013, 08:10 AM
techmattr's Avatar
Quoted: 71 Post(s)
Liked: 184
direct link: http://techmattr.wordpress.com/2013/08/30/sas-hba-crossflashing-or-flashing-to-it-mode/
post #2114 of 4731 Old 11-22-2013, 08:22 AM
Quoted: 43 Post(s)
Liked: 42
I tried to do the decent thing and add some comments to Matt's blog entry (which may help quite a few people), but lost what I'd typed when I tried to create an account to post them, so here they are.
Basically, if you get an error after you run the clean steps and try to reflash with the LSI firmware, you probably need to do it from a UEFI shell. I had a nightmare with this, because of secure boot. below is how I fixed it. YMMV, as it may be Motherboard dependent (Mine is ASUS Gryphon Z87).
Had a real nightmare flashing my M1015
Ran first two commands to clean bios from instructions commonly available, such as these: http://forums.servethehome.com/raid-controllers-host-bus-adapters/433-ibm-m1015-experiences-5.html
megarec -writesbr 0 sbrempty.bin
megarec -cleanflash 0
I then got an error about failing to initialize the PAL when trying to install new firmware
Result of numerous Google searches suggested I would need to boot from a UEFI shell. This is where the fun started
I had just installed Windows 8.1 Pro (clean install) on an ASUS Gryphon Z87
I downloaded a UEFI shell from here (v1) https://wiki.archlinux.org/index.php/Unified_Extensible_Firmware_Interface#Obtaining_UEFI_Shell
Renamed to Shellx64.efi and copied to root of usb
Also downloaded Installer_P17_for_UEFI from http://www.lsi.com/products/host-bus-adapters/pages/lsi-sas-9211-8i.aspx#tab/tab3 (downloads -> firmware)
Extracted and copied sas2flash.efi to root of USB
Tried to boot to UEFI shell and couldn’t because it wasn’t a secure boot device
So I tried to turn off secure boot in BIOS and there seems to be no way to do it
This meant I had to somehow make the USB a secure boot device
Figured out I had to set an admin password in BIOS setup
Then I went to manage keys and saved keys to USB (can’t do this without BIOS password)
Then when to advanced
Then exit
Then boot to UEFI
Once in the UEFI shell, I ran these commands (If you get "initshellApp: application not started from shell" at any point, try another uefi shell (e.g. v2). I got this when I tried v2, so went back to v1)
fs0:
sas2flash.efi -o -sasadd 500605bxxxxxxxxx (x= numbers for SAS address (no dashes))
Got message saying need new firmware: entered 2118ir.bin at prompt
Installed firmware and then got "sas address added message"
Hope this helps some of you
Regards
mark
wiley165 likes this.
post #2115 of 4731 Old 11-22-2013, 09:03 AM
techmattr's Avatar
Quoted: 71 Post(s)
Liked: 184
::snip::
Regards
mark
And yeah... Wordpress sucks for commenting. Unless you already have an account and actively use it for other things it's a huge pita to setup an account just to comment.
Oh and you can turn off secure boot in the Z87 Gryphon UEFI in the same place I show in my blog as you can see here in this guy's walkthrough: http://www.youtube.com/watch?feature=player_detailpage&v=8F7NfXRfiRg#t=196
Screenshot from blog: http://techmattr.files.wordpress.com/2013/08/130821130652.jpg
post #2116 of 4731 Old 11-22-2013, 09:17 AM
Quoted: 43 Post(s)
Liked: 42
HI Matt
It doesn't seem to cover the case where you can't disable secure boot. I have no clue what secure boot is all about, but on my ASUS Gryphon MB, I couldn't disable secure boot for the life of me. I did find some references to it being locked depending on something that was set during windows 8.x install. I don't recall seeing anything about this. Anyway, in my quest, I found a few other people who had the same issue and never seemed to resolve it. I solved it by setting a bios password and then I was able to download the keys to the USB drive (again no clue what any of this is doing, but it worked). Wasted an entire morning on this :-(
If anyone knows h to disable secure boot, please share
Regards
mark
post #2117 of 4731 Old 11-22-2013, 09:45 AM
techmattr's Avatar
Quoted: 71 Post(s)
Liked: 184
HI Matt
Regards
mark
Select Other OS.
http://techmattr.files.wordpress.com/2013/08/130821130709.jpg
Save. Reboot back into UEFI. Boot into EFI Shell.
post #2118 of 4731 Old 11-22-2013, 12:40 PM
Quoted: 43 Post(s)
Liked: 42
Select Other OS.
Thanks will give it a try
post #2119 of 4731 Old 11-22-2013, 02:20 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
Video time! I posted this in the other thread but figured I would re-post it here too.
I've been playing around with the MB3 Theater and it's "live backdrops"
Here is a quick one I just launched:(note I created a fake demo library for these videos, and removed my real media folders from the config) I really just wanted to show off a little of the video backdrops.
Here is another: #2
Here is a TV show demo:
nickbuol likes this.
Mfusick is offline
post #2120 of 4731 Old 11-22-2013, 09:52 PM
Gronnie's Avatar
Quoted: 32 Post(s)
Liked: 30
Quick question on PPU drives for FlexRaid. What does adding an extra parity drive do for me? Does it mean that I can now have two drives fail and not lose data?
Gronnie is offline
post #2121 of 4731 Old 11-22-2013, 10:47 PM
jim2100's Avatar
Liked: 34
Why is the video backdrop quality so poor? Is that just a poor quality youtube upload (I watched the 1080p version), or does it really look that bad on your screen?
jim2100 is offline
post #2122 of 4731 Old 11-22-2013, 10:51 PM
nickbuol's Avatar
Quoted: 554 Post(s)
Liked: 615
What do you mean by "poor"?
I know that capturing things from a HTPC seems to yield stuttering video and such, so I just took it to be the capture limitations since I've seen several other screen captures look "less than good" but the person who uploads them says that they are great and don't do that in real life (stutter and have bad "gradients" of colors).
Mfusick? Enlighten us.
nickbuol is offline
post #2123 of 4731 Old 11-23-2013, 07:09 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
I think it's compression. I'd be happy to provide a couple samples to you to test locally. It looks awesome IRL.
It's 1080p mkv backdrops. You can put any video you want in the backdrops folder actually.
Mfusick is offline
post #2124 of 4731 Old 11-23-2013, 10:00 AM
jim2100's Avatar
Liked: 34
No need. I'll take your word for it. I was just curious where the poor quality was introduced. Obviously it was not at the MBT level since you say it looks awesome on your screen.
jim2100 is offline
post #2125 of 4731 Old 11-23-2013, 11:10 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
Adding second PPU drive allows you to suffer two simultaneous hard drive failures and not lose data. With 1 parity drive you could only suffer 1 failure at a time.
I think we need to keep in mind too that one thing that isn't easily seen in YouTube but is much nicer in real life is the "film" or "fog" effect. The video backdrops play in the background at full quality, basically any quality you have video file that is inside the backdrops folder will play. But the video backdrops play in the background and the HD overlay has a "fog" or "greyed-out" effect to it like a sheet of tinted glass on top of the video. It's tinted grey and foggy so that the backdrops don't take over the entire eye's focus and become the main point- They are just for effect. You are not meant to watch the video backdrops critically and I think the MB3 DEV did a really nice job at making sure the focus is on the actual text and icons and HD overlay itself. The "greyed out" effect looks great in real life but it simply does not translate as well to youtube because the greyed out effect is percieved as lack of quality, which isn't really the case as in real life it's greyed out as to not make the video back drop too distracting.
Here is some of the video backdrops I used: (They are small check it out locally) [use Direct Download and then playback- don't play in your browser as that looks like ***** too]
Friends With Benefits
Man of Steel
Hunger Games
Titanic
Just Go with It
World War Z
Tranformers Dark Side Moon
Wreck it Ralph
These are the actual files I used from my backdrops folders- They play in full quality in MBT3 except as a backdrop they are slightly greyed out intentionally- but it's still full quality.
Mfusick is offline
post #2126 of 4731 Old 11-24-2013, 04:13 AM
DotJun's Avatar
Quoted: 574 Post(s)
Liked: 154
DotJun is offline
post #2127 of 4731 Old 11-24-2013, 08:30 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
Originally Posted by DotJun View Post
No. Just on my desktop (where I quickly made that video)
I don't actually have any mouse hooked up to my HTPC. (or keyboard)
We use a combo of the HP remote that came with my ebay IR kit, a universal remote programmed to WMC code, and a Lenovo handheld Mini wireless keyboard/mouse remote
Mfusick is offline
post #2128 of 4731 Old 11-24-2013, 05:38 PM
DotJun's Avatar
Quoted: 574 Post(s)
Liked: 154
I used to use an HP MCE Remote until I found out about the harmony remotes. Now with that one remote, and without having to switch modes or anything on the remote, I am able to control my htpc with it and my receiver volume at the same time. When using the hp remote I would have to use me receivers volume buttons to control volume which is a pita.
DotJun is offline
post #2129 of 4731 Old 11-24-2013, 06:24 PM
Quoted: 43 Post(s)
Liked: 42
Harmonies are great. You can pick up the 500 and 600 series pretty cheap, and I think they are better than the current models WRT button layout and value
post #2130 of 4731 Old 11-24-2013, 09:35 PM
jbcain's Avatar
Liked: 64
So installing the live movies plugin for MBT, do I have to add the clips myself or does the plugin do it for you?
jbcain is offline
Reply Home Theater Computers
Flexraid , Intel Core I5 4670k 3 4ghz Lga 1150 Quad Core Desktop Processor , Intel Core I3 4130 3 4 3 Fclga 1150 Processor Bx80646i34130 , Asrock , Asrock Z87m Extreme4 Lga1150 Intel Z87 Chipset Ddr3 Quad Crossfirex Quad Sli Sata3 Usb3 0 Microatx M , Asus , Asus Us , Asus Computer , Asus Components , Norco , Asus Computer International Direct , Flexraid Raid F , Seagate , Seagate Hard Drives , Seagate Freeagent Theater 1080p Hd Media Player Stcea201 Rk , Hitachi , Dell , Windows 7 Vista Xp Media Center Mce Pc Remote Control And Infrared Receiver , Hp Oem Window Media Center Mce Pc Remote Control And Infrared Receiver For Windows7 Vista Xp Home Pr , Intel , Intel Core I5 3570 3 4 Ghz Processor , Intel Pentium G2020 2 9ghz Lga 1155 Dual Core Desktop Processor , Intel Pentium G3220 3 0ghz Lga 1150 Dual Core Desktop Processor , Amd , Amd A10 6700 Richland 4 2ghz Socket Fm2 65w Quad Core Desktop Processor Amd Radeon Hd Ad6700okhlbox , Amd A6 5400k 3 6ghz Socket Fm2 Dual Core Desktop Processor , Amd A8 5600k 3 6ghz Socket Fm2 Quad Core Desk
