What RAID should I use for a 3 hard drive (2TB each) setup .... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 11-10-2012, 04:29 PM - Thread Starter
vzphoneman's Avatar
Quoted: 109 Post(s)
Liked: 109
I have a Dell Dimension 9200 with Intel Core2 Quad 2.40 with 4gig ram. My OS is Windows 7 Ultimate 32bit. The OS is on a Hitachi 1TB drive. I have 3 WD 2TB drives installed, one green and two red. The green drive is now empty and the red drives have about 1Tb of data on one and 1.5Tb on the other (mostly music files). What Raid setup would be best for me to protect the data on the 3, 2TB drives. I've never worked with or setup a RAID but my technical level is high. Any advice would be appreciated. Phoneman cool.gif
The lazy man finds the easiest way ... Ben Franklin
Rouge Audio Cronus Magnum II integrated amp, Goldenear Technology's Triton 2+ speakers, Schiit Bifrost Multibit Dac, Technics SL-1200MK2 turntable with Audio Technica 440ml cartridge, Teac X-1000R reel to reel, custom computer as main music source
vzphoneman is offline
post #2 of 13 Old 11-10-2012, 04:49 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Hardware raid will erase your data so that's out.
Software raid like flex raid is what I would do.
Use the two RED drives as data drives and the empty green as back up drive.
You won't lose any data on the red drives and you can pool them to appear and function as a single drive of double capacity.
Both red drives and data would be backed up with the single dedicated green you use as parity drive
Only you parity drive is erased with flexraid
Mfusick is offline
post #3 of 13 Old 11-10-2012, 05:12 PM - Thread Starter
vzphoneman's Avatar
Quoted: 109 Post(s)
Liked: 109
A few questions.
Does the parity drive need to be the same size (2TB) as the data drives? Would I be able to add another 2Tb drive to this setup in the future? ...and finally Are you referring to FlexRAID.com software? Thanks for your quick reply by the way. After briefly look it over it does sound like my best solution.
post #4 of 13 Old 11-10-2012, 05:31 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Originally Posted by vzphoneman View Post
A few questions.
Yes Flexraid software raid.
It works great. I use it.
You can definetly add more drives in future. I've added a few myself and my Flexraid drive is now 20tb.
It shows as a single storage drive on my pc.
Parity can be any size drive but it must be a large as your largest drive.
Most people grab a 120$ 3tb when setting it up and use that as parity since it will allow you to add any size up to 3tb in future.
Do you understand how flex raid works ?
Mfusick is offline
post #5 of 13 Old 11-10-2012, 06:13 PM - Thread Starter
vzphoneman's Avatar
Quoted: 109 Post(s)
Liked: 109
I'm getting there! I've just started reading the thread "http://www.avsforum.com/t/1421746/should-i-flexraid" and I'm getting up to speed. I liked your suggestion in that thread of buying a cheap 3TB for parity and I could keep the 3, 2TB drives for data. I'm now also now interested in "Crash Plan"... but I do worry about the time involved to back everything up with only DSL speeds. Been there and done that with Mozy until they did away with there unlimited plan. That literally took me months to back and I probably had half the data I have now! Still I think I will look into it as second layer of defense. Thanks for all your input, you got me on the right track. Phoneman
post #6 of 13 Old 11-10-2012, 06:17 PM - Thread Starter
vzphoneman's Avatar
Quoted: 109 Post(s)
Liked: 109
Do you have any thoughts on "Drive Bender" ?
post #7 of 13 Old 11-10-2012, 06:20 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
No experience with it
Mfusick is offline
post #8 of 13 Old 11-10-2012, 11:46 PM
fventura03's Avatar
raid5
fventura03 is offline
post #9 of 13 Old 11-11-2012, 04:16 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
Windows 8 and drivespace?
I think classic RAID is finally coming to the end of its life, as its features are now becoming central to operating systems. So far, drive combining with backup is the ONLY feature of Windows 8 that makes it look interesting to me.
lespurgeon is offline
post #10 of 13 Old 11-11-2012, 07:56 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Originally Posted by fventura03 View Post
raid5
You can't use green drives with hardware raid.
Bad advice. Don't listen.
Mfusick is offline
post #11 of 13 Old 11-11-2012, 07:57 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Advantage of hardware raid is performance and speed.
It's not a good back up solution.
The op should look into software raid like Flexraid with drive pooling
Mfusick is offline
post #12 of 13 Old 11-12-2012, 01:18 PM
Mrkazador's Avatar
Quoted: 264 Post(s)
Liked: 390
Snapraid is free and its what I use for my media server. It doesn't do storage pooling and there is no GUI. I use Junction folders to create a "ghetto" drive pool and the cmd line is easy to learn, not very many commands. There is Elucidate if you really need a GUI.
Mrkazador is offline
post #13 of 13 Old 11-12-2012, 03:30 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
I don't mind paying for great software and recommend Flexraid as a complete solution.
There's usually a free version somewhere for everything but its not always as easy or good.
Mfusick is offline
Reply Home Theater Computers
