Question about gt430 and Panasonic st50 55" - resolution related - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 11-11-2012, 06:02 PM - Thread Starter
pburgh's Avatar
Quoted: 16 Post(s)
I just picked up a 55" ST50 Panasonic. I am running HDMI from my HTPC (GT430) to the plasma. It seems the 1920x1080 is spilling over the edges of the display. I can dial this down using the NVidia control panel, but I'm wondering why this is happening in the first place?
I thought if I set my GT430 to 1920x1080, it would fill the screen 100%, no more no less. Not true?
Thank you!
pburgh is offline
post #2 of 14 Old 11-11-2012, 06:27 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
All Panasonic TVs have overscan built in. It is by design. Some higher end models let you choise how much overscan you want. Not sure if your ST50 has this option. Other brands like Samsung has special PC mode that has zero overscan.
If you ever watched cable TV in zero oversacn TV, you will know why almost all TVs have overscan by default. Those lines and dots on the edges of the picture are very distracting.
Foxbat121 is offline
post #3 of 14 Old 11-11-2012, 06:54 PM - Thread Starter
pburgh's Avatar
Quoted: 16 Post(s)
Thanks. So what's best... do I resize using NVidia controls or let the overscan happen?
pburgh is offline
post #4 of 14 Old 11-11-2012, 07:22 PM
lockdown571's Avatar
Quoted: 36 Post(s)
Liked: 87
You want to turn overscan off on the ST50. Then you won't need to use any overscan/underscan compensation in the Nvidia settings. The ST50 can show everything dot for dot. I can't quite remember where the setting is, but it might be under HDMI or Input settings. There's something like "Full screen 1" and "Full screen 2" and I think the right setting is "Full screen 2". Sorry I don't remember exactly where the setting is. It's there somewhere.
lockdown571 is offline
post #5 of 14 Old 11-11-2012, 07:26 PM - Thread Starter
pburgh's Avatar
Quoted: 16 Post(s)
Funny, I was just headed back here to mention the HDMI 2 setting. It removed overscan and now I have 1920 x 1080 running fine. No resizing. Woo!
Thanks for the tips!
pburgh is offline
post #6 of 14 Old 11-11-2012, 07:33 PM
Quoted: 36 Post(s)
Liked: 87
Yeah so under "aspect adjustments" you should select
Screen format: Full
HD size: Size 2
but it sounds like you already found it. Enjoy your ST50! Amazing TV. I have the 50" and my dad got the 65" after seeing mine. The only TV better IMO is the VT50, and it's not really worth the significant increase in price.
post #7 of 14 Old 01-02-2013, 11:52 PM
ForeverSilent004's Avatar
Screen format: Full
HD size: Size 2
Finally! I've had my ST50 installed since June and I was messing with the graphics options for months trying to get the overscan "OK"
Leave it up to Panasonic to label 'overscan' as 'HD Size' even under the Advanced menu settings. Oh well, glad I found this thread. Thanks!
TV: Panasonic 50" ST50 1080p Plasma
Audio: Yamaha Aventage A710 / Polk Audio RM510 5.1
Remote: Logitech Harmony 510 / Logitech MX Air mouse / Lenovo N5902
HTPC: Silverstone SG06 / Intel i7-3770S / XFX 7870 DD / 840 Pro 256GB / Windows 8 Pro / Synology DS413 + 4x3TB WD Red RAID5
Build: http://pcpartpi...
ForeverSilent004 is offline
post #8 of 14 Old 01-03-2013, 08:01 AM
Quoted: 36 Post(s)
Liked: 87
Glad I could help! If you aren't getting it professionally calibrated, be sure to check out D-Nice's reference settings. Enjoy your new TV!
post #9 of 14 Old 01-03-2013, 04:51 PM
Very good, sir. Would you mind linking to the thread?
post #10 of 14 Old 01-03-2013, 05:02 PM
wiggindude's Avatar
Here is the [URL=http://www.**************.com/showthread.php?t=12986#.UOYbjqU5SEk]link [/URL]to D-Nice's reference settings. I recommend reading up on the [URL=http://www.**************.com/showthread.php?t=12986&page=3#.UOYbzqU5SEl]FAQ[/URL] posted on page 3 of that thread.
wiggindude is offline
post #11 of 14 Old 01-03-2013, 05:22 PM
Mind trying again...?
post #12 of 14 Old 01-03-2013, 05:26 PM
Quoted: 36 Post(s)
Liked: 87
Ugh, AVSForum has this absolutely juvenile policy that prevents you from posting links to one particular website.
Try this: http://www.controlcal.com/forum/showthread.php?p=6601
post #13 of 14 Old 01-03-2013, 05:47 PM
Thanks again!
Sorry to turn this into a ST50 thead, but I've had my TV set up since June and have been using it normally. I suppose I would use the second group of settings?
post #14 of 14 Old 01-03-2013, 05:48 PM
Quoted: 36 Post(s)
Liked: 87
Thanks again!
Reply Home Theater Computers
