new to htpc. mpc/hc settings - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-12-2012, 07:50 AM - Thread Starter
gerall's Avatar
Quoted: 50 Post(s)
I'm using a gateway FX series computer/windows 7 connected to my hdtv. media player home cinema plays dvds and ripped blu-rays well, but the video does not appear to be smooth and is a bit jerky. Any recommendations for settings for a novice? I noticed I have a choice of "renderer settings" - set to optimim or default. not sure what to so. thanks.
gerall is offline
post #2 of 6 Old 11-13-2012, 03:31 PM - Thread Starter
gerall's Avatar
Quoted: 50 Post(s)
anyone? thanks
gerall is offline
post #3 of 6 Old 11-13-2012, 06:45 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Can you post more information about your hardware specs.. Processor, MoBo, Video Card, RAM?
How is your HTPC connected to your HDTV?
What is the container and codecs for the content you're atempting to play? What splitters do you have installed on your system?
Help us help you.
Sammy2 is offline
post #4 of 6 Old 11-13-2012, 06:45 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Help us help you.
Sammy2 is offline
post #5 of 6 Old 11-16-2012, 08:33 AM - Thread Starter
gerall's Avatar
Quoted: 50 Post(s)
Sammy, it's a gateway fx6803-35 connected via dvi. 2.8 ghz intel core i7-930 processor, 9 gb ddr3 ram, intel x58 express chipset, ati radeon hd 5850 graphics, 1gb of ddr3 discreet graphice memoy. downloaded mpc-hc didn't adjust anything. not sure about splitters. copied movies to hd via dvdfab to folders. your assistance would be greatly appreciated. (I'm a NOVICE but slowly getting addicted to this and want to learn)
gerall is offline
post #6 of 6 Old 11-16-2012, 09:44 AM
pittsoccer33's Avatar
Quoted: 648 Post(s)
Liked: 426
the first thing id look at is what your CPU usage looks like when youre playing a jerky video.
if its 100% we know where to start. that would mean the video card isnt doing the heavy lifting
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
Reply Home Theater Computers
