Audio Chipsets: VIA VT2021 vs. Realtek ALC887 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 11-13-2012, 10:26 AM - Thread Starter
123
123's Avatar
Hi guys. I am building a HTPC using assassin's guide - I did this last year for my father and I've built quite a few other rigs for myeslf (for other uses). I am doing an Ivy Bridge Build, and want to stick with Gigabyte for the motherboard because of personal preference. So based on assassin's guide, I'm looking at the following boards:
GIGABYTE GA-B75M-D3H
GIGABYTE GA-H77M-D3H
The H77 has a few extra Sata 6.0 Gb ports and more USB 2.0 ports, and small perks like that. None of that really matters for my build. The one difference between the boards I noticed was the audio chipsets. The B75 uses a Realtek ALC887 chipset, while the H77 uses a VIA VT2021 chipset. I am wondering what the difference is in the audio chipsets. Is one notably superior to the other? I know I am probably being way too anal for a casual user like myself, but I like to be thorough. The price difference of 20$ is not really important, if one chipset is better than the other.
Other info: The rig will be used primarily for HD and SD media (tv shows and movies), and secondarily for music and light web browsing.
Thanks in advance!
123 is offline
post #2 of 8 Old 11-13-2012, 10:44 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Are you sending audio to AVR by hdmi ?
If so... Well ...
Mfusick is offline
post #3 of 8 Old 11-13-2012, 10:46 AM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
As Mfusick hinted no difference if you are bitstreaming to a AV receiver.
assassin is online now
post #4 of 8 Old 11-13-2012, 10:50 AM - Thread Starter
123
123's Avatar
Yes, I left that out. Audio and video to be sent to AVR via HDMI. Ok thanks guys, I'll probably just go with the cheaper board then, since there are no features on the H77 that I need. Appreciate the quick responses!
123 is offline
post #5 of 8 Old 11-13-2012, 11:12 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Yup. Either is fine.
Mfusick is offline
post #6 of 8 Old 11-17-2012, 11:54 PM
sumrtym's Avatar
I have a follow-up question. If for now I was relying on HDMI out to a TV but DTS and DD audio tracks out over optical to my speaker set / decoder, would the Via on that board be worse than the Realtek? Or indistinguishable?
P.S. I Know the b75 board he linked to doesn't have optical out, it's a general question regarding the two audio chipsets if you are using the optical out on competing boards.
sumrtym is offline
post #7 of 8 Old 11-18-2012, 04:35 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Indistinguishable. DTS and DD are compressed formats, neither chip can alter them.
renethx is offline
post #8 of 8 Old 11-18-2012, 09:10 AM
sumrtym's Avatar
Just making sure, thanks! smile.gif Been a long time since I've seen other than a Realtek chip for onboard audio.
sumrtym is offline
Reply Home Theater Computers
