Windows 8 scaling? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-13-2012, 12:33 PM - Thread Starter
i3c
i3c's Avatar
I moved my HTPC to Windows 8 and am, so far, really liking it. the netflix app is quite good. WMC works as well as ever.
Having "metro" game apps is very nice.
The main problem right now is that text is a bit hard to read from the couch. The desktop still has the option to enlarge screen elements to make text, etc. bigger.
But that doesn't work on the start screen or metro apps.
Am I missing something? Is there a way to scale metro screen elements?
i3c is offline
post #2 of 4 Old 11-13-2012, 12:59 PM
Chronoptimist's Avatar
Liked: 532
On the Metro start screen, do a search for size (just start typing to search) and it should bring up the "Make everything on your screen bigger" option under settings.
Chronoptimist is offline
post #3 of 4 Old 11-14-2012, 10:35 AM - Thread Starter
i3c
i3c's Avatar
That's it. Perfect. thanks!
i3c is offline
post #4 of 4 Old 11-14-2012, 11:46 AM
jprovence's Avatar
This a certainly something that needs to be turned on for the HTPC. It completely transforms metro into something very usable.
jprovence is offline
Reply Home Theater Computers
