mkv a/v sync issue with WMC7 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-13-2012, 07:46 PM - Thread Starter
augerpro's Avatar
Quoted: 99 Post(s)
Liked: 61
Hi all. Just started converting all my bluray to mkv and playing back with WMC7 and shark007 package (LAV). I have an issue where every time I pause the movie, the audio is out of sync with the video when I resume playback. If I stop the movie then hit play everything is fine. Anyone seen this before?
augerpro is online now
post #2 of 4 Old 11-13-2012, 08:42 PM
Shark007's Avatar
Quoted: 81 Post(s)
Liked: 73
I havent experienced your issue, but do have a suggestion
For 64bit Media Center playback, make changes in the 64bit app.
on the MKV TAB of the Settings Application
Haali is set as the current default, try selecting the LAV splitter.
If that doesnt correct it, tell me about your audio setup.
Use Shark007 Codecs and retain your sanity.
Shark007 is offline
post #3 of 4 Old 11-13-2012, 10:28 PM - Thread Starter
augerpro's Avatar
Quoted: 99 Post(s)
Liked: 61
I already run LAV splitter for mkv. My audio is optical from Realtek chip to Denon receiver.
post #4 of 4 Old 11-14-2012, 07:54 AM
Shark007's Avatar
Quoted: 81 Post(s)
Liked: 73
using a different splitter would be my 1st choice towards a resolution so Try Haali's instead.
I've never had an optical connection for testing.
The only other suggestion, which you probably have correctly set already,
is to select AC3/DTS only on the Audio TAB
For testing purposes, I would connect to anolog.(speakers to the green output jack)
and test with that to see if the issue is only with the optical. Maybe a driver update will help.
Shark007 is offline
Reply Home Theater Computers
