begginner's advice please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-18-2012, 11:28 PM - Thread Starter
tcrosss's Avatar
Hello all.
I have been reading your informative forum for a few weeks now and was hoping for a bit of general advice from the experts. I have built my own PC’s for the last 10 years or so but this time am considering using a shop to build it due to time constraints. I currently have a tower to the side of my TV and run Media portal / XBOX media player for fanart etc. Two weeks ago it died and I have now decided to buy a completely new system. I consider myself a ‘novice builder’ as it is only every couple of years when the PC dies and I am in need of an upgrade that I research parts and build.
The main purposes of my HTPC:
• A media player,
• to dload movies,
• tv capture,
• general browsing and email,
• gaming,
(I am aware that gaming is not the norm for a HTPC however I will just put up with the fan noise and minimise the noise as best I can)
Also to note:
- I intend to hook up my current storage drives to the new system (2 X 2 terabyte SATA, 3 X 1 terabyte SATA, 2 x small IDE drives)
- audio output to amp and then to 5+1 speaker setup,
- video output directly into HDTV via DVI/HDMI,
- I would like to control some functions by remote but will also have wireless keyboard and mouse hooked up.
- I am not sold on windows 8 however I understand there are enough threads about that already
- I can probably save myself $100 easily with the build and maybe another 100-150 with searching for cheaper parts (Australia) however I am happy with paying $250 extra for the convenience of buying from a shop with support
I have procured a quote from a local PC build shop and was hoping for some advice around the proposed componentry. Specifically if I have gone overboard anywhere in particular or if there are much better products available at a similar price point. Furthermore the case may prove to be too hot because of a lack of ample side venting?
My budget is in the region of 2k USD/AUD
Thank you all very much in advance for your assistance:
chip- Intel Core i5-3570 Processor $205.00
board- GIGA Z77X-UD5H-WB MB $268.00
Ram- 16G CORSAIR VENGEANCE 1600 CL9 $95.00
SSD- Intel 520 120GB SSD $145.00
Sata drive - 2TB SEAGATE BARRACUDA 64MB 3.5 $99.00
GFX- GAINWARD GTX660 Ti OC 2GD5 $349.00
Case- SILVERSTONE LC16B-MR BLK D/T $259.01
Power- 750W CORSAIR AX-750 $213.00
Chipfan- NOCTUA NH-L9i CPU COOLER LOW PROFILE LGA 1155/56 $53.00
case fans - 2 X NOCTUA 92MM NF-B9-1600 FAN $21.00
Soundcard- SOASXONARD1 $79.00
Tvcard- Leadtek Winfast DTV1000S PCI - HDTV $31.00
OS- MS WINDOWS 8 PRO 64BIT OEM $147.99
Drive- PIONEER BLURAY WRITER $109.01
Misc- SYSTEM BUILD LABOUR CHARGE $89.99
TOTAL $2,164.00
Cheers,
tcrosss
tcrosss is offline
post #2 of 6 Old 11-19-2012, 09:28 PM - Thread Starter
tcrosss's Avatar
Hi all - a quick update to the above: due to the amount of hard drives i intend to install i am going to change the case choice to a Silverstone GD08 and fill it with Noctua 120mm PWM fans.
Therefore my new system as it stands looks like this:
Case- SILVERSTONE GD08 BLACK $259.01
rear fans 2 X Noctua 80mm PMW Fan $44.00
case fans 5 X Noctua 120mm PWM coolers $145.00
TOTAL $2,332.00
Thank you in advance for any feedback,
tcrosss
tcrosss is offline
post #3 of 6 Old 11-20-2012, 12:19 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2696
That's serious system
Mfusick is offline
post #4 of 6 Old 11-20-2012, 05:36 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
NOCTUA NH-L9i does not look a good choice for 3570K. Check NH-L9i TDP Guidelines. A low-profile CPU cooler is not necessary in this chassis.
Don't forget to buy 3 x GELID PWM fan Y-cable.
Check Samsung 840 Pro. A lot faster than 520 for the same price.
renethx is offline
post #5 of 6 Old 11-20-2012, 06:54 PM - Thread Starter
tcrosss's Avatar
Thanks for the tips - i will definitely re-assess the cpu cooling fan - good pick up.
And definitely need the Ycable adaptors for 5 fans. My trusty expert salesman did not mention these and said i could only have 4 fans!
Cheers,
tcrosss
tcrosss is offline
post #6 of 6 Old 11-20-2012, 08:19 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
Among the 4 system fan connectors of the mb, only 3 can control the fan speed (with only 1 independent PWM). So connect 2 x side to one, 2 x bottom to another, 2 x rear to the last. Or use Akasa FLEXA FP5 (power from PSU, PWM signal from one of the headers, RPM of one of the fans to the header).
renethx is offline
Reply Home Theater Computers
