Are mounting brackets necessary for a 2.5" SSD? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 27 Old 11-19-2012, 03:33 PM - Thread Starter
C E Jones's Avatar
I'm planning on installing an SSD in my HTPC and I'm wondering if there's any need to bother with mounting brackets. Since SSD's don't have moving parts, it shouldn't be an issue to just toss it into a 3.5 inch bay without brackets, right? I never move the computer around, so it should stay put. Will this work, or should I just go with brackets to be on the safe side?
C E Jones is offline
post #2 of 27 Old 11-19-2012, 04:10 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Most good SSD models come with a 2.5" to 3.5" adapter so just check the model you buy.
Often better level SSDs come with this while cheaper ones do not. Example Vertex3 OCZ does but some agility3 doesn't.
What SSD are you looking at?
Most SSD are 2.5" and most case bays are 3.5" so if it doesn't come with it just buy the adapter separate. They are cheap and easily available.
Mfusick is offline
post #3 of 27 Old 11-19-2012, 04:49 PM
flocko's Avatar
Or just spend $2 for some Velcro and call it a day
flocko is offline
post #4 of 27 Old 11-19-2012, 04:50 PM
aliaskary77's Avatar
Quoted: 46 Post(s)
Liked: 56
i personally would make sure it doesnt move at least. vibration from other components can affect it. i might even use velrco or padded double sided tape at least. :P
aliaskary77 is offline
post #5 of 27 Old 11-19-2012, 05:16 PM
josrq's Avatar
Mine is held in place with 2 wire ties. I have some closed cell packing foam between the bracket and the ssd.
josrq is offline
post #6 of 27 Old 11-19-2012, 05:37 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Two sides tape would work just fine but honestly an adapter costs couple bucks so just do it right .
Mfusick is offline
post #7 of 27 Old 11-19-2012, 05:45 PM
Karyk's Avatar
Quoted: 225 Post(s)
Liked: 44
Not quite the same thing, but back with whatever the last version of Windows was where the install program did not recognize CD drives, I kept a floppy drive in the base of a tower computer, just in case I needed to do a clean install. It was not hooked up to anything, or tied down in any way. It never caused an issue. Gravity is a wonderful tool.
Karyk is offline
post #8 of 27 Old 11-19-2012, 05:50 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I'd just get an SSD that came with adapter.
Vertex3 SSD 120GB is on sale Black Friday for $49 and comes with adapter.
There's no reason to be cheap and do it half assed IMO
Mfusick is offline
post #9 of 27 Old 11-19-2012, 06:15 PM
flocko's Avatar
flocko is offline
post #10 of 27 Old 11-19-2012, 09:13 PM
StinDaWg's Avatar
Quoted: 451 Post(s)
Liked: 216
But that's the thing. There is no need for an adapter if you have some 3m tape laying around. You won't even see the hard drive with the side cover on so what does it matter? I had mine taped for a year or so, then I took it out to move it and it was stuck on there so well it look a few minutes to carefully peel it off. It's not going anywhere. smile.gif
I didn't even bother re-taping it into the new pc. It's just sitting inside and it's not going anywhere since I never move it.
StinDaWg is offline
post #11 of 27 Old 11-19-2012, 11:20 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 911
Right now I have an SSD in an adapter bracket mounted in the 3.5" external bay on my HTPC. I'm thinking of adding a card reader to that hole and if it means I have to move the SSD to do it I guess I'll be going all half assed on you and sticking it down with a bit of Velcro...Wanna buy a slightly used bracket? tongue.gif
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #12 of 27 Old 11-20-2012, 12:41 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Lol...
I've done it.
I've actually not mounted HDDs too...
Gravity does most if the work .
But if you know upfront my point is its easy enought to do it right.
My hhlalf ass attempts are usually cause I don't have what it takes to do it right.
I can't beat anyone up too much since I do it too.
Mfusick is offline
post #13 of 27 Old 11-21-2012, 09:44 AM - Thread Starter
C E Jones's Avatar
How much for the used bracket? And is shipping included or extra? biggrin.gif
It was more out of laziness than cheapness that I asked, but I guess if the SSD I buy comes with one I'll use it. Thanks for all the tips smile.gif
post #14 of 27 Old 11-22-2012, 09:49 PM
kesawi's Avatar
Quoted: 30 Post(s)
Liked: 25
If you have a 3.5" bay just mount one side of the SSD. They're light and rigid enough that it shouldn't be a problem.
kesawi is offline
post #15 of 27 Old 11-22-2012, 10:03 PM
ilovejedd's Avatar
Quoted: 76 Post(s)
Liked: 67
Huh? We are talking about SSDs and not HDDs, right?
ilovejedd is offline
post #16 of 27 Old 11-22-2012, 10:07 PM
ilovejedd's Avatar
Quoted: 76 Post(s)
Liked: 67
I'd like to know where. TigerDirect website has it for $109.99 and Newegg's already sold out. *sigh* Dunno how I missed the deal. I kept checking Newegg throughout the day.
Edit:
Great. Just refreshed my browser and it's down to $49.99 but looks like TigerDirect's servers are getting hit heavily. I'm getting a server error trying to check out.
post #17 of 27 Old 11-22-2012, 11:10 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Edit:
Yup.
I tried about 15 times before it took my order.
I checked with my Credit Card statement and it appears pending.. so I think I got one.
Mfusick is offline
post #18 of 27 Old 11-22-2012, 11:11 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Mfusick is offline
post #19 of 27 Old 11-23-2012, 04:58 PM
JoshDorhyke's Avatar
That's all I do. Run 1 screw through a hole into the drive. Bend and formed the cables so they weren't going to stress the connectors (which I do anyways with the SATA ones) and plugged them in. There really is no need for the bracket unless you want to be able to throw the PC around.
JoshDorhyke is offline
post #20 of 27 Old 10-02-2013, 12:53 PM
Kelsea's Avatar
Hi guys,
Personally, I would get a reliable with high rating converter bracket for my SSD, yet it is not cheap nor expensive. (let say 5-12 bucks at most?) What do you know, SSD price does get cheaper but it is still not that cheap. It is just my thought. :) I hope this comment helps you guys!
Kelsea is offline
post #21 of 27 Old 10-02-2013, 02:11 PM
user4avsforum's Avatar
Any of these will work fine. I have used Velcro and have also hung one vertically with two screws from the top of a 3.5" multi-drive bay.
user4avsforum is offline
post #22 of 27 Old 10-02-2013, 03:49 PM
mud sloth's Avatar
Originally Posted by Kelsea View Post
Hi guys,
Personally, I would get a reliable with high rating converter bracket for my SSD, yet it is not cheap nor expensive. (let say 5-12 bucks at most?) What do you know, SSD price does get cheaper but it is still not that cheap. It is just my thought. smile.gif I hope this comment helps you guys!
This thread was nearly a year old..... Just....why?
mud sloth is offline
post #23 of 27 Old 10-02-2013, 06:31 PM
Dark_Slayer's Avatar
Quoted: 655 Post(s)
Liked: 434
You went over your 2 post per year average to point out a Necromancer biggrin.gif
Dark_Slayer is offline
post #24 of 27 Old 10-03-2013, 05:23 AM
captain_video's Avatar
Quoted: 510 Post(s)
Liked: 336
I usually keep an eye on the various deal websites and pick up items like 2.5" to 3.5" adapter brackets when they're cheap. That way I've always got one on hand when I need it. I think I've still got a few brackets waiting to be put to good use.
captain_video is offline
post #25 of 27 Old 10-04-2013, 02:30 PM
DanPackMan's Avatar
Quoted: 228 Post(s)
Liked: 379
I am going to make you all wait and post my opinion on this next year. smile.gif
DanPackMan is offline
post #26 of 27 Old 10-04-2013, 02:37 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
lol
Mfusick is offline
post #27 of 27 Old 10-05-2013, 07:24 PM
ikkuranus's Avatar
Quoted: 86 Post(s)
Liked: 53
Mine is held in place by the bundle of unused cables from my psu. Before anyone says your 600t has 6 2.5 compatible sleds I already know. I chose not to use them at least till I have more then 1 drive in the upper 3.5/2.5 cage.
ikkuranus is offline
Reply Home Theater Computers
