How do you like my build? Nearly silent ~$500 - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 76 Old 11-23-2012, 06:28 AM - Thread Starter
elliscs's Avatar
elliscs is offline
post #62 of 76 Old 11-23-2012, 06:42 AM
ljo000's Avatar
Thats a great build for the money. Also check out the SiliconDust HDHomeRun Prime on Newegg for $130 if you want a cableCARD tuner.
ljo000 is offline
post #63 of 76 Old 11-23-2012, 08:43 AM
fifteenfeetoff's Avatar
I'd have gotten the 180gb Intel 330 for $100 over that SSD. OCZ scares me.
Edit: What brand and size TV are you looking to get?
fifteenfeetoff is offline
post #64 of 76 Old 11-23-2012, 09:16 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Technically- The OCZ is a better reliability choice. This is validated by AnandTech and other professional review sites.
While you make dislike OCZ for personal reasons that's cool- but here is some facts:
OCZ has full 5 year Warranty.
OCZ Vertex 4 uses the same Marvel controller that everyone raves about as most reliable (same as Crucial M4 and many other popular SSDS)
OCZ uses the same sources NAND inside as most others
OCZ is faster, higher performance
OCZ is Cheaper
In comparision- The Sandforce controllers have been suspect in certain areas on performance and even with Intel. It seems the TRIM might not work properly because of the Sandforce design.
Sandforce controllers are still a great option and work well. I have over 10 of them.
But I thought I'd provide a more balanced opinion.
Saying you don't like a brand is fine. But assuming others share your same fear and then suggesting someone spend more on much less makes little sense to me.
Mfusick is offline
post #65 of 76 Old 11-23-2012, 09:38 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Some more about Intel: Looks like the 320 has had some bugs of it's own.
http://communities.intel.com/message/133499
http://www.anandtech.com/show/4625/intel-testing-firmware-fix-for-ssd-320-8mb-power-bug
More on this- What makes you think the Intel is more reliable than the OCZ?
Here's an interesting article I read today:
http://www.anandtech.com/show/6107/corsair-force-series-gs-240gb-review
Introduction to the TRIM Issue
TRIM in SandForce based SSDs has always been trickier than with other SSDs due to the fact that SandForce's way to deal with data is a lot more complicated. Instead of just writing the data to the NAND as other SSDs do, SandForce employs a real-time compression and de-duplication engine. When even your basic design is a lot more complex, there is a higher chance that something will go wrong. When other SSDs receive a TRIM command, they can simply clean the blocks with invalid data and that's it. SandForce, on the other hand, has to check if the data is used by something else (i.e. thanks to de-duplication). You don't want your SSD to erase data that can be crucial to your system's stability, do you?
As we have shown in dozens of reviews, TRIM doesn't work properly when dealing with incompressible data. It never has. That means when the drive is filled and tortured with incompressible data, it's put to a state where even TRIM does not fully restore performance. Since even Intel's own proprietary firmware didn't fix this, I believe the problem is so deep in the design that there is just no way to completely fix it. However, the TRIM issue we are dealing with today has nothing to do with incompressible data: now TRIM doesn't work properly with compressible data either.
All that aside- Intel is an excellent SSD choice and a good value at $99. I like Sandforce Drives and I like Intel.
My point is just that I saw no point in your post when the OP just posted he already bought and made a decision. Suggesting he made a mistake is not productive at that point, his decision had been made.
Personally I admit to everyone I hate Crucial SSD's and I often do post some feelings I have about how they are generally overated- But I try not to post that to someone who just bought one. It's just not polite.
I'd have overlooked your post more I agreed and felt there was some valid reasons to your point. But my common sense showed me 5 years warranty vs 3 years warranty- Faster performance specs- and $25 cheaper- Plus no Sandforce Controller inside... It all just adds up with my math to a better choice. Vertex4 > Intel 320
Mfusick is offline
post #66 of 76 Old 11-23-2012, 09:51 AM - Thread Starter
elliscs's Avatar
I won't sweat my decisions. The SSD won't be important for storing video permanently. Mainly running the os, and streaming. I'll back up my config on my main computer.
I haven't decided on the TV. I was seriously looking at the Vizio M3D550KD but it is now more expensive on Amazon. I'm going to have to do a lot more research now that that one is out of the picture. I refuse to go to BestBuy today. They had tape on the floor around the store designating lines.
elliscs is offline
post #67 of 76 Old 11-23-2012, 10:10 AM - Thread Starter
elliscs's Avatar
Anyone's thoughts on this one?
Samsung 55 Inch 1080p 120Hz
elliscs is offline
post #68 of 76 Old 11-23-2012, 10:21 AM
jeffkro's Avatar
jeffkro is offline
post #69 of 76 Old 11-23-2012, 10:22 AM
jeffkro's Avatar
My dad has a samsung 55" from a couple of years ago, its got a great picture.
jeffkro is offline
post #70 of 76 Old 11-23-2012, 10:23 AM - Thread Starter
elliscs's Avatar
Originally Posted by jeffkro View Post
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371033
I really like these PSU's, saves you a little money.
earthwatts 380W
Already bought one, but thanks though.
elliscs is offline
post #71 of 76 Old 11-23-2012, 10:32 AM
ljo000's Avatar
I bought an LG 55LM7600 a couple of months ago an I love it. Beautiful picture and a thin bezel. Other features it has that I don't use are reasonably good sounding speakers, "magic" motion sensing remote, smart TV apps, and 2D to 3D conversion. Amazon had a deal where you got the TV, 12 pairs of glasses and a LG BluRay player for $1,400.
ljo000 is offline
post #72 of 76 Old 11-23-2012, 10:45 AM - Thread Starter
elliscs's Avatar
Looks like a great deal. How does the 2D to 3D conversion look? I had seen that mentioned, but figure it was above my budget. I was looking around the $1000 mark. I have some money to work with, but this is our first house and we have tons of other stuff to buy as well. (Fridge, dining table, shovel, and other nonsense)
elliscs is offline
post #73 of 76 Old 11-23-2012, 01:34 PM
ljo000's Avatar
I think the conversion is kind of cool but very dependent on what your watching. I haven't tried video games yet but I think it would look pretty good.
ljo000 is offline
post #74 of 76 Old 11-23-2012, 04:02 PM - Thread Starter
elliscs's Avatar
Originally Posted by renethx View Post
Compare:
- WH14NS40: the latest model, 165mm deep
- WH10LS30K: 3-year old, 172mm deep
I strongly recommend WH14NS40 (OEM) or BH14NS40 (retail, that comes with a bunch of software including PowerDVD 10 [not the latest version]).
The space between PSU and ODD is small and sleeved cables may be difficult to handle. But don't complain to me. smile.gif
I don't think you need case fans. The system runs pretty cool.
Just realized I never updated to the WH14NS40, do you think it will be a problem?
elliscs is offline
post #75 of 76 Old 11-23-2012, 04:12 PM - Thread Starter
elliscs's Avatar
Ordered this through Amazon, asked for a cancellation. Will see if they give it to me. If they do I'm definitely going with the other one. *Facepalm*
elliscs is offline
post #76 of 76 Old 11-27-2012, 05:29 PM - Thread Starter
elliscs's Avatar
Got the PSU and case today. Rest should come tomorrow.
elliscs is offline
Reply Home Theater Computers
