How do I fix "TV ARCHIVE" service using Win 7 HTPC and WHS2011 Server? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 11-19-2012, 06:36 PM - Thread Starter
tomandbeth's Avatar
It was working until recently.
In WMC I get the error message "INVALID APPLICATION. UNABLE TO LAUNCH "TV ARCHIVE" "
I did try starting the program in services, program started than stopped with message indicating this would be normal unless the service was needed.
Some background:
I did have this working flawlessly until last weekend. My Server had started to freeze up, and in anticipation I stopped Archive in WMC
so I wouldn't lose recordings in the event I had to do a full OS rebuild. Found one of my memory modules wasn't seated correctly.
I also added the High Point 8 post SAS card listed in Assassins Server guide as well as replaced the Server Drives/Rebuilt Flexraid
while the Server was down...
help...please?
tomandbeth is offline
post #2 of 8 Old 11-19-2012, 06:55 PM
lockdown571's Avatar
Quoted: 71 Post(s)
Liked: 95
lockdown571 is online now
post #3 of 8 Old 11-19-2012, 08:02 PM - Thread Starter
tomandbeth's Avatar
No I haven't. I did find that and a registry hack while rooting around. While neither SEEM to address how I got in this bind, I could give it a try. A third option would be to re-install WHS2011 on the server, I suppose.
I do appreciate your help. As the only change to the Server OS was due to installation of the SATA card, I was thinking the issue was something in the HTPC....
post #4 of 8 Old 11-20-2012, 06:50 AM
ncarty97's Avatar
Quoted: 77 Post(s)
Liked: 43
Don't reinstall WHS2011. There is a hack (not sure if it is the registry hack you are referring to) where you edit some XMl files, but it breaks MediaBrowser.
Follow the instructions in that support doc lockdown posted. I did this last weekend. It was pretty easy:
1) Uninstalled the WHS connector from the HTPC.
2) Rolled back the update on the WHS, didn't take but a few minutes
3) Reinstalled WHS connector on the HTPC
4) Reinstalled the update on WHS
Total time was less than 20 minutes. Only caveat was that I ended up having to reinstall the connector on each of my client PC's, even after the update was put back on. Not a big deal to me though and the archive works perfect now.
Carty Custom Builders, LLC
ncarty97 is online now
post #5 of 8 Old 11-20-2012, 10:51 AM - Thread Starter
tomandbeth's Avatar
OK. Thank you.
So if I'm grasping this correctly, the "TV Archive" that is failing to launch is on the SERVER, and not the HTPC. Interesting.
Once again, thanks to both of you for "educumating" me.
post #6 of 8 Old 11-20-2012, 11:26 AM
NNate's Avatar
Quoted: 57 Post(s)
ncarty97 and lockdown571 have the right solution. I had this problem too when I reinstalled Windows 7 on my PC a month ago. The steps in that doc solved the issue.
NNate is offline
post #7 of 8 Old 11-20-2012, 06:49 PM
ncarty97's Avatar
Quoted: 77 Post(s)
Liked: 43
Originally Posted by tomandbeth View Post
OK. Thank you.
Sort of. The Archive itself (where you store stuff) is on the server. The application is part of the WHS connector software. They made some change in the last roll up (something to do with .net versions IIRC) that messed up the app if you install off WHS after the roll up. The new version apparently works fine if it is pushed out to an existing installation from before the roll up. Hopefully MSFT will fix this.
post #8 of 8 Old 11-26-2012, 09:32 PM - Thread Starter
tomandbeth's Avatar
Thanks to lockdown571 and ncarty97 I have everything back to normal
It's also nice to have the household back to normal after Thanksgiving,
How does one invite their sister WITHOUT the brother-in- law?
Reply Home Theater Computers
