Is my processor holding back 1080p? - AVS Forum
post #1 of 5 Old 11-20-2012, 02:05 PM - Thread Starter
ps2cho's Avatar
HTPC:
AMD BE-3200 1.9GHz Dual Core
2GB RAM
HD4550 512MB.
Using Serviio as the player streaming to the PS3, 720p video is showing ~40-55% cpu utilization.
Is my graphics card offloading the data or is this older AMD dual core struggling?
ps2cho is offline
post #2 of 5 Old 11-20-2012, 02:51 PM
jdmag00's Avatar
Are you trying to transcode with servio? If so the CPU might be your issue I have an amd 250u 1.8ghz DC that works fine in my htpc with a 5450 but the video card takes care of most of the work. In your case I don't think video is doing much of anything.
Sent from my DROID BIONIC using Tapatalk 2
jdmag00 is offline
post #3 of 5 Old 11-20-2012, 09:51 PM
Ryan__M's Avatar
Yeah doesn't sound like your vid card is helping at all. I have an HTPC with probably a fairly equivalent vid card and C2D E6300 and I get ~5% CPU usage playing BD's. Check the setting in the software to see if 'hardware acceleration' or some similarly names setting is enabled.
Ryan__M is offline
post #4 of 5 Old 11-20-2012, 10:46 PM
erickotz's Avatar
Liked: 30
is one of your CPU cores pegged, and the other nearly idle?
Quality Assurance Manager, Ceton Corporation
erickotz is offline
post #5 of 5 Old 11-25-2012, 11:12 PM - Thread Starter
ps2cho's Avatar
Maybe it is a driver issue then...I'll update the ATI drivers and see if that helps.
I would have thought the 65nm 1.9GHz /w HD4550 should be enough. The HD4550 says its easily 1080p capable.
ps2cho is offline
Reply Home Theater Computers
User Tag List
