Critique my "budget build" - AVS Forum | Home Theater Discussions And Reviews
post #1 of 25 Old 11-20-2012, 03:59 PM - Thread Starter
Badfish740's Avatar
After exhaustively reading Assassin's HTPC build guide and browsing a few more places I came up with the following "budget build." As I've stated before, my HTPC needs are quite modest compared to most. Basically I'm just looking for more flexibility than a Roku or Boxee unit offers, but not a full on 3D/gaming unit. This HTPC needs to:
Playback 1080p content from internet sources (Netflix, Hulu, etc...), OTA TV, and cable
Function as a DVR to record said sources (while simultaneously watching another source/channel)
Play DVD, CD, and Blu-Ray discs
Rip DVDs and CDs to the hard disc (not Blu-Rays, just old movies and music that we already have-new stuff we can stream)
Here is my parts list-criticism welcome and encouraged:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811121100&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10446076&PID=4176827&SID=1lt4qg3ub4pex
Black 0.7mm Thickness SECC Steel 7K09BBA30FNRX Micro ATX Media Center 300W Power Supply / HTPC Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16813135288&nm_mc=OTC-pr1c3grabb3r&cm_mmc=OTC-pr1c3grabb3r-_-Motherboards+-+Intel-_-ECS+(EliteGroup)-_-13135288
ECS H61H2-M2(1.0) LGA 1155 Intel H61 HDMI Micro ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116399&Tpk=G620
Intel Pentium G620 Sandy Bridge 2.6GHz LGA 1155 65W Dual-Core Desktop Processor Intel HD Graphics BX80623G620
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231643&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10446076&PID=4176827&SID=2obfq6urkt8x
G.SKILL NS Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Desktop Memory Model F3-1333C9D-8GNS
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152379
SAMSUNG Spinpoint F3 ST1000DL004 / HD105SI 1TB 5400 RPM 32KB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106374&nm_mc=OTC-pr1c3grabb3r&cm_mmc=OTC-pr1c3grabb3r-_-Blu-Ray+Drives-_-Lite-On-_-27106374
LITE-ON Black 12X BD-ROM 16X DVD-ROM 48X CD-ROM SATA Internal Internal 12X Blu-ray Combo Model ihes112-04 - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16815116037
Hauppauge WinTV-HVR-2250 Dual TV Tuner w/ MPEG-2 Encoder PCI-E x1 - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16880101002
Rosewill RRC-126 Windows Vista/Window7 MCE/Windows 8 MCE Infrared Remote Control
With the cost of Windows 7 (I get an employer discount) I think I can do it all for about $545-thoughts?
Badfish740 is offline
post #2 of 25 Old 11-20-2012, 04:08 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
You seem budget conscious so I would get the G630 over the G620 for 5$ cheaper.
I'd also get the 39$ MSI z68 board newegg had instead if the lower quality H61.
Wait for a few Black Friday deals.
Mfusick is offline
post #3 of 25 Old 11-20-2012, 04:09 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Oh and there's a deal on the faster/better DDR3 to match the z68 chipset.
Mfusick is offline
post #4 of 25 Old 11-20-2012, 04:29 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
renethx is offline
post #5 of 25 Old 11-20-2012, 04:58 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Mfusick is offline
post #6 of 25 Old 11-20-2012, 06:52 PM
Mike99's Avatar
Quoted: 133 Post(s)
Liked: 63
Badfish740,
I have the same ECS mobo with a G620 & it works just fine. Sometimes the mobo goes on sale for about $25 & IIRC once it was only $15. I'm not saying it's the best but it works for me. It does have only 3 slots but that's all I needed, two PCIe x1 and one PCIe x16. Has HDMI output & also a SPDIF header on the mobo in case you need digital coax audio out.
The Rosewill RRC-126 also works quite well. They give you a software disc but no clear explanation what it really does. It is used if you want to use and/or make Netflix a default with remote. But there is no need to install any software in order to use the remote with WMC.
Mike99 is offline
post #7 of 25 Old 11-20-2012, 07:09 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Mfusick is offline
post #8 of 25 Old 11-20-2012, 07:22 PM
LastButNotLeast's Avatar
Quoted: 1486 Post(s)
Liked: 1084
Or the G540 for $50 (I'm using a G530, and it's perfectly adequate for non-3D material).
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116408
Michael
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
LastButNotLeast is offline
post #9 of 25 Old 11-20-2012, 07:25 PM
Liked: 1084
For BD, you'll need software, TMT5 or PowerDVD. Otherwise, you'll need to rip with MakeMKV then play it back with standard stuff.
post #10 of 25 Old 11-21-2012, 09:46 AM - Thread Starter
Badfish740's Avatar
Wow-didn't even know these were out there-thanks! It looks like this would save quite a bit of time and money-looking forward to learning more about them. Of course now I see that it's sold out. Is that because it was such a low price or do they always discount them that much? Will they go on sale that low again once they get more in?
post #11 of 25 Old 11-21-2012, 10:56 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Mfusick is offline
post #12 of 25 Old 11-21-2012, 11:07 AM
anikun07's Avatar
Quoted: 32 Post(s)
Liked: 47
Corel has a black friday sale with WinDVD 11 marked down to $40. I preferred TMT5 with my trials, but that's a good price on the software and probably the cheapest for a retail media software.
Also, if your system specs are lower you could always speed things up with a faster HDD. I wish I'd seen this post previously. Newegg had a 300 GB WD Velociraptor drive for $70 and it made system responsiveness a lot better. Personally, I think the HDD is the slowest component, even with just the OS on the drive everything is speed up. I think you're build looks good and will get the job done. I hope you enjoy it when it's all set up.biggrin.gif
anikun07 is offline
post #13 of 25 Old 11-21-2012, 12:09 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
That's why it should be illegal to use a HDD instead SSD for OS
Even velociraptor 10k rpm are terribly slow for OS installations.
Mfusick is offline
post #14 of 25 Old 11-21-2012, 12:12 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Sorry I missed this earlier.
Yes it should come back in stock.
One of those with a 49$ vertex3 SSD 120gb.
Some $20 ddr3 1600mhz 8gb
You have a decent little HTPC cheap.
You could at 3tb of storage for 89$ with the Seagate drive I linked too
Mfusick is offline
post #15 of 25 Old 11-21-2012, 04:49 PM
Liked: 1084
I must be the only one on the planet not impressed with switching to an SSD. If you shut down your computer or restart it frequently for some reason, boot times will be much faster. But if you put the computer to sleep, waking up is not that much faster, and I noticed almost no improvement in Media Browser, TMT, or other programs loading and running. And, of course, your media files are on HDD, so they aren't affected at all.
Just so you know you're not totally missing out if you need to put the OS on an HDD.
post #16 of 25 Old 11-21-2012, 07:49 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Your the only one. You must have fine something wrong.
For me it's night and day.
I can't operate a PC without SSD. It's way too slow.
Mfusick is offline
post #17 of 25 Old 11-21-2012, 07:54 PM
sidefx79's Avatar
@LastButNotLeast: You have AHCI selected\enabled in BIOS right? and what OS?
sidefx79 is offline
post #18 of 25 Old 11-21-2012, 08:13 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Something was obviously wrong. No modern hardware build with quality SSD couldn't be noticeably improved vs a HDD.
That's impossible.
Mfusick is offline
post #19 of 25 Old 11-21-2012, 09:45 PM
Liked: 1084
Yes. Win 7 whatever (as per Assassin).
Speed tests show it's working (I think), I'm just not impressed with much of a difference in normal usage, and I think his money is better spent elsewhere.
I've tried different ports (it's SATA 3, 6Gb/s, as is the mb, which makes absolutely no difference to it or the HDDs I have), drivers, the usual stuff (I've been doing this type of thing for more decades than I care to admit). It's not that I'm unhappy, I just don't seem to be as enthused as everyone else.
And if you're putting together a "budget build" (as was my original plan, too), a separate partition on a big HDD works fine.
post #20 of 25 Old 11-21-2012, 10:22 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
That tuner has limited usability. Fine if your source is an antenna and OTA but for cable, most systems have limited NTSC and Clear QAM, if any. The FCC basically gave CATV companies free reign to scramble everything so even if you still have Analog and Clear QAM on your cable don't count on it lasting.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #21 of 25 Old 11-21-2012, 11:35 PM
fventura03's Avatar
if you have a MicroCenter near by, the G550 is $34.99 and its sufficient for HTPC, use some of the money saved from not picking up the Pentium processor and upgrade to SSD. way better investment and it'll run a lot smoother and faster.
instead of the TV Tuner you chose, I'd get an HDHomeRun Dual, it plugs into your router, and to your cable line.
http://www.newegg.com/Product/Product.aspx?Item=N82E16815345007
8gb for 31.99 is pretty good, MicroCenter has 4gb for 17.99 if you really wanted to save more money, and 4gb is plenty. some of my HTPC's have 2gb smile.gif
fventura03 is offline
post #22 of 25 Old 11-22-2012, 05:28 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Superbiz has great CPU prices btw.
You can get better CPU for like $50.
G850 or 860 is basically an i3 for $10 more.
If you looking at g530 for $35 you can step up for small charge and still stay well under i3 prices.
Mfusick is offline
post #23 of 25 Old 11-22-2012, 07:50 AM - Thread Starter
Badfish740's Avatar
I'm a little confused-I was told that the Hauppauge tuner would take a cable card (looks like a credit card) from my cable company that I would have to rent for $1.50 a month or so instead of a box and that would allow me access to all channels. Am I not understanding this correctly? Does the HDHomeRun Dual accept a cable card?
post #24 of 25 Old 11-22-2012, 08:17 AM
C17chief's Avatar
Liked: 24
For a regular machine sure, especially as affordable as SSD's are becoming vs their performance. For a budget HTPC however...budget being the key word here...it is hardly necessary. Even the $40 or so you can get a 64gb one for is better spent on a TB or 2 larger hdd if not simply saved to lower the overall cost of the machine. Except for startup and shut down, they really dont add enough to be considered essential on an HTPC. With or without doesnt make any difference with any video playback, and while they can make menu transitions and such slightly faster in some cases moving around the software frontend, it will hardly make or break the experience.
Out of 4 pc's in my home, the HTPC is the only one without one and I still have no intention on adding one due to this. I actually did give in to that notion once before....decided screw it, they are really cheap, why not after coming across another good deal after all my other machines already had em. Set it up in the HTPC and wasnt all that impressed with the difference. Since the SSD was identical to the one in my main desktop, I pulled it from the HTPC to use in the desktop in raid configuration where it would be much better served. smile.gif
C17chief is offline
post #25 of 25 Old 11-22-2012, 06:50 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
No, but the HDHR Prime does: http://www.newegg.com/Product/Product.aspx?Item=N82E16815345006&Tpk=HD%20Homerun%20prime. This Hauppauge does cable card: http://www.newegg.com/Product/Product.aspx?Item=N82E16815116072 as does this Ceton: http://www.newegg.com/Product/Product.aspx?Item=N82E16815706001. If your source is cable I wouldn't bother with a Clear QAM tuner unless you want to gamble that your cable provider isn't going to turn it into a doorstop.
olyteddy is offline
Reply Home Theater Computers
