Trying to build a 3D Blu-Ray HTPC for around 500 if possible Ideas Please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 29 Old 11-21-2012, 12:01 PM - Thread Starter
SilverFoxhound's Avatar
Build Updates on 11/27/12 Current Options to be reviewed
Ok here is the new Builds I've thrown together today
For both Options
Case - SilverStone GD04 Usb 3.0 (Black) - $122 with shipping
http://www.google.com/aclk?sa=l&ai=CPcIlrBa1UJHxFOya6wG8r4GwCfmotdQCqeywqELR1sKAlgEIBhABUL7O8ZYBYMm2uIzUpKgQmAHT8gegAeKNs_8DyAEHqgQlT9AtRMvdHmOG-nMgykUZNofxUwkVYXUU0nOGJi8It9baAWYuOLoFEwjz1tmJ8--zAhXlXjQKHYFvAGrABQXKBQCgBibgEozY1-bpg9jL0wE&ei=rBa1UPPQEeW90QGB34HQBg&sig=AOD64_1yH8T2wKhDmLTcHvA7oXHmmYLZUA&ctype=5&sqi=2&ved=0CJ0BEPQO&adurl=http://www.newegg.com/Product/Product.aspx%3FItem%3DN82E16811163179%26nm_mc%3DKNC-GoogleAdwords%26cm_mmc%3DKNC-GoogleAdwords-_-pla-_-NA-_-NA&rct=j&frm=1&q=silverstone+gd04
Power Supply - Rosewell Green Serise 430w - $55 with shipping (Not sure if that is able to be used on this case the other one I found was a Istar usa 400 w for almost double the price)
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=1&cad=rja&ved=0CDAQFjAA&url=http%3A%2F%2Fwww.newegg.com%2FProduct%2FProduct.aspx%3FItem%3DN82E16817182202&ei=uBy1UPmhEKyF0QHgxoDAAg&usg=AFQjCNErwyy1mSGfTBak2ugj0Fuun3cK2Q&sig2=hRbJcrc31OHNpCaWeXEvlw
RAM (4gb) - 2x 2gb - G. Skill DDR3 1333 - $20
http://www.google.com/aclk?sa=l&ai=CS4-5BB61UKOcFO7j6QH2lICwCMmutdQC2ejDjUmZr4eClgEIBRABKAVQsdeb4vr_____AWDJtriM1KSoEJgB1PIHoAHijbP_A8gBB6oEJU_QTyxtLjgLo4M_3xNEW5BfjdgViUFZ5nDkkYeoJHYXwyowPQXABQWgBibgEpLZj6CZz7T_twE&sig=AOD64_3CmnWuBbuSHvNU6QSKZjqr5dA1ww&ctype=5&ved=0CC8Qww8&adurl=http://www.newegg.com/Product/Product.aspx%3FItem%3DN82E16820231252%26nm_mc%3DKNC-GoogleAdwords%26cm_mmc%3DKNC-GoogleAdwords-_-pla-_-NA-_-NA&rct=j&frm=1&q=g.skill+1333+desktop+memory
Wifi - RoseWill PCI - $22.98 (or would a usb stick be a better option?)
http://www.newegg.com/Product/Product.aspx?Item=N82E16833166033
Hard Drive - WesternDigital Green WD10EZRX 1TB - $72.97
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=1&cad=rja&ved=0CFoQFjAA&url=http%3A%2F%2Fwww.newegg.com%2FProduct%2FProduct.aspx%3FItem%3DN82E16822236070&ei=ICi1UL-SLqqK0QGlqIHgAQ&usg=AFQjCNHxXWr8t9L3y8RkEeJ-A44zHIT6RQ&sig2=vtfmtl4i7IJDSCTvdtbkLw
Disc Drive - Lite-ON black 12X BD-R - $54.99
http://www.google.com/aclk?sa=l&ai=C97-vYyi1UJWvIcf36AHztICoDZmQ79IC0cLumBrprtvufggGEAIoA1Cxs8aWBmDJtriM1KSoEJgB0_IHoAHijbP_A8gBB6oEJU_QtuXd4gHE4uzOIJ6jskJpjE57w45s1X72sfl-d1zzi0kMRsjABQWgBibgEqLL4tHd57KImQE&sig=AOD64_1PRDN5e1Jm_cQoxwald-xjIgzaTg&ctype=5&ved=0CIYBEPQO&adurl=http://www.newegg.com/Product/Product.aspx%3FItem%3DN82E16827106369%26nm_mc%3DKNC-GoogleAdwords%26cm_mmc%3DKNC-GoogleAdwords-_-pla-_-NA-_-NA&rct=j&frm=1&q=what+disc+drive+can+play+3d+blu+ray
Sub total - $347.94
Option 1
CPU - Sandy Bridge Lgall Intel I3-2105 - $104.99
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=1&cad=rja&ved=0CEUQFjAA&url=http%3A%2F%2Fwww.newegg.com%2FProduct%2FProduct.aspx%3FItem%3DN82E16819115090&ei=Px-1ULbtE6nI0QHK94HQBw&usg=AFQjCNGkP-kGpYfP7maVfAc_fPmyqJlUow&sig2=Yzf9wYhCqjyUcywvq1NN6w
Motherboard - ASUS P8H67M-EVO - $124.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131710
Totaling @ $577.92
Option 2
CPU - Ivy Bridge I5 3570K Quad Core - $219.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
Motherboard - ASRock Z77 Pro4-M - $125.11
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157306
Totaling @ $693.04
Feel free to make any suggestions and or corrections to my builds. Thank you an critique away.
Original POST
Hi to start,
This is for a friend she wants to spend about $500 on it she already has the 3d tv and the sound system. I'm thinking only 8g dd3 ram should be good and I'm not sure which motherboard or tower to use.
For a Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813135288&nm_mc=OTC-pr1c3grabb3r&cm_mmc=OTC-pr1c3grabb3r-_-Motherboards+-+Intel-_-ECS+(EliteGroup)-_-13135288
For a processor I was looking at
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116399&Tpk=G620
For Ram
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231643&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10446076&PID=4176827&SID=2obfq6urkt8x
I'm wondering if that is strong enough to play 3D
Things that don't need to be included with the build is a remote keyboard or Windows. I'm looking for at least 2 docking stations in a tower that not sure if the compact HTPC Case is the way to go or A Mid size tower any help would be nice I have more parts that I've been looking at but I'm hoping for feed back and help before I set my own list in stone or post them up here.
I'm also wondering if I should use a dual harddrive method with one solid state with the Operating system, an a large slave or just one large harddrive.
Thank you sorry if I wasn't great a posting this I am new to this site.
SilverFoxhound is offline
post #2 of 29 Old 11-21-2012, 03:46 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
Playing 3D is one of the easiest tasks for HTPC (with right hardware components, of course).
The integrated GPU in G620 does not support 3D (precisely speaking, supports MVC decode, but does not support Frame packing). You have to choose: Core i3 or higher, AMD Llano APU (any), AMD Trinity APU (A8 or higher), or add a discrete card (AMD Radeon HD 6xxx or higher, NVIDIA [almost any]). If you happen to have an older HDMI 1.3 AVR, you have to pay a special attention to audio, that's another (a bit complex) subject.
2x2GB RAM is plenty enough for any video playback task, but you can go with 2x4GB (no big price difference).
renethx is offline
post #3 of 29 Old 11-21-2012, 04:06 PM - Thread Starter
I'm pretty sure the TV is going to be the 1.4 hdmi It's a VIZO M-Series 47". I just looked up the specs and it does have it, and I was leaning towards the Nevda Geforce 630 I believe but was curious do I need one or two for just Blu ray 3D movies. There is going to be NO GAMING on this pc and I've been researching for myself to build a gaming HTPC, so I'm not sure if the for 3d video if you need one or the dual graphics card. When reading up on other things I get the impression that Yes you do But i could be misunderstanding.
Also what case would you recomend the mid size towers or the HTPC compact looking cases?
post #4 of 29 Old 11-21-2012, 10:27 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
A single graphics card is enough.
I like SilverStone GD04.
renethx is offline
post #5 of 29 Old 11-21-2012, 11:50 PM - Thread Starter
Is that one more reliable the nvidia when i asked a couple of people in person they steered me away from that and towards amd by telling me nvidia gave them some problems every time they bought their cards. Not the company but the product to be more clear on why they said.
But im very new to 3d so my minds a huge sponge at the moment but im defently going to check that brand out to the more options i have the better.
post #6 of 29 Old 11-22-2012, 03:03 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
IMO AMD Trinity A8/A10 is the best choice in the mid-range section, I don't see a good reason to add a discrete card to a cheap Intel CPU. GPU in A10 surpasses GT 430 / HD 6570 and is close to GT 440/630 / HD 6670. Well, some people talk about upgradability, but...
renethx is offline
post #7 of 29 Old 11-22-2012, 04:28 AM
Tony_Montana's Avatar
Quoted: 45 Post(s)
hello renethx .. have you done any experiments comparing the K with non-K editions?
Is there any value on buying A10-5700 over A10-5800K and A8-5500 over A8-5600K.
I suppose that AMD used the same APU with undervolting and underclocing for lowest TDP.
The same trick that intel did in intel i3-xxxT versions.
So, what's better? Buy a non-K version and overclock it or a K version and undervolting/clocking ?wink.gif
Tony_Montana is offline
post #8 of 29 Old 11-22-2012, 05:22 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
I have A4-5300, A8-5500, A10-5700 and A10-5800K at hand, but I haven't even opened the box of A10-5800K. So far the best result is obtained by underclocking A8-5500 / A10-5700 to ~2.6GHz without touching voltage. Actually APU @2.6GHz runs with significantly lower voltage thant APU @default clock, that reduces the power consumption greatly. I see ~70W of the total system power consumption at video playback with madVR (yes, Trinity A8/A10 can do Lanczos 4 + AR easily for every video format up to HD). The stock cooler is enough and it's very quiet. CPU is less important for video playback (and 2.6GHz is powerful enough even if you decode any video by CPU). Compare with this result, 110W is outrageous. smile.gif
Switching between 2.6GHz and default clock can be done quickly by keyboard shortcuts (create profiles starting from "Balanced" power plan within Vision Engine Control Center and assign a shortcut to each profile). You don't have to tweak BIOS at all (you can do so if you prefer, of course).
So, I don't see a reason to choose a K version for a video playback system. A K version is still good if you also do some CPU intensive tasks such as encoding. You will have to add a better cooler, of course.
Tony_Montana likes this.
renethx is offline
post #9 of 29 Old 11-22-2012, 07:39 AM - Thread Starter
I don't think she cares too much about upgradeablity as long as she can watch 3d bluray discs and files as well as go on facebook. I won't be able to find out til Friday as well as ill try to put another draft build and part list together by then and post it in this thread on Friday as well.
What do you think about small sshd idea for the operating system unnecessary or a definitely do. The slave drive is probably going to be 3tb harddrive.
Thank you for all the help,
Have a happy thanksgiving.
Mike
post #10 of 29 Old 11-22-2012, 02:22 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
OS in SSD and data on HDD is a good idea. For OS in HTPC, 60-64GB is enough, e.g., Intel 330, Crucial m4, Samsung 830.
renethx is offline
post #11 of 29 Old 11-22-2012, 05:03 PM
ljo000's Avatar
IMO you're much better off using a separate BD player for disk playback. HTPC is much better for playing rips of your disks, TV and streaming content.
ljo000 is offline
post #12 of 29 Old 11-22-2012, 08:23 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
Well, playing back an optical disc in HTPC is as easy as (or as difficult as) ripped ISO / files, there is nothing special in playing back an optical disc.
Among the three, AMD GPU is perhaps the easiest to play back BR 3D with.
renethx is offline
post #13 of 29 Old 11-23-2012, 06:48 AM
ljo000's Avatar
Sure you CAN play the disks on an HTPC, but:
- Playback software may not be usable with remote
- The software is expensive whereas ripping is free
- Adding rips to a media library gives you coverart, keeping track of watched/unwatched, grouping by genre etc
- I like to keep the HTPC look and feel completely non-PC like. i.e. it boots straight into WMC fullscreen and only needs a KB/mouse for maintenance which I do via remote desktop.
ljo000 is offline
post #14 of 29 Old 11-23-2012, 09:15 AM
dubboxster's Avatar
dubboxster is offline
post #15 of 29 Old 11-23-2012, 10:14 AM
jeffkro's Avatar
Not to state the obvious but if your just going to play 3D blu-rays, buy a stand alone player. HTPCs are for people that also want a no monthly fee DVR, a box for streaming, or to store a ton of movies on a drive. I basically consider the HTPC to be a cord cutting device.
jeffkro is offline
post #16 of 29 Old 11-23-2012, 03:03 PM - Thread Starter
Those are desired as well she just wants it to do all so there isn't a need for multiple machines as well as go online to regular websites on her 3d tv screen (which doesn't not need to be in 3d nor does she want that in 3d lol) but basicly one machine that does it all, 3d movies ripped in disc, and enough power for internet streaming wordprocessing space for storing music movies and documents. Just so you have idea of what I'm working with. She also said she can break the budget of 500 if she needs to but would rather not if she doesn't have to. Upgrading isn something she's also super conserned about.
post #17 of 29 Old 11-23-2012, 04:32 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
1. MCE remote is "usable" at least with PowerDVD and TMT, the two most popular BR 3D software players.
2/3/4. Not sure what you are trying to say. If she wants to only play optical BR 3D, then HTPC is surely pointless, but that's not the case here.
renethx is offline
post #18 of 29 Old 11-27-2012, 07:19 AM - Thread Starter
I'm going to post the updated build today I'm sorry It took me so long black friday and all that where more hecktic form me than I imagined.
post #19 of 29 Old 11-27-2012, 07:35 AM
jeffkro's Avatar
Why not just get the 65W quad core trinity, it seems easier then messing around with undervolting. Although I did undervolt my llano with good results.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113288
jeffkro is offline
post #20 of 29 Old 11-27-2012, 01:06 PM - Thread Starter
For both Options
Sub total - $347.94
Option 1
Totaling @ $577.92
Option 2
Totaling @ $693.04
Feel free to make any suggestions and or corrections to my builds. Thank you an critique away. When I get closer to finalizing I'll change my first post to one or both of these biulds along with the update date.
Thank you
post #21 of 29 Old 11-27-2012, 01:25 PM
jeffkro's Avatar
for both
Sub total - $347.94
Option 1
Totaling @ $577.92
Option 2
Totaling @ $693.04
Thank you
You can go a lot cheaper on the mobo and have the same results. Should be able to pick one up for $80 easy.
jeffkro is offline
post #22 of 29 Old 11-27-2012, 02:12 PM - Thread Starter
What would you recomend and I'll take a look at them
post #23 of 29 Old 11-27-2012, 03:04 PM
Tiddles88's Avatar
Liked: 24
Intel i3 3225 + Asrock B75 Pro 3 + 8GB DDR3 1600MHz CAS 9 RAM. All you need.
Tiddles88 is offline
post #24 of 29 Old 11-27-2012, 03:31 PM - Thread Starter
I was going to do the 8gb of ram I only switched it to the 4 just to cut down on a little on the price with something not supper important or hard to upgrade later. But if i go that way with the GPU and MB i'll def. put the 8 GB in without even thinking.
post #25 of 29 Old 11-27-2012, 03:48 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
The wattage I cited is about A8-5500, quad-core 65W Trinity APU. confused.gifsmile.gif At playing back a 720p60 video in full HD under madVR (MN in chroma, Lanczos4+AR in luma),
- Default 3.2GHz: CPU voltage 1.360V, the system power consumption 100W
- Downclocked 2.6GHz: CPU voltage (will be automatically) 1.064V, the system power consumption 70W
As you (may not) know, madVR (well, almost all video playback jobs nowadays) uses GPU entirely, CPU is less important (2.6GHz is fast enough to decode all 2D/3D HD video coding formats, of course). Downclocking inside Windows is prettty easy by using AMD Vision Engine Control Center. Even I can save a profile for each max clock and use a kbd shortcut to switch between them.
"65W" is not so precise. If both Prime95 and FurMark run simultaneously, the total power consumption could reach 150W.
renethx is offline
post #26 of 29 Old 11-27-2012, 03:51 PM - Thread Starter
OP edited as of now with the current updates
post #27 of 29 Old 11-28-2012, 07:31 AM - Thread Starter
Still opened for Ideas Part suggestions and advice
post #28 of 29 Old 11-28-2012, 08:36 PM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
All it takes to reach 125W is to put an A10-5700 in the ASRock FM2A75M-ITX and go into the BIOS smile.gif. I found turning off Turbo and reducing the freq. as you say helped tremendously and not to blow a second 120W power supply smile.gif.
Question: since you say Trinity A8/A10 for 3D does that mean Trinity A4/A6 do not support 3D?
StardogChampion is offline
post #29 of 29 Old 11-28-2012, 08:39 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
A4/A6 Trinity:
- MVC decode: No
- Frame packing: Yes
All Llano
- MVC decode: Yes
renethx is offline
Reply Home Theater Computers
