HELP! No TV on Thanksgiving! I think its a Playready issue.. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-22-2012, 06:59 AM - Thread Starter
doozer12's Avatar
So I woke up this morning and found I had only a few channels and some errors from WMC saying it couldnt record because of no signal on certain channels (scheduled recordings). This does seem to happen once in a while. Although WMC doesnt tell me right off, from previous experience I assumed that Playready needed to be updated. (this happenes from time to time). So I rebooted the HTPC and when WMC starts it immediately tells me I have to update Playready. (like it usually does in these situtions). So I update Playreasy, it finishes and tells me it was successful and that I can now watch TV.
This time however, I still cant watch any copy protected channels. Which for me is just about everything after the networks. So I tried restarting WMC, no change. I rebooted the HTPC and again, as soon as WMC starts it tells me I have to update Playready. I just did that! UGH! So I updat again and it tells me again that it was successful. Again I triyto watch TV, No dice. I am stuck in a loop! I know some people have had issues where Playready would error and not update, but for me it says it HAS updated, but for somereason didnt.. not sure..
I tried a few things with no success. I tried uninstalling Playready and downloaded it through WMC. Same issue. I tried renaming the Playready file and running the update again. (had to start in Safemode to do this). My next sted is to try the DRM Reset Tool from Microsoft. But I am worried this might screw things up more. And if I use the Reset Tool, I may not be able to watch any previously recorded copy protected shows.
ANy advice would be helpful. I would really like to have this working today.
I am running Win 7 64 bit, Ceton infiniTV4 with a cable card from TWC in New England.
doozer12 is offline
post #2 of 7 Old 11-22-2012, 07:27 AM - Thread Starter
doozer12's Avatar
Also, I forgot to mention, I have not made any changes or upgrades to this HTPC. I know changing hardware can "break" Playready. Nothing what so ever has been done to it.
doozer12 is offline
post #3 of 7 Old 11-22-2012, 08:14 AM
tehowell's Avatar
I have solved issues just by deleting the contents of the PlayReady folder...
C:\ProgramData\Microsoft\PlayReady
ProgramData is a hidden folder so you'll need to make hidden folders visible in order to navigate to it with Windows Explorer.
You might also try what is suggested in this post.
Let us know the results.
Samsung UN65JS8500 65" SUHD TV FW1455; Yamaha RX-A750BL Receiver FW1.77; Samsung UHD-K8500 UHD BD player, FW1005, w/dual HDMI; one to TV (video), one to AVR (bitstream); Arris DCX-3600M Cable STB; Nvidia Shield Android TV Update 3.2, Server: Windows 10 Home and Emby Server.
tehowell is offline
post #4 of 7 Old 11-22-2012, 08:19 AM
Andy_Steb's Avatar
Quoted: 31 Post(s)
Liked: 158
Did you try a system restore? Try taking it back a few days
Andy_Steb is offline
post #5 of 7 Old 11-22-2012, 08:21 AM
pittsoccer33's Avatar
Quoted: 648 Post(s)
Liked: 426
i got play ready errors when i screwed around with different filters in the shark codec pack.
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
post #6 of 7 Old 11-22-2012, 09:19 AM - Thread Starter
doozer12's Avatar
So I tried thr DRM reset tool. No change. Even after running the security upgrade too. So I tried a restore point from a few days ago. Still no change. It did ask me to update playready again after the restore. I updated playready and it said it was successful (again). But stll no change... I did see that yesterday there was a critical update in Windows. This may have something to do with it. Not Sure.
doozer12 is offline
post #7 of 7 Old 11-22-2012, 11:16 AM
erickotz's Avatar
Liked: 30
Have you uninstalled any codec packs that you have installed? Also, try sfc /scannow
Quality Assurance Manager, Ceton Corporation
erickotz is offline
Reply Home Theater Computers
