Breaking up FlexRaid array? Anything need to do to remove a HDD from a FLEXRAID server ? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 38 Old 12-26-2012, 11:23 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
^ reason for that post is everything I am seeing is leading me to believe it's a bad drive that is giving me the problem. Not 100% dead yet but some issue on it. It's one of the GREEN drives. I might keep trying adding one more at a time each night and seeing if it takes till I find the bad one.
Mfusick is offline
post #32 of 38 Old 12-26-2012, 01:05 PM
assassin's Avatar
Quoted: 88 Post(s)
Liked: 246
This issue is not one with your drive. I have had this issue before as well.
assassin is offline
post #33 of 38 Old 12-26-2012, 01:07 PM
assassin's Avatar
Quoted: 88 Post(s)
Liked: 246
Btw no issues with green drives for almost a year in my flexraid server.
assassin is offline
post #34 of 38 Old 12-26-2012, 03:20 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
Any idea what it is ?
I just make a 12TB pool with 4 3TB drives (one totally full) it took 6 hours but it works fine.
I plan to try to make another pool with the others and figure out which drive is giving me the error. Then I will just copy the data from it and exclude it from the pool. I don't mind RMA it and add it back in the replacement later. I have enough storage to do this.
One of them is clicking. It's either an EARZ or EARS 2TB. I don't want to take a chance. Once the flexraid and snapshot is up and running I don't mind as much a failure.
Mfusick is offline
post #35 of 38 Old 12-26-2012, 03:22 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
I hate to be so critical because I used to be a WD guy. But I have had luck that is terrible recently. I forgave the first few RMA I did... but this is just silly now.
Mfusick is offline
post #36 of 38 Old 12-27-2012, 09:33 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
How did you fix ?
Mfusick is offline
post #37 of 38 Old 12-27-2012, 01:36 PM
tomandbeth's Avatar
FWIW, I've had good luck migrating all data off the disk, then "remounting" if that's the correct verb.
matter of fact, had to do it too a WD blue 1T last weekend.
tomandbeth is offline
post #38 of 38 Old 12-28-2012, 12:56 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
Your saying you basically copied off the data from the original to the new flexraid array- then reformatted and remounted the drive raw ????
Mfusick is offline
Reply Home Theater Computers
