FREE windows 8 bluray solution for HTPC - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 33 Old 02-05-2013, 03:00 PM
yesnomaybe's Avatar
Has anyone tried DVDFAB Media Player
yesnomaybe is offline
post #32 of 33 Old 02-06-2013, 02:22 AM
acejh1987's Avatar
It works to some extent, but its very buggy and although some menus work, a lot either lock up or don't work at all.
It is based on XBMC 12 (It used there source code)
In its current state I would not recommend it.
acejh1987 is offline
post #33 of 33 Old 12-07-2013, 03:40 PM
blazerqb11's Avatar
Originally Posted by elaine98 View Post
This article will guide you to download and place the AACS and BD+ DRM libraries and keys in order to play Blu Ray on Windows 8 with VLC for Free.
Step 2: Download the Blu-ray playback addon pack from: here, and install the Key file from addon pack – “KEYDB.cfg”
Wow! This actually works! It works on Windows 7 also with the latest VLC, but you have to put the KEYDB,cfg in \AppData\Roaming.
blazerqb11 is offline
Reply Home Theater Computers
