edid override issues with latest nvidia drivers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-24-2012, 10:16 PM - Thread Starter
Mangix's Avatar
I have a Philips TV with a stupid extension block added at the end of the EDID for HDTV stuff. I usually remove it as I am doing now.
However, the same trick does not seem to work anymore. I will install a new monitor.inf file created with Monitor Asset Manager but even though in the registry will be my modded EDID with the extension block removed, The extension block remains active and gives extra resolutions.
Any way to fix this? This is on Windows 8 64-bit.
Mangix is offline
post #2 of 3 Old 11-25-2012, 08:54 AM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Did you disable UAC and driver signature enforcement?
http://www.avsforum.com/t/1227161/edid-overrides-to-solve-bitstreaming-issues-for-ati-5xxxs/3240#post_22347472
EDID Overrides (capture, install/uninstall, troubleshooting)
Tulli is offline
post #3 of 3 Old 11-25-2012, 01:06 PM - Thread Starter
Mangix's Avatar
the issue is not that the .inf file has not been replaced. it absolutely has. but it seems that the nvidia driver seems not to care.
Mangix is offline
Reply Home Theater Computers
