Why did my SSD diappear? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 11-26-2012, 01:38 AM - Thread Starter
Dark_Slayer's Avatar
Quoted: 659 Post(s)
Liked: 434
Has anyone had this happen before?
http://forum.crucial.com/t5/Solid-State-Drives-SSD-Knowledge/Why-did-my-SSD-quot-disappear-quot-from-my-system/ta-p/65215
I should say, has anyone else had this happen. Not fun, thought I was going to have to process a warranty replacment
Dark_Slayer is offline
post #2 of 14 Old 11-26-2012, 06:57 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
Yup. Been there and done that.
Multiple brands too.
It's the most common version of SSD failure which failure in general is uncommon.
This happens to about 1% off all SSDs across all brand and models according to what I've read.
Mfusick is offline
post #3 of 14 Old 11-26-2012, 07:02 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
I'd still RMA it. Disappearing from Bios is not a good issue to have with any SSD.
I RMA a Crucial 64gb and older Vertex2 60gb SSD for that problem.
I didn't power cycle it or try fix. I just swapped out.
Mfusick is offline
post #4 of 14 Old 11-30-2012, 02:49 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
Any luck on this one?
Did you ever update the firmware?
Mfusick is offline
post #5 of 14 Old 11-30-2012, 03:20 PM - Thread Starter
Quoted: 659 Post(s)
Liked: 434
Well, the firmware was already up to date, but the power cycle brought it back.
It felt kind of silly following those steps, but fortunately it was not a critical PC.
I really think a lot of the RMAs on SSDs could have been solved this way before having it replaced. It seems like some kind of UEFI bios snafu to me, but I don't really know how to debug that other than just flashing a new bios. Hope it doesn't happen again !!
post #6 of 14 Old 11-30-2012, 03:31 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
Which drive was it?
I had that happen to me before. I RMA it. It's just easier sometimes to do that.
I am sure your right and lots of RMA are because of this. return data is skewed by the ease in which a consumer can create and RMA and process it.
Some companies let you set up RMA online yourself without talking to anyone. Those companies have the highest return rates.
Companies that make you call in- or troubleshoot first- Obviously have the lowest RMA. Spend on tech support and you save on return costs... Seems logical to me.
Glad you got it back working. Was the data still on it ?
Mfusick is offline
post #7 of 14 Old 11-30-2012, 03:43 PM - Thread Starter
Quoted: 659 Post(s)
Liked: 434
Yes everything intact, but I don't really keep anything precious on my OS drives anyway
If I had a spare SSD, I'd probably just RMA it
post #8 of 14 Old 11-30-2012, 03:58 PM
Tiddles88's Avatar
Liked: 24
Another quality OCZ product, my Agility died within 48hrs. For that I'm avoiding anything by OCZ period.
Tiddles88 is offline
post #9 of 14 Old 11-30-2012, 04:06 PM - Thread Starter
Quoted: 659 Post(s)
Liked: 434
It's working fine now. Yours might not have really died
This and other SSDs seem to play a disappearing act if they lose power unexpectedlly
I really don't know if it's solely an OCZ issue since the fix I posted was from a Crucial support forum
post #10 of 14 Old 11-30-2012, 06:21 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
I have it happen to a Vertex2 and a M4. So... it's probably both.. lol.
Mfusick is offline
post #11 of 14 Old 11-30-2012, 07:14 PM
assassin's Avatar
Quoted: 82 Post(s)
Liked: 243
Check your power connection thoroughly. I have had this happen to 3.5" drives using some bad adapters/splitters with a PICO. Changed or tightened the connection and it fixed the issue completely.
assassin is offline
post #12 of 14 Old 12-01-2012, 07:45 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
I have too. Both issues appear to be when a drive suddenly loses power. Then you need to do some type of odd power cycling to reset it back.
In my case the drive was totally gone from BIOS. I RMA the first two before I fixed the third myself... Since then I have not had issue.
I taught me don't use cheap SATA powerwire connectors/splitters.
Mfusick is offline
post #13 of 14 Old 12-01-2012, 10:19 AM
Rico66's Avatar
Had that happen with a drive from the high quality company with the 3 letters. It's a sign of things to come. In the beginning it happens infrequently but sooner or later it's becoming more often. I also thought that it was related to power/connectors and replaced/tried quite a lot of different combinations. RMAing the drive fixed it.
Rico66 is offline
post #14 of 14 Old 12-01-2012, 10:44 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
I tend to agree if possible RMA it to be safe.
I only fixed my HDD because it had lots of stuff on it. It's still working. Both the Crucial and OCZ Vertex2 I RMA - it's been about a year. Both replacements are in office PC's and working fine 12 months later.
It's not really a big deal but it's a big pain in the butt if it's your boot drive- or you lose information.
Mfusick is offline
Reply Home Theater Computers
