PC blu ray drive? Looking for something quiet - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-26-2012, 11:14 PM - Thread Starter
ivwshane's Avatar
Does anyone have any personal recommendations for a blu ray drive (I prefer a blu ray burner if you know of a good one). My main requirement is that it be quiet.
ivwshane is offline
post #2 of 6 Old 11-26-2012, 11:19 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
This one's a pretty good deal. I have one. http://www.newegg.com/Product/Product.aspx?Item=N82E16827136250
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #3 of 6 Old 11-27-2012, 12:14 AM - Thread Starter
ivwshane's Avatar
How is the noise level compared to other drives you used in the past? The reviews didn't have a lot to say about how loud it is.
ivwshane is offline
post #4 of 6 Old 11-27-2012, 01:04 AM
Tong Chia's Avatar
If the drive speed is limited to 1x during playback just about any BD drive is quiet, including the little laptop drives.
Nero Drivespeed is one tool
http://www.softpedia.com/get/CD-DVD-Tools/CD-DVD-Rip-Other-Tools/Nero-DriveSpeed.shtml
AnyDVD can also do that.
Limiting the drive speed during a burn also does the same thing, I am not sure if it is useful to cap the speed of the drive during a write , just mentioning it for completeness.
Tong Chia is offline
post #5 of 6 Old 11-27-2012, 11:52 AM
Antripodean's Avatar
This Pioneer BDR2207 is definitely very quiet. It's what I use and for that reason
explore the music
Antripodean is offline
post #6 of 6 Old 11-27-2012, 01:52 PM
Dark_Slayer's Avatar
Quoted: 655 Post(s)
Liked: 434
It's tough to really find good info on the loudness of a drive
I have an older LG Blu Ray / HD-DVD combo drive, and it is inaudible when used in my Thermaltake Armor+ full tower and secured with screws and anti-vibration grommets. It is a little noisy when I just slide it in the case and use the built in 5.25 "easy-latch" method to secure the drive. It is VERY noisy if I slide it into my nMediaPC 5000 case without securing it
Point being, lot's of hard drive and optical drive noise can be from the case. The case may amplify any vibrations from the drives while they are spinning (case resonance)
Lian Li cases are the worst for resonance
Lots of quiet PC enthusiasts bash components, because of the environment they put them into as opposed to the actual sound level the component produces.
Great resource http://www.silentpcreview.com/
Dark_Slayer is offline
Reply Home Theater Computers
