Sluggish performance streaming video? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 11-27-2012, 07:21 PM - Thread Starter
ugk
ugk's Avatar
TV: Panasonic 50inch ST50
Video Card: AMD Radeon HD 2GB 6950
Processor: Intel i5-2500k
When I'm trying to stream video on my TV, the picture looks great but gets pretty choppy.. is there any thing I could do on the video end to try and smooth out the performance?
ugk is offline
post #2 of 13 Old 11-27-2012, 07:23 PM
lockdown571's Avatar
Quoted: 37 Post(s)
Liked: 87
What software are you using to play the video?
lockdown571 is offline
post #3 of 13 Old 11-27-2012, 07:28 PM
jdmag00's Avatar
Also what is your source? YouTube? File on PC? From server?
Sent from my DROID BIONIC using Tapatalk 2
jdmag00 is offline
post #4 of 13 Old 11-27-2012, 07:59 PM - Thread Starter
ugk
ugk's Avatar
Alright.. Just ran some 1080p files from my hard drive.. they play well.. no issues
so I guess it's just the video I'm streaming from the internet I'm having issues the choppy playback
It's NBA Leaguepass and NFL Game Rewind BTW
Edit - Youtube 1080p streams perfectly as well
ugk is offline
post #5 of 13 Old 08-21-2013, 07:45 AM
bakerja's Avatar
I would like to resurrect this topic. I recently installed a pretty nice PC as a media PC and am having problems with NFL rewind choppy playback. First off, the PC is a quad core 2.4ghz overclocked to 3ghz with a radeon HD 6800 card. Windows 7-64bit, 8gb ram, tons of hard drive.
Netflix, amazon instant plays flawlessly. Smooth as silk. I have tried every setting available within the catalyst software and when playing NFL rewind in full screen, the quality is choppy. If I reduce the screen size, I can get near perfect quality but I am watching on a 56" DLP and want it full screen. I realize that NFL rewind uses flash video to deliver so if you right click on the screen, you have a few options for adjusting flash performance. None of these help at all. Hardware acceleration on or off doesn't seem to matter. NFL rewind suggests turning hardware acceleration off but that doesn't help.
Any suggestions??
bakerja is offline
post #6 of 13 Old 08-21-2013, 07:49 AM
pittsoccer33's Avatar
Quoted: 648 Post(s)
Liked: 426
is your flash up to date? do you have another web browser you could try?
many moons ago I fixed some Flash video problems by ENABLING Windows Aero - I'd shut it off thinking it would save system resources. turns out it introduced problems.
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
post #7 of 13 Old 08-22-2013, 08:09 AM
bakerja's Avatar
Have tried Chrome, IE, Firefox, and Opera. All have similar results. I haven't tried enabling aero, will try tonight. Maybe I'm just expecting too much but Netflix, Amazon video is buttery smooth. NFL is very fast paced compared to a movie. My system is respectable speed so I thought I should be able to stream smoothly full screen.
bakerja is offline
post #8 of 13 Old 08-22-2013, 12:05 PM
gonzo90017's Avatar
Quoted: 42 Post(s)
Have you tried reducing the bitrate?
gonzo90017 is offline
post #9 of 13 Old 08-22-2013, 12:41 PM
wpbpete's Avatar
Quoted: 66 Post(s)
Liked: 71
How does it look on a smaller display? Sounds like your dlp's refresh rate may not be compatible. I had the same problem years ago with a dlp. Now I only use 240hz on anything over 40"
wpbpete is offline
post #10 of 13 Old 08-22-2013, 04:02 PM
rnm410's Avatar
Same issue. When I play dvd's, either ripped folders or from a disc, I get choppy video.
50" ST50
AMD X2 555
Asus HD6450 fanless
Any suggestions/ insight?
rnm410 is offline
post #11 of 13 Old 08-22-2013, 07:43 PM
rnm410's Avatar
(Manual) Driver update, closed.
rnm410 is offline
post #12 of 13 Old 08-24-2013, 09:51 AM
bakerja's Avatar
Bitrate not the issue. It's choppy at all bitrates fullscreen. Refresh rate could very well be the issue but I don't think I can set it that high. Drivers are all up to date. Installed the latest AMD drivers. I'm nearly positive it's a NFL game rewind issue that they are not fully addressing. All other streaming services that I use are silky smooth.
bakerja is offline
post #13 of 13 Old 10-11-2013, 05:58 PM
bakerja's Avatar
Update:
I found an add on for xbmc about a week ago. I had some initial problems with it because I'm a xbmc noon but now have it running great. The streams are much smoother than any browser that I tried. Still not as good as off air but what can I expect. The quality is very good and I am happy.
bakerja is offline
Reply Home Theater Computers
