Windows Media Center as XBMC PVR Backend? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 11-27-2012, 06:54 PM - Thread Starter
ImThat1Guy's Avatar
Basically the title. I'm setting up an HTPC for the family, and WMC does not meet our needs for a number of things. However, XBMC is missing the most crucial part-- live, TV. And while there are solutions working with basic TV, I'm unaware of any backends or plugins supporting CableCARD-protected content.
Essentially I was wondering if there was an add-on that allowed you to use WMC as a backend for live TV. Is there any way for me to boot up into XBMC, and then as I tab through the Videos, Music, etc. tabs, there's a TV tab which boots up WMC's live TV stuff and allows me to watch TV? I know it's possible with XBMC Frodo and MediaPortal, but I'm unsure if WMC can work like that.
Alternatively, is there any backend (or heck, any other standalone program) other than WMC that can work with CableCARD (with a Ceton InfiniTV 4) content? I've yet to find any at all.
ImThat1Guy is offline
post #2 of 12 Old 11-27-2012, 07:26 PM
TheTinkerer's Avatar
This is the best way I know of...not really integration though.
TheTinkerer is offline
post #3 of 12 Old 11-28-2012, 04:06 AM - Thread Starter
ImThat1Guy's Avatar
I'm aware of that... is there no way to do it in reverse?
post #4 of 12 Old 11-28-2012, 04:51 AM
stanger89's Avatar
Quoted: 3693 Post(s)
Liked: 2054
You wouldn't be able to play protected CableCard content in XBMC even if you used WMC as a backend to record it.
stanger89 is offline
post #5 of 12 Old 11-28-2012, 05:21 AM
lockdown571's Avatar
Quoted: 71 Post(s)
Liked: 95
There are plug-ins for XBMC that allow you to launch external programs. Otherwise I say just buy an Xbox 360 (or the upcoming Ceton Echo) and use it as an extender to watch live TV, and then run XBMC on your HTPC.
lockdown571 is online now
post #6 of 12 Old 11-28-2012, 05:16 PM - Thread Starter
ImThat1Guy's Avatar
That sounds almost exactly like what I want. Can I get a link?
Also, I'd like it to send WMC directly to live TV, is that possible? If not though, that's obviously alright.
post #7 of 12 Old 11-30-2012, 12:58 PM
BigLan's Avatar
This thread has some details on how to do it, including going directly to live TV, guide or recorded shows.
http://forum.xbmc.org/showthread.php?tid=131464
I couldn't figure out how to assign escape to a button on my harmony to close WMC, so I'm using the teknoweb version for now.
BigLan is offline
post #8 of 12 Old 12-04-2012, 08:00 PM
utee05's Avatar
Quoted: 44 Post(s)
So I guess xbmc still can't be used with a cable card correct? Using xbmc as a frontend still will not allow for this? I would love to strt using xbmc for everything but I guess as long as I'm using a cable card I'm stuck with windows.
utee05 is offline
post #9 of 12 Old 12-05-2012, 06:12 AM
Quoted: 71 Post(s)
Liked: 95
NextPVR and MythTV support CableCards, and both of them have PVR add-ons for XBMC. What neither support are copy-once protected shows.
post #10 of 12 Old 10-31-2013, 07:07 PM
RTK
RTK's Avatar
Quoted: 115 Post(s)
RTK is offline
post #11 of 12 Old 11-03-2013, 08:24 AM
utee05's Avatar
Quoted: 44 Post(s)
Thanks for the link. I will give this a try on my secondary htpc to make sure I do not mess anything up with my primary htpc that I use for all of my recording.
utee05 is offline
post #12 of 12 Old 11-04-2013, 06:45 AM
Charles R's Avatar
Liked: 649
You shouldn't have any issues with the server. I have used it for several weeks and it appears to be completely transparent. Only item I ran into was when I upgraded to Windows 8.1 (from 8.1 Preview) the upgrade went south and I basically did a fresh install. Creating the same user Windows used another name (internally) so I lost permission to access/control the recording directory via the client (OpenELEC). Once I updated the WMC server credentials I was good to go (again).
I posted my experience using the client/server starting here...
http://www.avsforum.com/t/1497448/intel-nuc-dcp847ske#post_23900516
| 120" Screen | 1080p Projector | 7.2.4 Boston Acoustics & Power Sound Audio | Yamaha RX-A3060 & AudioSource AMP110 | Sony UBP-X800 | LibreELEC/ODROID-C2 Media Client | Ubuntu/ODROID-XU4 Server via Kodi/Plex Media Server : LG 65EG9600 OLED TV | TiVo | Roku Premiere+ | Blu-ray Movies for Sale | Digital HD Codes for Sale |
Charles R is offline
Reply Home Theater Computers
