Looking to get a USB 3.0 card. Are these the PCI express slots? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 11-28-2012, 09:08 AM - Thread Starter
higgybaby's Avatar
Hello, been awhile since I've messed with upgrading a PC. I want a USB 3.0 card, just making sure these are PCI express slots?
My device manager reads like there are two of them. Any suggestions on which USB 3.0 card to buy are appreciated. Only need 2 inputs.
Any help is appreciated.
camera pix 001.jpg 2298k .jpg file
camera pix 002.jpg 2755k .jpg file
Name:	camera pix 001.jpg
ID:	65208   Click image for larger version
Name:	camera pix 002.jpg
higgybaby is offline
post #2 of 13 Old 11-28-2012, 09:25 AM
vladd's Avatar
Liked: 39
Looks like the following:
(3) PCI - White slots
(1) PCI Express x8 - Larger brown slot between video card and PCI slots
(1) PCI Express x1 - Small brown slot above video card
I can't see what the video card is plugged into. If you post your PC model number I could probably tell you for sure what they are.
Image for reference:
vladd is offline
post #3 of 13 Old 11-28-2012, 10:05 AM - Thread Starter
higgybaby's Avatar
I don't have that info with me. But thank you for the help. If I need more advice, I will reply again, with the model #.
post #4 of 13 Old 11-28-2012, 10:17 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
If you want a USB card get a PCI-X card.
Mfusick is offline
post #5 of 13 Old 11-28-2012, 10:20 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Originally Posted by Mfusick View Post
If you want a USB 3.0 card get a PCI-X card.
http://www.newegg.com/Product/Product.aspx?Item=N82E16815124113
$12.99
Mfusick is offline
post #6 of 13 Old 11-28-2012, 10:50 AM
vladd's Avatar
Liked: 39
Umm, no! PCI-E. He does not have a PCI-X slot.
PCI-E = PCI Express
PCI-X = PCI Extended
vladd is offline
post #7 of 13 Old 11-28-2012, 10:52 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
PCI x1.
Mfusick is offline
post #8 of 13 Old 11-28-2012, 10:53 AM
vladd's Avatar
Liked: 39
That is a PCI-E slot. "x1" is the speed
vladd is offline
post #9 of 13 Old 11-28-2012, 10:57 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
I know. Just going too quickly.
Technically it's a PCI Express x1 slot. which is very different than a PCI X
But the slot for PCIX is way longer so I am sure there won't be any confusion on his part. Just my typo.
Thanks for the clarification. You are correct.
@ OP- Just get the link and picture card I posted for $13 and put it into the slot I circled and incorrectly labeled PCI-X when it is a PCIx1. It should be obvious it's the only slot it will fit into.
Mfusick is offline
post #10 of 13 Old 11-28-2012, 11:06 AM
vladd's Avatar
Liked: 39
It will also work in the x4/x8 slot (I can't tell which it is from the pic) but yes, that card will work.
vladd is offline
post #11 of 13 Old 11-28-2012, 03:19 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
BTW
USB 3.0: up to 400MB/s
PCI Express 1.0 x1: 250MB/s
PCI Express 2.0 x1: 500MB/s
So older PCI Express 1.0 slot could be the bottleneck of the transfer speed, although that's still a lot faster than USB 2.0 60MB/s.
renethx is offline
post #12 of 13 Old 11-28-2012, 04:07 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Originally Posted by renethx View Post
BTW
Great points.
A normal HDD is about 125MB/sec and a green drive is probably a bit slower...
A high end near empty HDD can be 150MB/sec
I doubt his speed would be bottlnecked. I say slam it into the small x1 slot and go.
I am not even sure they make USB 3.0 cards for x2 , x4 x8 or x16 slots. They certainly are not popular like the x1 slot cards are.
Mfusick is offline
post #13 of 13 Old 11-28-2012, 04:16 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
A possible case is a RAID enclosure, where > 300MB/s is pretty normal. But I haven't seen any actual comparison.
renethx is offline
Reply Home Theater Computers
