Recommendation needed for OTA DVR software - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 11-28-2012, 12:53 PM - Thread Starter
Cameron_Peck's Avatar
I have a 2 year old HTPC that I built and never really used as a HTPC. It has Vista Media Center on it now but I am open to changing if I need to. I would like to use this machine to record OTA TV only. I will not be using it as a dvd player or for surfing the web or internet tv. DVR only. I also would like to be able to watch the same content in another room with an extender or another PC or something like that. And the less tweaking it needs, the better. My wife wants it to just work. I have been out of the HTPC game for a while so I need your advice. What software would best fit my needs at the moment?
Cameron_Peck is offline
post #2 of 12 Old 11-28-2012, 01:06 PM
Zagor's Avatar
Your best bet is still Windows Media Center. It is the simplest (to setup) and best looking GUI (in my opinion) DVR available on the PC. All you need is a digital tuner(s), an antenna and a connection to the internet so that you can download the guide. You can share the recorded shows with other media center computers. Extenders can also be used to watch live TV and/or recorded shows.
jeffkro likes this.
Zagor is offline
post #3 of 12 Old 11-28-2012, 05:19 PM
Karyk's Avatar
Quoted: 225 Post(s)
Liked: 44
I would agree with the WMC recommendation, but they did make some improvements to WMC in Win7--not sure about Win8. Win8 is $39.95 right now, with a free WMC license option.
Karyk is offline
post #4 of 12 Old 11-29-2012, 12:54 AM
Mike99's Avatar
Quoted: 135 Post(s)
Liked: 64
I use my HTPC as an OTA DVR and use WMC7. I don't have much experience with other HTPC software but WMC just works for me. Just like a "real" DVR. I just click on the program I want to record from the EPG and it records. Or select the program to play & it plays. So I think your wife should like it. And there are settings to record series, etc.
I've read that WMC7 is a lot better than the Vista version. But it will cost you more for Win7 than Win8. As suggested Win8 with the free WMC right now is probably the way to go.
Mike99 is offline
post #5 of 12 Old 11-29-2012, 03:48 AM
Heuer's Avatar
Try Recorded TV HD: http://www.recordedtvhd.com/
Heuer is offline
post #6 of 12 Old 11-29-2012, 06:02 AM - Thread Starter
$40 for Win 8 + MC sounds like a great deal. Are there quirks about W8MC that would be bad for a "just works" system? I read about MC always on top & boot into MC not working out of the box but there are registry hacks to make it work so that does not bother me. But are there other pitfalls? I don't want to have to remember to reset the DVR after a power failure and that kind of thing.
post #7 of 12 Old 11-29-2012, 07:11 AM
Heuer's Avatar
WMC works perfectly on Win7 and boots straight into the media screen. WMC will recover from a reboot or power loss and retain your recordings list. Downside is WMC just keeps the programmes in one long list so if you have lots of recordings sorting them is a nightmare. This is where Recorded TV HD comes in as it fetches artwork and puts all episodes together in their own 'folder' showing the number of unwatched episodes. It runs from within WMC appearing as another menu item in the list. Makes the whole DVR wife and child friendly with great graphics but you do have to pay for it ($20) - worth it though.
Heuer is offline
post #8 of 12 Old 11-29-2012, 07:37 AM
Karyk's Avatar
Quoted: 225 Post(s)
Liked: 44
Recovering from a power loss would be dependent on the bios.
My WMC 7 groups the recordings of the same program--so there must be a setting for that. Are you maybe sorting the programs by date?
Karyk is offline
post #9 of 12 Old 11-29-2012, 07:38 AM - Thread Starter
Recorded TV HD looks like it would be a good addition. Thanks for the suggestion.
post #10 of 12 Old 11-29-2012, 08:07 AM
Rew452's Avatar
Quoted: 113 Post(s)
Liked: 65
+1 for Record TV HD! Great addition.
Rew
Rew
Vizio P75-C1 | OPPO UDP-203 | Samsung UBD-K8500
Denon AVR-X4300H00 | Nvidia Shield Android TV | C =Axiom VP150 |FL/FR =Axiom M60 |SL/SR =Axiom QS4 |TFL/TFR =Bose 161 | TRL/TRR =Bose 161 |Sub =Reaction Audio S-15 500W SEALED SUBWOOFER
Rew452 is offline
post #11 of 12 Old 11-29-2012, 10:12 AM
Heuer's Avatar
Yes you can re-order the recordings but Recorded TV HD creates, in effect, box sets of episodes together with art work. As for power loss recovery it does indeed depend on correct BIOS setting and having no password for Windows as a given.
Heuer is offline
post #12 of 12 Old 11-29-2012, 12:00 PM
jeffkro's Avatar
Yup, its already installed and works great. Why go looking around? If I were building from scratch I would probably give mythTV a shot, mostly just to save on buying a windows license.
jeffkro is offline
Reply Home Theater Computers
