How to properly force WMC to use a different RF channel? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 11-29-2012, 12:06 AM - Thread Starter
pixelation's Avatar
Quoted: 13 Post(s)
My local station is broadcasting a channel in both UHF and VHF in different locations. It turns out that my VHF channel is weak but it seems 7MC prefers the VHF channel. How can I force the 7MC to use the other channel? I know I can "add" a channel and then assign the guide but from time to time the channel get overwritten. Any ideas?
pixelation is offline
post #2 of 11 Old 11-29-2012, 12:35 AM
Mike99's Avatar
Quoted: 135 Post(s)
Liked: 64
There a way to change the order and/or delete the sources a tuner uses. I'm at a different PC right now so I can't verify the steps. But go into WMC > Settings. And I think it's TV > Edit. After you select the channel number you can select the source & use the up/down arrow keys to move the UHF source above the VHF one, or IIRC you can also delete it.
Mike99 is offline
post #3 of 11 Old 11-29-2012, 08:43 AM - Thread Starter
pixelation's Avatar
Quoted: 13 Post(s)
The problem is the UHF source isn't part of the default WMC guide. WMC database just pick one and they picked the VHF. Looks like I would have to add the channels manually.
post #4 of 11 Old 11-29-2012, 09:18 AM
Rico66's Avatar
Did you scan for channels? It should fine the channel, if it exists. The mapping is a different issue, but you can fine tune that under tv -> guide > edit channels.
Rico66 is offline
post #5 of 11 Old 11-29-2012, 09:45 AM - Thread Starter
pixelation's Avatar
Quoted: 13 Post(s)
I have scanned the channels but I don't see any new channels being added. Perhaps it is because it overlaps with existing channels.
post #6 of 11 Old 11-29-2012, 10:57 AM
dicko2's Avatar
Quoted: 17 Post(s)
Are you sure about this? Here in Chicago both VHF and UHF stations are rolled into one guide listing.
dicko2 is offline
post #7 of 11 Old 11-29-2012, 10:58 AM
erickotz's Avatar
Liked: 30
Maybe put a notch filter on the blocks the VHF channel entirely and re-scan?
Quality Assurance Manager, Ceton Corporation
erickotz is offline
post #8 of 11 Old 11-29-2012, 01:09 PM
Mike99's Avatar
Quoted: 135 Post(s)
Liked: 64
That's what happened with channel 7 for me also. The WMC7 guide lists the following:
7.1 WLSSTA
7.2 WLSSTA2
7.3 WLSDT3
I recently rearranged the sources putting ch 44 above the ch 7. Did you do anything to get 7.1 to display WLSDT instead of WLSSTA? I thought about doing a new channel scan but figured ch 7 will come out on top again.
Mike99 is offline
post #9 of 11 Old 11-29-2012, 08:15 PM
dicko2's Avatar
Quoted: 17 Post(s)
Mine says WLSDT. I didnt do anything to make it say that. I disabled the VHF channel. It doesnt come in too well where I am. Of course, during times of skip, the UHF station doesnt come in too well either. Then I have to switch back to the VHF station. Its a real pain and the VHF station is probably going away real soon.
dicko2 is offline
post #10 of 11 Old 11-29-2012, 10:07 PM - Thread Starter
pixelation's Avatar
Quoted: 13 Post(s)
Looks like I was wrong. I see both VHF and UHF in the source listing. In fact, there were 3 copies of the same channel with 2 identical UHF. I unchecked one UHF and VHF and I think this solves my problem. Thanks!
post #11 of 11 Old 11-30-2012, 01:18 AM
Mike99's Avatar
Quoted: 135 Post(s)
Liked: 64
I don't know which channel freq is considered the "STA" one. Initially I thought it would be ch 7 since that one is supposedly going away in January & is considered temporary. But it was there before the ch 44 freq. So I didn't delete either one, I just moved all the ch 44 sources to the top. I did a channel scan not too long ago so will probably get the same results if I do another. I guess I'll wait a couple months & then do another scan.
Mike99 is offline
Reply Home Theater Computers
