Problem WMC Through Remote Connection - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 12-01-2012, 08:08 AM - Thread Starter
Karyk's Avatar
Quoted: 225 Post(s)
Liked: 44
I've been using Jump Desktop to connect to my HTPC on both my normal Windows desktop and my Android device. I mainly use it to schedule programs I forgot to add (e.g. football games), so I don't connect that often. The HTPC is running Win7, and the normal Windows desktop used to connect is running Win8.
Now I can connect, but I can't get WMC to run via the connection. When connected through my desktop I just get the message right away that WMC stopped working. When connecting through Android I get a message that the color resolution isn't high enough.
I've made two changes recently.
First, I installed Win8 on the desktop on which I connect through. I did that the first day Win8 was available, and I don't remember whether I've connected since then or not.
Second, I've changed displays on the HTPC to a 1080p display (before it was 1080i).
Since it won't start WMC using either Win8 or Android, I assume it's not related to Win8 being added to the normal desktop used to connect.
Karyk is offline
post #2 of 11 Old 12-01-2012, 09:05 AM
Rico66's Avatar
Does it start as an admin (right click "run as admin)? If that's the case, then you can lower the access rights for HKLM\SYSTEM\CurrentControlSet\Control\Terminal Server\WinStations\Rdp-Tcp (e.g. full access to authenticated users) to fix this.
Rico66 is offline
post #3 of 11 Old 12-01-2012, 09:06 AM
lockdown571's Avatar
Quoted: 56 Post(s)
Liked: 89
I can't really answer your question, but why not just use the Ceton Companion App on your Android phone? It's much easier to just schedule missed recordings that way.
lockdown571 is offline
post #4 of 11 Old 12-01-2012, 09:11 AM - Thread Starter
Karyk's Avatar
Quoted: 225 Post(s)
Liked: 44
I'll give it a try.
Karyk is offline
post #5 of 11 Old 12-02-2012, 07:20 AM - Thread Starter
Karyk's Avatar
Quoted: 225 Post(s)
Liked: 44
I can't get port forwarding to work for that program. Reading through their forums, I suspect it's because I have two NICs, but their fixes don't work.
So that gets me back to the original question. Why can't I open WMC when connected?
Karyk is offline
post #6 of 11 Old 12-03-2012, 04:29 PM
Charles R's Avatar
Liked: 629
Going from Windows 8 to Windows 7 (via Remote Connection) I have to run MC as Administrator.
| 120" Screen | 1080p Projector | 7.2.4 Boston Acoustics & Power Sound Audio | Yamaha RX-A3060 & AudioSource AMP110 | Sony UBP-X800 | LibreELEC/ODROID-C2 Media Client | Ubuntu/ODROID-XU4 Server via Kodi/Plex Media Server : LG 65EG9600 OLED TV | TiVo | Roku Premiere+ | Blu-ray Movies for Sale | Digital HD Codes for Sale |
Charles R is offline
post #7 of 11 Old 12-04-2012, 07:14 AM - Thread Starter
Karyk's Avatar
Quoted: 225 Post(s)
Liked: 44
Thanks, I'll try that.
Karyk is offline
post #8 of 11 Old 12-04-2012, 11:49 AM
Rico66's Avatar
You don't have to do that (see my previous post above)
Rico66 is offline
post #9 of 11 Old 02-11-2013, 03:27 PM - Thread Starter
Karyk's Avatar
Quoted: 225 Post(s)
Liked: 44
I found the answer to this question on a few websites. Apparently a security update in about October caused the problem.
I found a solution here:
http://www.sevenforums.com/media-center/261036-remote-desktop-wmc-stopped-working.html
It involves going into the regedit, finding the registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Terminal Server\WinStations\Rdp-Tcp
and then setting permissions for "Users" to read the key.
It seems to work. Does anyone see a problem with having done that?
Karyk is offline
post #10 of 11 Old 02-11-2013, 03:33 PM
bryansj's Avatar
Quoted: 1336 Post(s)
Liked: 625
I think it was answered here in the second post and the one above yours...
bryansj is offline
post #11 of 11 Old 02-11-2013, 03:43 PM - Thread Starter
Karyk's Avatar
Quoted: 225 Post(s)
Liked: 44
Sure enough. I may have been distracted by trying the Centon app, although I don't remember getting it to work properly running as an administrator, so maybe I did that wrong and then never tried the fix.
Karyk is offline
Reply Home Theater Computers
