Which HD **** would be sufficient for MadVR - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1 of 212 Old 12-01-2012, 11:18 AM - Thread Starter
Hannzz's Avatar
Quoted: 20 Post(s)
I am wondering if HD 6450 should be fine for MadVR and should I go with nVidia card GT 630 or more powerful like HD 6670. Thanks
Hannzz is offline
post #2 of 212 Old 12-01-2012, 09:54 PM
corpgator's Avatar
I'm running an HD6870 and the only thing it can't handle is the highes jinc. I'm using the Intel Quick-sync Decoder for LAV, though, leaving the GPU to do just rendering while the CPU does the decoding.
corpgator is offline
post #3 of 212 Old 12-02-2012, 04:52 AM
Mnoe's Avatar
Yeah, really the question is what content will you watch and what scaling options do you prefer?
For progressive material (SD and HD 24fps), I have a 6570 and 6670 that do Jinc3/AR (luma/chroma) with playback to 1080P without issue. Will not handle Jinc/AR w/Deinterlacing, however, have turn off AR or back it down to Lanczos or Spline.
Mnoe is offline
post #4 of 212 Old 12-02-2012, 06:05 AM
steelman1991's Avatar
Quoted: 211 Post(s)
Liked: 116
Quite frankly - stick with something cheap - and forget madVR - I'm runnning it on a 65" plasma and 110" projector and I'm damned if I can tell the slightest difference in either HD or SD playback in comparison - pure placebo.
steelman1991 is offline
post #5 of 212 Old 12-02-2012, 06:40 AM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
What?!? Blasphemy! wink.gif I said something similar months ago and some people questioned my sanity.
assassin is offline
post #6 of 212 Old 12-02-2012, 06:44 AM
Tony_Montana's Avatar
Quoted: 45 Post(s)
If you are talking about 1080p Full HD there are no significant differencies
but if you are watching 720p, interlaced material or DVD / SD(.avi) the scaling algorithms can do terrific job.
The auto refresh rate change is a nice feature, too.
My opinion is to buy the most powerfull card you can afford and if you have problems
try some lower settings.
Tony_Montana is offline
post #7 of 212 Old 12-02-2012, 10:25 AM
ctviggen's Avatar
Quoted: 116 Post(s)
Liked: 32
I really don't understand what this says. Did you do a test using MadVR on SD playback on your 110 inch screen and then the same test without using MadVR on the same screen? Or are you saying that you can't tell the difference between HD and SD playback of the same information on the same screen?
Bob
ctviggen is offline
post #8 of 212 Old 12-02-2012, 11:12 AM
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 79
there is really no reason i can think of not to use madvr if you use windows.
It's free, and you can configure it to be very fast as well as excruciatingly slow, it's sorta your preference.
To answer OP's question, you can make it work either card I think, but the higher end cards would give you more options in the scaling department.
Sammy2 likes this.
MlNDBOMB is offline
post #9 of 212 Old 12-02-2012, 11:25 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I originally got MadVR to do frame rate switching but then discovered that it didn't play well with 720p as the HD2000 graphics in my i3-550 weren't up to the task. A $60 GT-430 resolved that issue and then I was able to dial in the frame rate to nearly 23.976 as well with frame skips on the order of many hours. I do notice frame skips when they occur but that doesn't make it a bad thing at all as it doesn't look bad at all. It is the inability of HD2000 to keep up with 720p Live/Recorded TV that was the issue as there were frame skips on the order of 3 or 4 a second which is VERY noticeable.
That said, not using MadVR is a viable option if you don't need automatic frame rate switching or are using XBMC, which I am not. If you go that route you most assuredly are not losing your sanity.
Sammy2 is offline
post #10 of 212 Old 12-02-2012, 11:27 AM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
1. Added cost ($-$$$) of discrete graphics card
2. Added heat of discrete card
3. Added hassle
4. Larger case needed for discrete card
5. Potentially larger PSU needed for discrete card
Just a few off the top of my head.
assassin is offline
post #11 of 212 Old 12-02-2012, 11:27 AM
Quoted: 211 Post(s)
Liked: 116
Agreed but I woudn't go shelling out big bucks just to use it
@mfusick - thanks.
@assassin - yes and I agreed with you then as well lol.
Why has automatic refresh rate switching become so highly rated for madVR use? - xbmc, media portal, mpc-hc natively all do it.
post #12 of 212 Old 12-02-2012, 11:34 AM
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 79
madvr doesnt require a discrete card. you always had the option of using bilinear for slow gpus, and now you have the dxva scaler too.
and with ivy bridge and trinity, integrated graphics has gotten faster too.
MlNDBOMB is offline
post #13 of 212 Old 12-02-2012, 11:39 AM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
I understand. But if you want to use all the possible settings in Madvr you need a discrete card. So saying you don't need one at all isn't really accurate.
Still waiting on some screenshots for 1080p and 720p showing the differences. Madshi showed comparison screenshots on non-HD material so I have no idea why this has been so difficult to show for HD material.
assassin is offline
post #14 of 212 Old 12-02-2012, 11:39 AM
juaniquillo's Avatar
After 3 years using a Popcorn Hour, this past black Friday I finally was able to build my first HTPC. I did setup XBMC following Assassin guides for HD audio bitstreaming, these are my findings:
1. 1080p Bluray (folders) movies look better on the HTPC. This is a huge surprise, because the popcorn is highly regarded for picture quality and I didn't think there were room for improvement.
2. 720p24 TV shows and movies look so much better on the Popcorn. I tried every possible upcaling method in XBMC and it didn't make a difference. Am I doing something wrong? Big dissapointment here.
3. DVD movies ripped to mkv look terrible on the HTPC.The Popcorn is just so much better.
75% of the content I watch is 1080p Bluray movies, 20% 720p24 TV Shows and movies. The problem is that lately I being watching just TV Shows that I obtained using the awesome program called sickbeard.
It seems extremely odd, that a great program as XBMC (that has almost everything you need to enjoy an HTPC) does a such a poor job in the upscaling department.
This is off course just my opinion, but also IMHO you have to be blind not to see the difference. Just remember this comparison is using XBMC and a Popcorn Hour A-200.
Now I need to decide if any alternatives or hardware upgrades are worth my time.
What are the alternatives for an HTPC front end with good integration with MPC-HC?
juaniquillo is offline
post #15 of 212 Old 12-02-2012, 11:42 AM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
So you may benefit from something like Madvr. I would try it especially for your non-HD media.
assassin is offline
post #16 of 212 Old 12-02-2012, 11:43 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
3. Added hassle
Very true but my case and PSU were already big enough. I agree on added heat but have not seen any ill effects and don't think I will in the life-span of my HTPC either.
@mfusick - thanks.
I tried it with HPC-HC but could not get it to work. I don't use the other offerings as I like MB and don't want to spend the time to configure XBMC which I don't think works with WMC extenders. Media Portal doesn't work at all with Copy Protected content or CableCARD tuners so it is out of the question too.
True. I could update my MoBo and CPU or get a GPU. Getting the GPU was much cheaper.
Sammy2 is offline
post #17 of 212 Old 12-02-2012, 12:38 PM
Tiddles88's Avatar
Liked: 24
With Broadwell/Skylake in 2/3yrs, if Intel is on track with its GPU's, you won't need a dedicated GPU for MadVR at all.
Tiddles88 is offline
post #18 of 212 Old 12-02-2012, 01:09 PM - Thread Starter
Hannzz's Avatar
Quoted: 20 Post(s)
My other machine specs are Intel Celron G530 dual core and 4 gig Ram, 60 inch Sharp LCD....currently, using built-in video.
Hannzz is offline
post #19 of 212 Old 12-02-2012, 02:30 PM
Assassin, I know your point of view regarding the "picture upscaling quality issue" and I understand your main goal is to bring simplicity to the whole HTPC complex setup process, which you do with your guides, but I think your skills will serve well the community if you decide to do a madVR guide.
I tried to follow the 4th option for HD Audio setup in your guides, but the integration with XBMC is just not there, for instance what happen when you stop the movie, you are left with MPC open.
Can you point me in the right direction to setup a better upscaling option in XBMC or other front end solution?
post #20 of 212 Old 12-02-2012, 02:44 PM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
I have a Madvr guide here.
Also Mindbomb has an excellent Madvr guide which I also link from my guide.
assassin is offline
post #21 of 212 Old 12-02-2012, 03:13 PM
Quoted: 211 Post(s)
Liked: 116
Set-up correctly that shouldn't happen. Do you have the 'keys' in mpc-hc set to 'exit' on stop. Options\Keys\Exit - set as MEDIA_STOP (don't worry that 'stop' is already using the same command, they can co-exist quite happily. If you have already done that - post your playercorefactory file here and we'll have a look at what's going on.
post #22 of 212 Old 12-02-2012, 05:48 PM
Ooops, my bad. It's in the Beta Section. Great, I'll check it soon. Thanks.
Thanks, I'll try tonight.
post #23 of 212 Old 12-02-2012, 06:06 PM
OK, 2 more questions, I looked everyehere on the forum here and on Anandtech an there's no answer. I got a i3-3220 (just because it was $19 more than a celeron on black friday), since the only thing I'm really missing/interesting on is to upscale 720p24 content:
1. Is the i3-3220 enough to upscale 720p24 using Lanczos3?
2. Is the Lanczos3 used in XBMC different in any way to the one used by madVR?
Why Anandtech and Renethx don't have any benchmarks on this type of common files? or am I blind?
Regards.
post #24 of 212 Old 12-02-2012, 07:06 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
1. Yes, Intel HD Graphics 2500 is (barely) enough for 720p24 under madVR Lanczos3+AR in image upscaling (and MN in chroma) in a 1080p display.
- Rendering time: ~36ms (a bit close to 41.7 ms = 1 / 24fps)
- GPU usage: ~90%
2. I don't know.
renethx is offline
post #25 of 212 Old 12-02-2012, 09:22 PM
jdastas's Avatar
Assasin,
I built my first HTPC thanks to your guides. I'm running an I5-2500K and only using the built-in graphics (HD3000 I believe). I am very confused on the use of MADVR in that I use XBMC for everything. So am I able to utilize MadVR and XBMC together at the same time? I didn't even know what MadVR was until I opened up this thread. Thank you in advance.
jdastas is offline
post #26 of 212 Old 12-02-2012, 09:28 PM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Originally Posted by jdastas View Post
Assasin,
No, you have to use MPC-HC for Madvr and not XBMC.
As I have stated many times before I am not as high or excited about Madvr as some people on AVS. I have tried it and not seen any noticeable improvement but almost all of my media is 1080p or 720p. The 480 stuff I have is mostly kids movies (and they don't care about the PQ either way wink.gif )
As to not offend the very passionate Madvr fanbase here at AVS I will leave it at that. The only way for you to know is to try it out yourself. I have a guide in my "Advanced/Beta" section that you can use if you want to try it out.
assassin is offline
post #27 of 212 Old 12-02-2012, 11:54 PM
jdastas's Avatar
Got it, Thank You!
jdastas is offline
post #28 of 212 Old 12-03-2012, 01:12 PM
- GPU usage: ~90%
Thanks Renethx. Using those settings I'm getting 100% GPU usage, probably because your test has a faster RAM? I have 8GB DDR3-1600.
The other issue is that playback is stuck at the beginning, I have to press stop and then press Play again for the movie to start.
post #29 of 212 Old 12-03-2012, 01:28 PM
To update my comments above and speaking strictly about scaling 720p24, I have notice that XBMC picture quality is highly dependant on the source quality, it seems obvious but it's not.
For intance for bluray rips @ 720p24 the picture quality is comparable to the scaling of the Popcorn Hour. Web-DL (TV episodes) in the other hand look like s*****.
About the 24p bug, I can say that so far I haven't notice a single glitch, even though XBMC shows the display changing constantly between 23.95 and 23.98 FPS.
madVR in the other hand, shows a constant frame rate of 23.972.
post #30 of 212 Old 12-04-2012, 12:05 AM
Chronoptimist's Avatar
Liked: 532
Only if your display is throwing away resolution or otherwise filtering chroma. The improved chroma upscaling in MadVR should definitely be noticeable.
Same goes for the 16-bit YCC > RGB conversion process which should eliminate any banding not in the source. Many players don't use enough precision when converting to RGB and can introduce banding.
But many displays (particularly Plasma or DLP) introduce banding, so you don't see the benefit of it.
The benefits can be easily shown and measured. It's anything but placebo.
But if you are less discerning, or your display is not capable of showing the improvements it makes, then it might not be worthwhile. Or you may see the differences and not care.
Admittedly if you are not upscaling above 1080p, you may not notice the difference with Blu-ray. It's very obvious in my setup though.
MadVR 1080p chroma
Other 1080p chroma
Check the smoothness of the letters and brightness of thin areas. Text in MadVR is sharper with smoother diagonals and has a uniform brightness.
MadVR gradation
Other gradation
Gradation is much smoother in MadVR.
Downscaling HD or upscaling DVDs is a huge improvement over any other player and very easy to show.
I don't have any 720p footage as I only use my Blu-rays and DVDs with it, but the difference should be easy to tell.
The other improvements of MadVR are difficult to show off in screenshots rather than in motion.
Chronoptimist is offline
Reply Home Theater Computers
