WASAPI necessary when using Asynchronous USB? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-02-2012, 11:05 AM - Thread Starter
HowardV's Avatar
Quoted: 65 Post(s)
Liked: 52
HTPC connected to a DAC which has Asynchronous USB input. I installed the drivers on my Win7 HTPC that allows Asynchronous USB. Do I still need to worry about using WASAPI? If it matters, I'm using Foobar.
Oppo BDP-105 Blu-Ray
Spectron Premiere MKII 7 Channel Class D Amp (500w x 7)
2 Anthony Gallo Reference SA Amps
5 Anthony Gallo Reference 3.5 Speakers
Sunfire Super JR Subwoofer
Sony Z2 Series laptop as dedicated HTPC
HowardV is offline
post #2 of 3 Old 12-02-2012, 12:08 PM
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 80
i mean, you might as well, there's no reason not to.
foobar has a great wasapi plugin.
MlNDBOMB is offline
post #3 of 3 Old 12-08-2012, 08:54 AM
Eiffel's Avatar
Quoted: 13 Post(s)
Yes, you do need WASAPI or ASIO with Windows Vista, 7 or 8 for bit perfect output. This is not strictly required with XP, as some DACs, such as my Audiolab MDAC, can rebuild the original signal, as well as confirm that no bits got mangled by playing a special test track.
Eiffel is offline
Reply Home Theater Computers
