Flexraid help deciding - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 164 Old 02-09-2013, 11:59 PM - Thread Starter
Dark_Slayer's Avatar
Quoted: 667 Post(s)
Liked: 436
11-12 hours, can't remember exact minute amount. The elapsed time counter stops upon completion
Dark_Slayer is offline
post #122 of 164 Old 02-10-2013, 12:10 AM - Thread Starter
Quoted: 667 Post(s)
Liked: 436
Originally Posted by amarshonarbangla View Post
And can you guys link to which label maker you are using?
Wound up using some labels we keep in supply room at office, usually for file folders. Put one over the existing HDD label and matching one on sata cable.
Originally Posted by Mfusick View Post
nice. Oldschool like mine? Or new school ?
Not very new, circa 2007
I have 7 5.25 expansion bays with a 5x3.5 tool-less HDD rack
I put in a 4 in 3x5.25 Cooler Master expansion cage to allow 9 HDDs. Any more storage will require another. I can fit 4 more HDDs in there since I still have 3 5.25 bays available, and the cage is only $20
post #123 of 164 Old 02-10-2013, 06:43 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
Old gaming rig ?
Mfusick is offline
post #124 of 164 Old 02-10-2013, 07:34 AM - Thread Starter
Quoted: 667 Post(s)
Liked: 436
Yep
post #125 of 164 Old 02-10-2013, 10:08 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
You still game ?
Mfusick is offline
post #126 of 164 Old 02-10-2013, 12:27 PM
amarshonarbangla's Avatar
Quoted: 28 Post(s)
Liked: 43
amarshonarbangla is offline
post #127 of 164 Old 02-10-2013, 12:43 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
What should I set WHS2011 power options to be ?
Should I turn of HDD "NEVER" or should I turn off after say 30 min ????
What is the advantage and disadvantage ?
Would turning them off save $$ on electricity, but just cause them to have to spin up and a small delay when first accessing the server ?
Mfusick is offline
post #128 of 164 Old 02-10-2013, 04:28 PM - Thread Starter
Quoted: 667 Post(s)
Liked: 436
Not really gaming since getting married. I spent way too much time on my k/d ratio anyway
I have mine turn off after 5 minutes
Flex raid will not spin them down on its own, but it will only spin up the ones you access rather than the whole array
On average about 5 kWh savings a month per drive
Not a great idea for drives you access often
post #129 of 164 Old 02-10-2013, 11:15 PM
Quoted: 28 Post(s)
Liked: 43
Isn't constantly spinning up and spinning down drives bad for them in the long run?
post #130 of 164 Old 02-11-2013, 05:49 AM - Thread Starter
Quoted: 667 Post(s)
Liked: 436
Most drives already perform head parking through their firmware nearly as often as the settings I described
post #131 of 164 Old 02-11-2013, 06:17 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
I'm going to test 30 min setting.
If I notice a problem I'll leave them always on
Mfusick is offline
post #132 of 164 Old 03-04-2013, 10:45 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
Depends on your use patterns really.
Mfusick is offline
post #133 of 164 Old 03-05-2013, 05:03 AM
goros's Avatar
Liked: 34
Wow, this thread should be stickied. Lots of good info - gives me some idea of what I want to set up when everything finishes rolling in. If you have 5 - 2TB drives and 5 - 3TB drives and you want 2 parity drives...can you do a 2 and a 3, or do both parity drives have to be 3?
goros is offline
post #134 of 164 Old 03-05-2013, 05:16 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
You need to use your largest drive
Mfusick is offline
post #135 of 164 Old 03-05-2013, 05:20 AM
goros's Avatar
Liked: 34
Doh. I figured, but I was hoping.
goros is offline
post #136 of 164 Old 03-05-2013, 06:15 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
your parity drive (or drives) must be at least as large as your largest data drive so it can hold parity information for everything that might be on your biggest data drive. If it was smaller, It simply could not. So you must always use a parity drive that is at least equal to your largest data drive. For me I use a 3TB since my largest drives I own are 3TB. At some point I'll upgrade to 4TB probably. Swapping out a parity drive is not a hard thing to do.
Mfusick is offline
post #137 of 164 Old 03-05-2013, 08:20 AM
goros's Avatar
Liked: 34
I just don't like the idea of losing 6TB of storage (out of 25..i know i know) It is what it is. I'd rather go overkill than have to re-rip everything.
goros is offline
post #138 of 164 Old 03-05-2013, 08:32 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
What do you mean ?
Mfusick is offline
post #139 of 164 Old 03-05-2013, 08:35 AM
goros's Avatar
Liked: 34
Wait, am I retarded?
This would work like raid 6 wouldn't it?
Nevermind. I am retarded. Not sure what I was thinking.
goros is offline
post #140 of 164 Old 03-05-2013, 10:00 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
I'll try to help you. I'm just confused too.
Mfusick is offline
post #141 of 164 Old 03-05-2013, 10:19 AM
goros's Avatar
Liked: 34
No no no. I was (for whatever reason) thinking I lost the storage on those drives like a true backup, not like a parity drive. So in my head, I'm doing math like RAID1, but for 2 drives instead of the whole array, and losing 6TB.
When You asked your Initial question it kicked me into realizing it was like RAID6 and that I wasn't really losing that much space.
goros is offline
post #142 of 164 Old 03-11-2013, 12:37 PM - Thread Starter
Quoted: 667 Post(s)
Liked: 436
Has anyone copied an existing flexraid config-db to an OS re-install (i.e. after swapping SSDs, or swapping for an SSD etc)
post #143 of 164 Old 03-11-2013, 01:23 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
It's easier to start over
Mfusick is offline
post #144 of 164 Old 03-12-2013, 03:16 PM
rbmcgee's Avatar
Great Thread.
After 13 years with an HTPC and storage scattered across what is now 6 different computers, this thread has spurred me to create a central storage location via Flexraid. I do have a few questions though that I would like some help with.
1) Currently many of the hard drives have a folder like "Movies" on them and then a bunch of ripped movies inside. If I were to just put those drives into a pool on the new server wouldn't that cause a problem because I will lose the drive designations and therefore have multiple folders with the same name in the pool which I assume is not allowed. Works fine for separate disks but I'm assuming not so well when pooled. Advice?
2) Some of these drives have been formatted with 4k clusters and some with 64k clusters. Will this represent a problem with parity? Seems like it might. Do I need to reformat so that they all have the same size clusters and if so, what's the better size?
3) Although the "new" server has a really nice and new Rosewill Gold 650w power supply (with 8 sata connectors) the mobo only has 6 sata ports. That means I will need a couple ports on a PCI-E card. How about this cheap Rosewill RC-211 $17.99 from newegg. http://www.newegg.com/Product/Product.aspx?Item=N82E16816132008
4) The "new" server also does not have enough 3.5" bays (only 4) for the hard drives. I figure I could use a drive cage so that I could fit 4 more drives into 5.25 bays. How about this cheap COOLER MASTER STB-3T4-E3-GP $24.99 from newegg. http://www.newegg.com/Product/Product.aspx?Item=N82E16817993002 Not only holds the drives but puts a fan on them.
Thanks for any help.
Bob
Bob
rbmcgee is offline
post #145 of 164 Old 03-12-2013, 03:28 PM
Quoted: 28 Post(s)
Liked: 43
Originally Posted by rbmcgee View Post
Great Thread.
Bob
1) The duplicate folders will be combined into one AFAIK.
2) Shouldn't cause problems but don't quote me on it. Post this question on the official FlexRAID forum to get a more competent answer.
3) That card is out of stock and doesn't have any reviews. Find one that has mostly positive reviews. I saw one around here that was pretty well received. I will try and find it for you. For future expansion though, I will recommend you just get an IBM M1015 HBA. It has two SAS ports which can split to 8 SATA ports via a couple of these cables. It has to be flashed with a different firmware in IT mode before you can put it to use. It can be had for under $100 on ebay. I say invest in that to make expandability easier in the future. Get a new case too ^_^
4) That will work just fine. Here's another option, although it's out of stock currently.
Here's another excellent thread about FlexRAID, M1015 and everything server related. There are some good resources there.
http://www.avsforum.com/t/1438027/planning-to-rebuild-my-20tb-whs-flexraid-server-information-requested
post #146 of 164 Old 03-12-2013, 06:23 PM
rbmcgee's Avatar
Thanks for the info.
After I thought about, it makes sense that it will combine the folders.
I will check on the cluster size issue
I may consider a new mobo (8 ports), but I really like the case.
Bob
rbmcgee is offline
post #147 of 164 Old 03-18-2013, 06:32 AM
goros's Avatar
Liked: 34
Might be cheaper just to get an m1015 used off eBay. I paid $117 including shipping and the bracket, plus another $20 for LSi breakout cables. Added 8 sata6 ports and could have added more if I wanted to run a SAS expander.
goros is offline
post #148 of 164 Old 03-20-2013, 12:43 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
+1
I paid as low at $80 for this.
There is a guide how to do it I made in my server guide. You can take the IBM card and make it a $250 LSI card... by cross flashing it.
Mfusick is offline
post #149 of 164 Old 04-22-2013, 08:44 AM
Nethawk's Avatar
Liked: 118
This has been an excellent thread, thanks very much to all of you who have provided both the challenging questions and the answers. It deserves a bump to the top again.
While data protection has been discussed thoroughly, and there is some important knowledge regarding disk pooling, I wonder what the benefits of pooling are outside of protection from running out of space. It would seem to me that at least two drives would be involved anytime an IO request is initiated, which is not necessarily desired. I'm sure I am missing something.
I was of the same mindset as Dark_Slayer - I'm just too stubborn about file management to give into the possibility of someday flexraid going away and having files all over the place. But I've gotten over it, especially if pooling provides some performance or environmental benefit. Otherwise I may just purchase raid on its own and forego pooling.
Thank you in advance.
Nethawk is offline
post #150 of 164 Old 04-22-2013, 10:57 AM
Quoted: 28 Post(s)
Liked: 43
Only the disks you are reading from will be active. If you are reading files from two different drives, only then would two drives be involved. If you are reading files from one drive, only that drive drive is involved.
Reply Home Theater Computers
