MPC-BE.. Anybody Using It?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 12-04-2012, 11:59 AM - Thread Starter
Sammy2's Avatar
Quoted: 522 Post(s)
Liked: 254
Sammy2 is offline
post #2 of 16 Old 12-04-2012, 12:01 PM
assassin's Avatar
Quoted: 132 Post(s)
Liked: 254
Very interesting. Can you run madvr with it yet?
assassin is online now
post #3 of 16 Old 12-04-2012, 12:05 PM - Thread Starter
Sammy2's Avatar
Quoted: 522 Post(s)
Liked: 254
I have no idea but I think so. I just learned about it today. It is a fork of MPC-HC that looks to only be a few months old. More research is required here.
Sammy2 is offline
post #4 of 16 Old 12-04-2012, 12:18 PM
cburbs's Avatar
Quoted: 94 Post(s)
Liked: 29
Looks like it from this post -
http://www.thegreenbutton.tv/forums/viewtopic.php?f=9&p=35386
Might have to test it out on my test rig.
"You’re KILLIN’ ME Smalls! "
Sony 55EX500 Settings
cburbs is offline
post #5 of 16 Old 12-04-2012, 02:48 PM
steelman1991's Avatar
Quoted: 249 Post(s)
Liked: 140
Yes came across it the other day, runs everything mpc-hc does. As Sammy says its a fork of mpc-hc. Quite stable for a 'beta' - resolves my issues with chapter skip. Unless under the hood is different, there is little to distinguish the two - slighlty different OSD, but presented along very similar lines to mpc-hc
steelman1991 is online now
post #6 of 16 Old 12-04-2012, 02:51 PM - Thread Starter
Sammy2's Avatar
Quoted: 522 Post(s)
Liked: 254
Does it do fast forward and rewind with a remote?
Sammy2 is offline
post #7 of 16 Old 12-04-2012, 02:58 PM
Quoted: 249 Post(s)
Liked: 140
Not something I use an awful lot - will test and report back.
EDIT - Nope only thing was chapter skip - no ff or rew
post #8 of 16 Old 12-04-2012, 03:16 PM - Thread Starter
Sammy2's Avatar
Quoted: 522 Post(s)
Liked: 254
So that is the same as MPC-HC. That is probably the only reason I would make the change. Right now I have the >> and << keys mapped to a 30 second skip right now but will probably reduce that a bit.
Does it have the same or similar "right click" menu system?
Sammy2 is offline
post #9 of 16 Old 12-04-2012, 03:37 PM
Quoted: 249 Post(s)
Liked: 140
Sammy - its almost identical - one or two cosmetic changes, but that's all - certainly that I can see. I can use it the same way I did mpc-hc, with the exception that chapter skip works with this build.
Sorry yes to answer your question - right click menu system as before.
post #10 of 16 Old 12-04-2012, 03:39 PM
hogues's Avatar
Quoted: 84 Post(s)
Liked: 62
There are the jump buttons that, if you hold them down, kind of act as a ff/rw. Not as good, but at least it's something.
hogues is offline
post #11 of 16 Old 12-04-2012, 03:44 PM - Thread Starter
Sammy2's Avatar
Quoted: 522 Post(s)
Liked: 254
It seams that I am having chapter support in MPC-HC but I may be wrong. I think it is a setting in the "Keys" menu.
It is ff/rew that is not like i'd like it to be with the jump function programed to the H-900.
Sammy2 is offline
post #12 of 16 Old 12-04-2012, 04:06 PM
hogues's Avatar
Quoted: 84 Post(s)
Liked: 62
I
Agreed. True FF/RW on either MPC version would make it almost perfect.
hogues is offline
post #13 of 16 Old 12-04-2012, 04:11 PM - Thread Starter
Sammy2's Avatar
Quoted: 522 Post(s)
Liked: 254
So maybe I wait to install this as it really isn't much of an improvement at this time.
Sammy2 is offline
post #14 of 16 Old 12-04-2012, 05:19 PM
Rico66's Avatar
When you guys say "chapter support in mpc missing (or not)", last time I played a DVD I could skip chapters back and forth. Same goes for chapters in mkvs (if those are included). So I don't think that that is missing (not working) in mpc-hc. Could well be a configuration issue due to keys being mapped to other functions.
Rico66 is offline
post #15 of 16 Old 12-04-2012, 08:33 PM
clubwerks's Avatar
Quoted: 79 Post(s)
Liked: 46
If you dig down into the MPC-HC menus, you can get creative with your Harmony remote. My skip buttons do a 10 second back/ 30 second forward and my FF/RW buttons do a 10 minutes skip forward and back.
clubwerks is offline
post #16 of 16 Old 12-04-2012, 10:45 PM
Quoted: 249 Post(s)
Liked: 140
Chapter skip is there in mpc-hc and all variants, but has been broken for at least the last 2 builds - misses chapters on skip (ie moving from 1 to 3, 4 to 6 etc) have raised this as a bug with the devs.
Reply Home Theater Computers
