Advice Needed for HTPC Build/Buy - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 12-04-2012, 04:09 PM - Thread Starter
dpn
dpn's Avatar
I need help!
I have a dedicated theater room with a 120" horizontal width screen, with Mitsubishi HC-3800 Projector, Onkyo 608 Rx with 7.1 audio, LFE equipped Coaster Pavillon reclining theater seats, Panasonic Blu Ray with Wifi, X Box, DVR, Wii. I also have a Harmony One remote. I built and installed everything except for laying the carpet!
I want to rip my (primarily) Blu Ray movies, store them using the HTPC, and play them through my system utilizing XBMC. I also want to be able to browse the internet.I think I want to only rip the movie only, no extras,no foreign language, no subtitles, and I am not interested in compressing the ripped movie. Memory is cheap.
I have NOT gotten an HTPC yet, so I am looking for a small form factor PC. I do have a supply (4) of Toshiba external 1 TB USB hard drives that COULD form the basis for my storage system, if they will work. I want to rip my Blu Ray dvds using a different PC, not the HTPC. I want the HTPC to use Windows 7 and XBMC. I will need Wifi.
So, what processor can handle this?
How much RAM do I need?
What Blu Ray player would be recommended for the ripping job. (I have a fast PC at my office that I can set up to rip Blu Rays while I'm at work. The Blu Ray drive will NOT be installed in the HTPC.)
Do I need a separate video card?
I want to use a remote controller/true keyboard for web browsing. Is the Lenova N5902 good?
What else do I need? If I could find what I'm looking for pre-built that would be great.
Thanks in advance,
David
dpn is offline
post #2 of 16 Old 12-04-2012, 04:50 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
David
So, what processor can handle this = Sandy or Ivy CPU. Anything from G620 and up. If your not budget limited I would recommend a Z77 motherboard with i3 IVY with HD4000 graphics.
RAM = 4GB will work but I would get 8GB just to be safe.
Asus makes a good bluray drive.
No you don't need a video card.
The lenovo remote is great!
Mfusick is offline
post #3 of 16 Old 12-04-2012, 05:22 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Pretty sound advice. The hardware is the easy part. I suggest signing up for assassin's blogs for the rest of it.
Sammy2 is offline
post #4 of 16 Old 12-04-2012, 08:41 PM - Thread Starter
dpn
dpn's Avatar
Thanks for the reply.
Any thoughts about the suitability of the Toshiba HDDs?
David
dpn is offline
post #5 of 16 Old 12-04-2012, 09:55 PM - Thread Starter
dpn is offline
post #6 of 16 Old 12-04-2012, 10:53 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
I like the 3225 but here's a better deal ($109.99 after rebate): http://www.amazon.com/Intel-i3-3225-Dual-Core-Processor-Cache/dp/B0093H8H8I/ref=sr_1_1?s=electronics&ie=UTF8&qid=1354684770&sr=1-1&keywords=i3+3225
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #7 of 16 Old 12-05-2012, 07:15 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
+1 for both i3 linked and Assassin guides.
Hardware is easy. Software and set up have learning curve.
Mfusick is offline
post #8 of 16 Old 12-05-2012, 07:39 AM - Thread Starter
dpn
dpn's Avatar
Many thanks for the link!
Am I missing the rebate??? Price is showing as $134.99.
David
dpn is offline
post #9 of 16 Old 12-05-2012, 08:44 AM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
With a combo deal. Add a $25 giftcard and at checkout the giftcard is fully discounted. wink.gif (down the page a bit)
olyteddy is offline
post #10 of 16 Old 12-05-2012, 11:42 AM - Thread Starter
dpn
dpn's Avatar
Duh! I should have seen that,
Thanks again!
dpn is offline
post #12 of 16 Old 12-10-2012, 02:07 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Yup motherboard and CPU look great.
Do you have a microcenter near you ?
You can get the i3 for $80 with HD4000 graphics and the Z77 Asrock PRO 3 for $89. That would be the next step up.
Otherwise that motherboard looks like a nice choice.
You might want to check out this CPU instead :
http://www.superbiiz.com/detail.php?name=G630BOX G630 $58
or
a 3.0ghz G860
$61
http://www.superbiiz.com/detail.php?name=G860BOX
or a $45
http://www.superbiiz.com/detail.php?name=G550BOX
Mfusick is offline
post #13 of 16 Old 12-10-2012, 02:09 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
If you can get the G630 cheaper.. than the G620 your looking at I would say do that.
Mfusick is offline
post #14 of 16 Old 12-10-2012, 07:28 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
You will disable DXVA2 and use CPU/software with Intel+XBMC. You will have more options with AMD (e.g. A4-3400 or A4-5300)+XBMC. Check XBMC forum, where AMD Llano/Trinity is very popular unlike AVS Forum.
renethx is offline
post #15 of 16 Old 12-13-2012, 11:13 AM - Thread Starter
dpn
dpn's Avatar
What if I use Windows Media Center?
David
dpn is offline
post #16 of 16 Old 12-13-2012, 06:43 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Trinity / Llano can do whatever Celeron / Pentium can do, and more (e.g. full range RGB, BR 3D [except for A4 Trinity])...
renethx is offline
Reply Home Theater Computers
