HTPC - Dolby Home Theater v4 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-04-2012, 06:08 PM - Thread Starter
damelon's Avatar
Liked: 283
So I guess I finally noticed my HTPC has a program called "Dolby Home Theater v4" on it, which is turned on and set to "Movies". Do I want to turn this off when playing blu rays through my HTPC to my preamp? I would assume so, I guess I installed it with drivers but wanted to check if anyone has had experience with it.
damelon is online now
post #2 of 3 Old 12-04-2012, 08:17 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
It depends on the connection from HTPC to the preamp. Dolby Home Theater works only with LPCM audio streams coming into the onboard audio codec (then output from S/PDIF or analog).
renethx is offline
post #3 of 3 Old 12-05-2012, 06:42 AM - Thread Starter
damelon's Avatar
Liked: 283
Ah ok. I'm just using HDMI for everything, but was just wondering if it was altering the sound playing off my blu rays
Reply Home Theater Computers
