H61 Build - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-04-2012, 08:49 PM - Thread Starter
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
So I bought this BareBone H61 (ShellShocker, $59.99) http://www.newegg.com/Product/Product.aspx?Item=N82E16856119065. My question is does the H61 chipset support QuickSync? If so, I'll probably build another i3-3225 HTPC, if not I'm going on the cheap and using a $40 Celeron. The 35 Watt Pentium chip at $75 is also on my radar. This one is for the bedroom so I don't need anything fancy. Thoughts? Suggestions?
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #2 of 5 Old 12-04-2012, 08:53 PM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
That's very likely this motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813186216. I would look at the manufacturer's site for CPU support. QuickSync would be a function of the CPU AFAIK.
StardogChampion is offline
post #3 of 5 Old 12-04-2012, 10:42 PM - Thread Starter
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
Close, but no cigar. The Motherboard is the H61SP and has a much more HTPC-centric choice of connections, including 8 channel audio, HDMI and eSATA:
olyteddy is offline
post #4 of 5 Old 12-05-2012, 09:33 PM - Thread Starter
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
I looked into it further, and it's actually an H67 chipset. Here's the MoBo: http://www.foxconnchannel.com/ProductDetail.aspx?T=motherboard&U=en-us0000515 eek.gif
olyteddy is offline
post #5 of 5 Old 12-05-2012, 11:42 PM - Thread Starter
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
Went for the Amazon $109.99 i3-3225.
olyteddy is offline
Reply Home Theater Computers
