ArcSoft DTS Decoder - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-04-2012, 10:49 PM - Thread Starter
Favelle's Avatar
Does this file no longer exist in the "endless MKV" thread?
In terms of LFE, size does matter!
Favelle is offline
post #2 of 8 Old 12-05-2012, 05:58 AM
rsoares28's Avatar
Quoted: 116 Post(s)
Liked: 27
Are you referring to the DTSdecoder dll? If you use LAV i dont think this file is needed anymore. I recently reformatted my htpc, forgot to find and put that file in the ncessary spot and my DTS HD mkv's work fine. Actually this thread just reminded me about that file.
i can find it and email it to you but not until i get home from work 8hrs from now:)
rsoares28 is offline
post #3 of 8 Old 12-05-2012, 06:23 AM
steelman1991's Avatar
Quoted: 278 Post(s)
Liked: 147
Its only needed if you want LAV to decode DTS-HD and send it as PCM. If you are bitstreaming and allowing the receiver to decode the stream its not needed and doubt it ever was.
steelman1991 is online now
post #4 of 8 Old 12-05-2012, 11:42 AM
rsoares28's Avatar
Quoted: 116 Post(s)
Liked: 27
ahh thank you
post #5 of 8 Old 12-05-2012, 01:54 PM - Thread Starter
Favelle's Avatar
You need it to rip any bluray with dts-ma audio. This isn't for playback....it's for ripping my movies to the htpc.
Favelle is offline
post #6 of 8 Old 12-05-2012, 02:48 PM
Quoted: 278 Post(s)
Liked: 147
Don't think you do. MakeMKV, ClownBD and AnotherEAC3to will all rip without it - unless you are looking to rip to FLAC which I believe requires that particular file. Perhaps if you were a little less obtuse it would be easier to provide an answer.
post #7 of 8 Old 12-05-2012, 11:33 PM - Thread Starter
Favelle's Avatar
My copy of MakeMKV wouldn't do it without it. I found an old copy of the TMT file and once installed, it ripped perfectly.
Favelle is offline
post #8 of 8 Old 12-06-2012, 09:42 AM
JDLIVE's Avatar
Quoted: 99 Post(s)
Liked: 57
Send a message via Yahoo to JDLIVE
You must have selected an option to convert the audio, that's the only reason a DECODER would be required, because a conversion would require a decode/re-encode. If you're just "ripping" the streams aren't decoded, they are just copied from the disc to your hard drive. And potentially re-muxed to a different container.
JDLIVE is offline
Reply Home Theater Computers
