Mediabrowser - no audio in m4a files - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-05-2012, 08:42 PM - Thread Starter
halfordb's Avatar
Hi, i have some music that I had previously downloaded from itunes in m4p (protected) format. I used the store to redownload the music in m4a format. mediabrowser sees it ust fine (it didn't see the m4p files) but when i play it, it has no volume. Is there something else I have to do to be able to use the songs i bought from apple in mediabrowser?
thanks
halfordb is offline
post #2 of 3 Old 12-05-2012, 08:42 PM - Thread Starter
halfordb's Avatar
Also - the songs play fine in itunes
halfordb is offline
post #3 of 3 Old 12-06-2012, 01:52 PM
Sammy2's Avatar
Quoted: 556 Post(s)
Liked: 264
First off, don't buy songs from apple.
But if you already did that do you have the right codecs installed?
Sammy2 is offline
Reply Home Theater Computers
