Windows Media Center MPC-HC/BE Plug-in - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 12-08-2012, 01:42 AM - Thread Starter
Joni_78's Avatar
I've always wanted to play Blu-ray's from native Windows Media Center Movie Library so that they open with players like MPC-HC or MPC-BE, so I could get the best possible image quality by using madVR and LAVFilters.
I decided to make a MPC-HC/BE Plug-in for 7MC/8MC, it's written in C#, Visual Studio 2012. When you start Blu-ray playback from Movie Library (Physical Disc Drives, Mounted Drives and Folders on HDD), it instantly launches MPC on full screen and playback starts, when playback ends, MPC closes and takes you back to Movie Library. Remote back button closes MPC and takes you back to Media Center.
MPC-HC & BE allows you to use the best possible video renderer, splitter and video/audio decoders (madVR and LAVFilters). madVR can for example automatically change your display refresh rate to 24p when Blu-ray playback starts.
Short video of how it works.
http://www.youtube.com/watch?v=MQwzVABwIhg
1.0.2.2 - 2012/12/10 Download
Features
- Can launch Blu-ray, HD DVD, DVD* and MKV* files from native WMC Movie Library (Physical Disc Drives, Mounted Drives and Folders on HDD).
- Can move WMC out of DirectX exclusive mode before MPC loads.
- Resumes playback where you left.
- Remote buttons are mapped as in WMC.
*If you wan't to launch DVD's and MKV files from Movie Library, create a folder BDMV alongside with VIDEO_TS folder or MKV file.
Known issues
- If you press for example Green button or Guide button, WMC activates on the background to take some remote commands over MPC.
I've added MPC-BE in the installer in the first builds so it's easier to test, I plan removing it soon so that the installer has just the plug-in. You can remove MPC-BE from "Program Files\Media Player Classic" and copy MPC-HC there, your settings aren't affected if you have previously used MPC-HC from different folder.
Links
MPC-HC
MPC-BE
madVR
LAVFilters
xy-vsfilter
55" Sony Bravia KDL-55XBR8 | Yamaha RX-V659 | Yamaha Piano Black NS-777/C444/333 | Fractal Design Define R2 | AMD FX-8120 @ 4.22 GHz (1.272 V) | Asus M5A99X EVO | Sapphire HD 7750 Ultimate | Windows 8 Pro with Media Center (64-bit)
Joni_78 is offline
post #2 of 10 Old 12-08-2012, 06:38 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
So is there a list of improvements in BE over HC forks of HPC?
There's another plugin to do this here. I haven't used it because I prefer the Media Browser library over the WMC native library.
Sammy2 is offline
post #3 of 10 Old 12-08-2012, 08:10 AM - Thread Starter
Joni_78's Avatar
It's a different kind of plug-in. It doesn't allow DVD's or Blu-ray's from Movie Library.
There's guite a lot improvement's, too bad the authors haven't done english changelog. MPC-HC is lacking dev's and is only getting bugfixes atm so no improvements/new features expected there.
http://translate.google.fi/translate?sl=auto&tl=en&js=n&prev=_t&hl=fi&ie=UTF-8&eotf=1&u=http%3A%2F%2Fwww.xvidvideo.ru%2Flogi-izmeneniy%2Flog-izmeneniy-media-player-classic-be.html
Just noticed save video from youtube, I wonder if that really works.
Joni_78 is offline
post #4 of 10 Old 12-10-2012, 09:17 AM - Thread Starter
Joni_78's Avatar
Fixed some bugs.
Joni_78 is offline
post #5 of 10 Old 12-10-2012, 09:39 AM
Postmoderndesign's Avatar
Quoted: 216 Post(s)
Liked: 85
I applaud your efforts. Getting media browser to allow me to select MPC-HC for blu-ray playback and getting media browser to automatically mount .iso files are high on my want list.
I am waiting for a new internal Blu-ray drive to come. When it does I will give your plug in a try. Please keep posting how your development is coming.
Anál nathrach, orth’ bháis’s bethad, do chél dénmha
Postmoderndesign is offline
post #6 of 10 Old 12-10-2012, 10:40 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
All I really need is a true solution for >> and << rather than using 'x' second skips to do it. Anything going on with that?
Sammy2 is offline
post #7 of 10 Old 02-14-2013, 06:12 AM
Relmoos's Avatar
To Joni_78
Using build 1.0.2.2, I've been able to get blu-rays to work. Excellent!
I have three suggestions, which I hope you can implement in a next version:
- when I select the "Play DVD" option in 7mc, the screen turns black for a moment but then 7mc returns to the main menu. That makes you think the operation has failed, but after a few seconds MPC-BE kicks in. Is it possible to increase the time the screen goes black until the moment MPC-BE takes over playing the video?
- when I return to 7mc after playing the blu-ray, 7mc sometimes gets juddery, as if it where operating at 24fps (which it doesn't). Minimizing the window, switching refresh rates, nothing helps. Restarting 7mc is the only way of getting rid of this. Perhaps of importance in this matter: I let MPC-BE change my refresh rate to match the 24Hz of the Blu-ray, but it neatly returns to 50Hz after quitting. I use Reclock as well.
- playing MKV's doesn't work. I read somewhere this is because of 'spaces' in the filestructure. My MKV's are structured as "D:\My DVD's\Name Of The Movie\Name Of The Movie.mkv". I'm not a fan of renaming the structure without spaces, because this also changes the movie title display in the movie library of 7MC.
Your work is greatly appreciated! I really hope you are willing to go the extra mile of making your plugin for me the ultimate solution for my high definition movies with 7mc.
Relmoos is offline
post #8 of 10 Old 02-14-2013, 05:57 PM
dazzo17's Avatar
Well Done looks like a great addition to WMC is it easy enough to add in media browser library as I dont use the WMC movie folders (Im a novice user so I'm not sure how easy that is)
dazzo17 is offline
post #9 of 10 Old 03-07-2013, 03:05 AM
Relmoos's Avatar
After some more tests, it seems the problem I mentioned earlier is that the plugin, after exiting MPC-BE, doesn't re-enable Exclusive Mode for 7MC. Even though the original refresh rate is restored after playback, 7MC still acts as if the refresh rate of the movie was applied.
Joni, could you please fix this?
Relmoos is offline
post #10 of 10 Old 03-10-2013, 05:02 PM
kkrull's Avatar
Does anyone have media center displaying cover art on the blu-ray folders that are be executed by this plug-in?
kkrull is offline
Reply Home Theater Computers
