GT 640 - the next HTPC king? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 12-08-2012, 01:00 PM - Thread Starter
Tiddles88's Avatar
Liked: 24
Anandtech review:
http://www.anandtech.com/show/5969/zotac-geforce-gt-640-review-
but this looks like a fantastic card. Its a shame they didn't compare the GTX 650 (GDDR5 bandwith in particular) but if HD 4000 doesn't do it for you, this will.
The only (slight) issue is with colour spaces, RGB range and all that. Drivers should fix that though. For those interested in pushing MadVR right up, this will do it.
Looking forward to my next build when Haswell is released.
Tiddles88 is offline
post #2 of 11 Old 12-08-2012, 02:45 PM
MKANET's Avatar
Quoted: 50 Post(s)
Liked: 24
This is a relatively old article; but, arguably still holds true.  The GT640 is ideal for 2D/3D BD playback and digital TV recordings on 1080p displays.  It's especially useful for smaller, space-saving HTPCs; especially, the low profile variety.  Although, if you're into 3D gaming, the 645GT/650GT would be a much better choice.
MKANET is offline
post #3 of 11 Old 12-09-2012, 04:35 AM
Heuer's Avatar
To take advantage of the latest versions of madVR you will need at least a GTX650Ti and some are suggesting a GTX660!
Heuer is offline
post #4 of 11 Old 12-09-2012, 02:23 PM
MKANET's Avatar
Quoted: 50 Post(s)
Liked: 24
I've seen lots of recommendations and suggestions of what display card (and respective performance) is needed for madVR.  However, last I checked, I haven't seen any real-world case where someone's GT640 was too slow to handle typical MadVR GPU based scaling tasks; especially on a PC with a fast CPU.  I'm curious if anyone here has actually seen any case like this reported before.
There's no doubt that MadVR does use up a good amount of memory bandwidth; but, doesnt need anywhere near the maximum memory bandwidth of a GT640 (28.5GB/sec) for typical madVR settings.  If anything, a very fast CPU would be much more beneficial than getting a higher model display adapter.
MKANET is offline
post #5 of 11 Old 12-09-2012, 02:33 PM
Heuer's Avatar
Depends what you want to do. You can run madvR on an i3 with integrated GPU with some settings - varies depending on what material you are processing. But if you want to use Jinc and remain future proof you need muscle. Post on Doom9 MadvR thread for a more forthright reply.
Heuer is offline
post #6 of 11 Old 12-09-2012, 02:50 PM
MKANET's Avatar
Quoted: 50 Post(s)
Liked: 24
Yes, I visit that Doom9 forum thread quite often.  I've only seen suggestions/recommendation.  As I said, I certainly haven't seen any real-world usage that exceeds 28.5GB/sec; presuming an adequate CPU.  I guess there could be some very unlikely scenarios
MKANET is offline
post #7 of 11 Old 12-09-2012, 03:02 PM
Tong Chia's Avatar
You can check mem controller utilization in real time using GPU-Z, I have never seen it hit 100% on MadVR even on a GT430 with 1/2 of the mem bandwidth.
I use CUVID not the DXVA copyback for the video decoding
I have a i3 530 I use with the 430, it still works quite well if the new features (AR, Jinc) are not enabled, with 0 dropped frames and reasonable render (<16.7ms) times.
Tong Chia is offline
post #8 of 11 Old 12-09-2012, 03:13 PM
Tong Chia's Avatar
Only if you want to use Jinc + anti ring filters on both chroma and luma channels.
There are more improvements in the 0.8x versions of MadVR besides the above namely better precision in the YUV->RGB conversion.
post #9 of 11 Old 12-09-2012, 08:31 PM
jeffkro's Avatar
HTPC GPU's are so 2010.
jeffkro is offline
post #10 of 11 Old 12-09-2012, 08:57 PM - Thread Starter
Tiddles88's Avatar
Liked: 24
HD 4000 will die with MadVR pushed to the limit. APU's won't fare much better.
post #11 of 11 Old 12-10-2012, 04:05 AM
Heuer's Avatar
Heuer is offline
Reply Home Theater Computers
