simple question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-08-2012, 08:04 PM - Thread Starter
stamina1914's Avatar
Quoted: 106 Post(s)
I am in the middle of my build, my chassis has 3 fans, but my board has only two chassis fans outletsbut it has 2 cpu outlets and 1 power fan outlet. Which one should I connect my third chassis fan too.
Also anyone with experience with the grandia 08, my optical drive is not ejecting, I belive I may have to use a different alignment. Thoughts?
stamina1914 is offline
post #2 of 3 Old 12-08-2012, 09:53 PM
Toys7505's Avatar
Quoted: 69 Post(s)
Liked: 26
On the Silverstone case - there are adjusters on the eject button to make sure it "hits" your optical eject button. You just need to slide it forward a little so it engages your optical drive eject when you press the case eject button.
Toys
Denon AVR-3311CI, Denon DVP-602CI, B&K Reference 200.7 S2, Belkin PF60
Sony BDP-S5000ES, Silverstone HTPC (6 Tuner DVR & 10 TB Media)
PSB Stratus Minis, PSB Stratus C6, PSB Alpha S surround, James Subwoofer EMB-1200
Sharp LC-70LE755U, Harmony 880 Remote
Toys7505 is offline
post #3 of 3 Old 12-09-2012, 12:39 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
You can use Y-Cable 3Pin Molex to 4x 3Pin Molex to connect up to 4 case fans to a fan connector of the mb (each of the 900rpm stock fans consumes < 0.1A).
renethx is offline
Reply Home Theater Computers
